HP ZBook Studio G5 Intel Core i9-8950HK 16GB 512GB SSD 15.6" Windows 10 Professional 64-bit
Quicklinx: G2G8WS00 Mfr#: 5UC04ET#ABU
  • IEEE 802.11n
Get the perfect blend of ultra-slim design & pro-grade performance in the new HP ZBook Studio. Remove limitations from your creative workflow with fast editing and rendering, and bring your ideas to life on HP's brightest 4K UHD laptop display.
  • Windows 10 Pro for Workstations
    Be productive in any situation. Windows 10 Pro and powerful security, collaboration, and connectivity features from HP help you power through your day on the HP ZBook Studio.
  • 8th gen Intel Core i9 or Intel Xeon processors
    Do more at once with next-generation 6-core Intel Core i9 or Intel Xeon processors designed to handle complex, multi-threaded applications like Adobe Premier Pro.
  • NVIDIA Quadro 3D Graphics
    Seamlessly edit your designs and render multi-layered files with certified NVIDIA Quadro P2000 graphics, optimized for stability and performance with professional software apps.
  • Blazing fast storage
    Create seamlessly. Save and access large files locally with up to 4 TB local NVMe storage, up to 21 times faster than standard HDD storage and six times faster than SATA SSD.
  • Large memory configurations
    Get remarkable, real time performance running multiple applications simultaneously with up to 64 GB RAM.
  • Fast charging and long battery life
    Take your work on the road with up to 16 hours of battery life for maximum productivity. When you need it, recharge ultra-fast (50% in just 45 minutes).
HP ZBook Studio G5 Mobile Workstation - 15.6" - Intel Core i9 - 8950HK - 16 GB RAM - 512 GB SSD - UK
Mobile workstation
Operating System
Win 10 Pro 64-bit - English
Intel Core i9 (8th Gen) - 8950HK / 2.9 GHz, up to 4.8 GHz / 12 MB Cache
16 GB DDR4 (1 x 16 GB)
Storage
512 GB SSD - NVMe
Display
15.6" LED backlight 3840 x 2160 / Ultra HD 4K
Graphics
NVIDIA Quadro P2000 / Intel UHD Graphics 630
Video Memory
4 GB GDDR5 SDRAM
Input Device
Keyboard, ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 5.0
6-cell
Ambient light sensor
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
36 cm x 25.4 cm x 1.74 cm
2 kg
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Mobile workstation
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i9 (8th Gen) 8950HK / 2.9 GHz
Max Turbo Speed
4.8 GHz
Number of Cores
6-core
Cache
12 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
16 GB (1 x 16 GB)
Max RAM Supported
64 GB
DDR4 SDRAM
Speed
2666 MHz
Rated Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
512 GB SSD M.2 2280 PCIe - NVM Express (NVMe)
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Resolution
3840 x 2160 (Ultra HD 4K)
Widescreen
Image Brightness
400 cd/m²
Ultra HD 4K eDP anti-glare
Keyboard Name
HP Collaboration
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
4 GB GDDR5 SDRAM
Camera
Yes - HD
Video Resolutions
720p
Camera Features
IR camera
Sound
Four speakers, dual array microphone
High Definition Audio
Audio Features
Output: Bang & Olufsen Audio, HP Clear Sound Amp
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
Volume control, spill-resistant, multi-touch clickpad, gesture function
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Wireless-AC 9560 - PCI Express Mini Card (M.2)
Dual stream (2x2)
IEEE 802.1x, IEEE 802.11i
6-cell lithium polymer
95.6 Wh
AC Adapter
Input
Output
150 Watt, 19.5 V
Connections & Expansion
Interfaces Details
2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort 1.3 Alt Mode) , USB 3.0 (charging) , USB 3.0 , HDMI , Headphone/microphone combo jack
Memory Card Reader
Yes (SDHC Card, SDXC Card, SDXC UHS-II Card)
Integrated Options
Security
Power-on password, One-Step Logon, Setup Password, Automatic DriveLock, BIOS Absolute Persistence, HP DriveLock, Measured Boot, Power On Authentication, Pre-boot Authentication, Secure Erase, HP Sure Start Gen 4, HP Sure Run, HP Sure Recover, BIOS Update via Network, HP Sure Click
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, FCC, RoHS, WEEE, Common Criteria EAL4+, low halogen
Localization
HP Smart Buy
2 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Essential Accessories (1)
Get more from your purchase from one of our essential accessories
G2G8 HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt In Stock £185.94
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
G2G8 HP Care Pack Next Business Day Hardware Support - extended service agreement - 3 years - on-site In Stock £124.94
Other bundles (3)
G2G8 HPE DisplayPort to VGA Adapter In Stock £13.22
G2G8 HP USB-C To VGA Adapter In Stock £23.07
G2G8 HP USB Travel Mouse In Stock £9.28
