Meticulously built with extraordinary performance in a transformative size, never has so much power been engineered into such a sleek package. Rigorously tested. Ingeniously crafted. Keep your best talent creating on the best tech with the new benchmark for mobile workstations.
Windows 10 Pro for Workstations 64
Work without compromising on performance or security with Windows 10 Pro for Workstations, powered by HP's collaboration and connectivity technology. -
Intel Core i7 processor
Run several CPU–heavy programs simultaneously without sacrificing performance with an Intel Core i7 processor. -
HP Z Turbo Drive High-speed Storage
Work without limits in any location with local PCIe storage that's up to 6x faster than SATA SSD, and up to 21x faster than traditional HDD storage. -
HP Fast Charge
Ultra-fast recharge takes you from zero to 50% charge in just 30 minutes. -
Spill-resistant Keyboard
Accidents happen - which is why we designed our keyboard with a drain hole, so minor spills flow out the bottom for easy cleanup. -
Industry-leading security features
Advanced security features come standard. System safeguards like HP Sure Start – the industry's first self-healing BIOS – mean your device is locked down tight, so your data and identity are too.
- HP ZBook Studio G7 Mobile Workstation - 15.6" - Intel Core i7 - 10750H - 16 GB RAM - 512 GB SSD - UK
- Product Type
- Mobile workstation
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i7 (10th Gen) - 10750H / 2.6 GHz, up to 5 GHz / 12 MB Cache
- Memory
- 16 GB DDR4 (provided memory is soldered)
- Storage
- 512 GB SSD - SED, TCG Opal Encryption 2, NVMe, TLC
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD
- Graphics
- NVIDIA Quadro T1000 / Intel UHD Graphics
- Video Memory
- 4 GB GDDR6 SDRAM
- Input Device
- Keyboard, ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 5.0, 802.11a/b/g/n/ac/ax
- Battery
- 6-cell - up to 18 hours
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- Turbo silver
- 35.4 cm x 23.46 cm x 1.79 cm
- 1.79 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Limited warranty - parts and labour - 3 years
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i7 (10th Gen) 10750H / 2.6 GHz
- Max Turbo Speed
- 5 GHz
- Number of Cores
- 6-core
- Cache
- 12 MB
- 64-bit Computing
- Chipset
- Mobile Intel WM490
- Hyper-Threading Technology, Intel Smart Cache, Intel Turbo Boost Max Technology 3.0, Intel Thermal Velocity Boost
- RAM
- 16 GB (provided memory is soldered)
- Technology
- DDR4 SDRAM - non-ECC
- Speed
- 2666 MHz
- Rated Speed
- 2666 MHz
Storage
- Main Storage
- 512 GB SSD M.2 2280 PCIe 3.0 x4 - Self-Encrypting Drive, TCG Opal Encryption 2, NVM Express (NVMe), triple-level cell (TLC)
Display
- 15.6" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Brightness
- 400 cd/m²
- Colour Gamut
- 72% NTSC
- Full HD ultra wide-viewing angle (UWVA) eDP anti-glare, Panel Self Refresh (PSR), Low Power, 72% NTSC colour gamut
- Keyboard Name
- HP Premium Quiet Keyboard
Audio & Video
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Processor
- Video Memory
- 4 GB GDDR6 SDRAM
- Video System Features
- Max-Q design
- Camera
- Yes - HD
- Video Resolutions
- 720p
- Camera Features
- IR camera, Temporal Noise Reduction
- Sound
- Four speakers, HP World Facing Microphone multi-array digital microphone
- High Definition Audio
- Audio Features
- Output: Bang & Olufsen Audio
Input
- Keyboard Layout
- UK
- Volume control, spill-resistant, multi-touch clickpad, gesture function, DuraKeys
Communications
- Wireless
- Wireless Controller
- Intel Wi-Fi 6 AX 201
- Miracast, dual stream (2x2)
- Technology
- 6-cell lithium polymer
- Capacity
- 83 Wh
- Run Time
- Up to 18 hours
AC Adapter
- Input
- AC 115/230 V (50/60 Hz)
- Output
- 150 Watt
Connections & Expansion
- Interfaces Details
- USB-C , Mini DisplayPort , USB 3.1 Gen 1 (charging) , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
- Software Included
- HP Performance Advisor, HP BIOSphere, Absolute Persistence, HP Device Access Manager, HP Noise Cancellation, Native Miracast, HP Connection Optimizer, HP Sure Recover, HP Manageability Integration Kit, HP Sure Sense, HP SureStart, HP ZCentral Remote Boost 2020, HP Embedded Reimaging Gen2
- Turbo silver
- Security
- Power On Authentication, HP Fast Charge, Pre-boot Authentication, Master Boot Record Security, Microsoft Security Defender, HP Sure Start Gen 5, HP Sure Sense
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- HP Smart AC Adapter
- Low halogen
- Localization
- 1.79 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt | In Stock | £109.31 |
HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt | In Stock | £138.07 |
Other bundles (4)
HP USB-C To VGA Adapter | In Stock | £22.09 |
HP USB Travel Mouse | In Stock | £9.39 |
HP USB-C to HDMI 2.0 Adapter | In Stock | £46.71 |
HP P34hc G4 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor | In Stock | £373.33 |
