Reimagine your creative process with a versatile laptop that gives you the latest convertible design you'll want with the pro-grade performance you need. Showcase your work like never before with five unique modes.
Windows Pro for workstations
Be productive in any situation. Windows 10 Pro and powerful security, collaboration, and connectivity features from HP help you power through your day on the HP ZBook Studio x360. -
HP ZBook x360 Pen
Create on the go with the professional Wacom AES pen featuring 4K pressure sensitive levels, tilt and two customizable buttons. -
15.6" diagonal touch display
Take your work outdoors with the anti-glare touch display and built in ambient light sensor that dims or brightens based on your surroundings. -
Fast charging and long battery life
Take your work on the road with up to 16 hours of battery life for maximum productivity. When you need it, recharge ultra-fast (50% in just 45 minutes). -
Blazing fast storage
Create seamlessly. Save and access large files locally with up to 4TB local NVMe storage, up to 21 times faster than standard HDD storage and six times faster than SATA SSD. -
8th Gen Intel Core i9 or Intel Xeon processors
Do more at once with next-generation six-core Intel Core i9 or Intel Xeon processors designed to handle complex, multi-threaded applications like Adobe Premier Pro.
- HP ZBook Studio x360 G5 Mobile Workstation - 15.6" - Intel Core i7 - 8750H - 16 GB RAM - 256 GB SSD - UK
- Product Type
- Mobile workstation - flip design
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i7 (8th Gen) - 8750H / 2.2 GHz, up to 4.1 GHz / 9 MB Cache
- Memory
- 16 GB DDR4 (2 x 8 GB)
- Storage
- 256 GB SSD - SED, TLC
- Display
- 15.6" LED backlight touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 630
- Input Device
- Keyboard, ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 5.0
- Battery
- 4-cell - up to 18.5 hours
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- 36 cm x 25.4 cm x 1.87 cm
- 2.22 kg
- Localisation
- Manufacturer Selling Program
- HP Smart Buy
- Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i7 (8th Gen) 8750H / 2.2 GHz
- Max Turbo Speed
- 4.1 GHz
- Number of Cores
- 6-core
- Cache
- 9 MB
- 64-bit Computing
- Chipset
- Mobile Intel CM246
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 16 GB (2 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM - non-ECC
- Speed
- 2666 MHz
- Rated Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 0
Storage
- Main Storage
- 256 GB SSD M.2 2280 SATA 6Gb/s - Self-Encrypting Drive, triple-level cell (TLC)
Display
- 15.6" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Brightness
- 400 cd/m²
- Colour Gamut
- 100% sRGB
- Ambient light sensor, Panel Self Refresh (PSR), Corning Gorilla glass 4, Full HD eDP anti-glare
- Keyboard Name
- HP Collaboration
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Video Resolutions
- 1280 x 720
- Frame Rate
- 30 frames per second
- Camera Features
- Low light enhancement
- Sound
- Stereo speakers, dual array microphone
- High Definition Audio
- Audio Features
- Output: Bang & Olufsen Audio, HP Clear Sound Amp
Input
- Keyboard Layout
- UK
- Spill-resistant, multi-touch clickpad, gesture function
Communications
- Wireless
- Wireless Controller
- Intel Wireless-AC 9560 - PCI Express Mini Card (M.2)
- IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Technology
- 4-cell lithium polymer
- Capacity
- 64 Wh
- Run Time
- Up to 18.5 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 150 Watt, 19.5 V
Connections & Expansion
- Interfaces Details
- USB 3.0 (charging) , USB 3.0 , HDMI , 2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort 1.3 Alt Mode) , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
- Security
- Power-on password, One-Step Logon, Setup Password, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, Pre-boot Authentication, BIOS Update via Network, HP Sure Click
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- CSA, UL, FCC
- Localization
- HP Smart Buy
- 2.22 kg
Sustainability Information
- TCO Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
Essential Accessories (1)
Get more from your purchase from one of our essential accessories
HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt | In Stock | £115.06 |
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
HP Care Pack Next Business Day Hardware Support - extended service agreement - 3 years - on-site | In Stock | £122.39 |
Other bundles (3)
HPE DisplayPort to VGA Adapter | In Stock | £13.38 |
HP USB-C To VGA Adapter | In Stock | £22.09 |
HP USB Travel Mouse | In Stock | £9.39 |
