HP ZBook Studio x360 G5 Core i7-8750H 16GB 256GB SSD 15.6" Touch Windows 10 Professional 64-bit
Quicklinx: F70FWS00 Mfr#: 6KP03ET#ABU
  • Core i7
  • IEEE 802.11n
Reimagine your creative process with a versatile laptop that gives you the latest convertible design you'll want with the pro-grade performance you need. Showcase your work like never before with five unique modes.
  • Windows Pro for workstations
    Be productive in any situation. Windows 10 Pro and powerful security, collaboration, and connectivity features from HP help you power through your day on the HP ZBook Studio x360.
  • HP ZBook x360 Pen
    Create on the go with the professional Wacom AES pen featuring 4K pressure sensitive levels, tilt and two customizable buttons.
  • 15.6" diagonal touch display
    Take your work outdoors with the anti-glare touch display and built in ambient light sensor that dims or brightens based on your surroundings.
  • Fast charging and long battery life
    Take your work on the road with up to 16 hours of battery life for maximum productivity. When you need it, recharge ultra-fast (50% in just 45 minutes).
  • Blazing fast storage
    Create seamlessly. Save and access large files locally with up to 4TB local NVMe storage, up to 21 times faster than standard HDD storage and six times faster than SATA SSD.
  • 8th Gen Intel Core i9 or Intel Xeon processors
    Do more at once with next-generation six-core Intel Core i9 or Intel Xeon processors designed to handle complex, multi-threaded applications like Adobe Premier Pro.
HP ZBook Studio x360 G5 Mobile Workstation - 15.6" - Intel Core i7 8750H - 16 GB RAM - 256 GB SSD - UK
Mobile workstation - flip design
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (8th Gen) 8750H / 2.2 GHz (4.1 GHz) / 9 MB Cache
16 GB DDR4 (2 x 8 GB)
Storage
256 GB SSD - SED, TLC
Display
15.6" LED backlight touchscreen 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 630
Input Device
Keyboard, ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 5.0
4-cell - up to 18.5 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
36 cm x 25.4 cm x 1.87 cm
2.22 kg
Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
4.1 GHz
Number of Cores
6-core
Cache
9 MB
64-bit Computing
Chipset
Mobile Intel CM246
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
16 GB (2 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - non-ECC
Speed
2666 MHz
Rated Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
0
Storage
Main Storage
256 GB SSD M.2 2280 SATA 6Gb/s - Self-Encrypting Drive, triple-level cell (TLC)
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
400 cd/m²
Colour Gamut
100% sRGB
Ambient light sensor, Panel Self Refresh (PSR), Corning Gorilla glass 4, Full HD eDP anti-glare
Keyboard Name
HP Collaboration
Audio & Video
Graphics Processor
Camera
Yes - 720p
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
Low light enhancement
Sound
Stereo speakers, dual array microphone
High Definition Audio
Audio Features
Output: Bang & Olufsen Audio, HP Clear Sound Amp
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-touch clickpad, gesture function
Communications
Wireless
Wireless Controller
Intel Wireless-AC 9560 - PCI Express Mini Card (M.2)
IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
4-cell lithium polymer
64 Wh
Run Time
Up to 18.5 hours
AC Adapter
Input
Output
150 Watt, 19.5 V
Connections & Expansion
USB 3.0 (charging) , USB 3.0 , HDMI , 2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort 1.3 Alt Mode) , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Security
Power-on password, One-Step Logon, Setup Password, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, Pre-boot Authentication, BIOS Update via Network, HP Sure Click
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
CSA, UL, FCC
Localization
2.22 kg
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Essential Accessories (6)
Get more from your purchase from one of our essential accessories
F70F HP Power Connector Adaptor DC Jack 7.4mm (F) To DC Jack In Stock £13.44
F70F HP Dual Head Keyed Cable Lock In Stock £43.00
F70F HP USB-C mini Dock - Docking Station - USB-C - VGA, HDMI - GigE In Stock £35.26
F70F HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt In Stock £135.82
F70F HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt In Stock £188.99
F70F HP Travel Hub G2 Port replicator USB-C VGA, HDMI for Chromebook In Stock £41.06
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
F70F HP Care Pack Next Business Day Hardware Support - extended service agreement - 3 years - on-site In Stock £120.47
Other bundles (8)
F70F HPE HDMI to DVI Adapter In Stock £9.89
F70F HPE DisplayPort to VGA Adapter In Stock £16.40
F70F HP USB-C To VGA Adapter In Stock £22.68
F70F HP USB Travel Mouse In Stock £10.58
F70F HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor In Stock £2,821.06
F70F HP Premium Wireless Mouse In Stock £38.00
F70F HP USB-C to DisplayPort Adapter In Stock £23.53
F70F HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor In Stock £150.00
