HP Zbook Studio G4 Xeon E3-1505MV6 32GB 512GB SSD 15.6" Windows 10 Pro
Quicklinx: DWYNWS00 Mfr#: 2WT97EA#ABU
Display Size: 15.6in
Processor Model: E3-1505MV6
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 32GB
Hard Drive Capacity: 512GB
  • Xeon
  • IEEE 802.11n
£2,891.81 ex VAT
£3,470.17 inc VAT
Built for creative visionaries, the HP ZBook Studio offers desktop workstation power, in a sleek, light, stunning mobile design.
  • Stunning design
    Meticulously crafted with a fully-machined aluminum and die-cast magnesium body, diamond-cut edges and an optional stunning DreamColor UHD display. And at just 18mm thin and 1.99 kg (4.4 lbs.), you'll be prepared wherever inspiration strikes.
  • No compromise reliability
    Confidently take on your workday with our durable & reliable HP ZBook Studio. With a 3-year onsite limited warranty, 120,000 hours of testing, and 30 years of HP Z DNA this is where the fusion of innovation, performance & reliability meet.
HP ZBook Studio G4 Mobile Workstation - 15.6" - Xeon E3-1505MV6 - 32 GB RAM - 512 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Xeon E3-1505MV6 / 3 GHz (4 GHz) / 8 MB Cache
32 GB DDR4 (2 x 16 GB)
Storage
512 GB SSD
Optical Drive
No optical drive
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
NVIDIA Quadro M1200 / Intel HD Graphics P630
Video Memory
4 GB GDDR5 SDRAM
Input Device
ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
4-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
Space Silver
37.5 cm x 25.5 cm x 1.8 cm
2.09 kg
Limited warranty - parts and labour - 3 years
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
4 GHz
Number of Cores
Quad-Core
Cache
L3 - 8 MB
64-bit Computing
Chipset
Mobile Intel CM238 Express
Intel Turbo Boost Technology 2.0
RAM
32 GB (2 x 16 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - ECC
Speed
2400 MHz / PC4-19200
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
0
Storage
Main Storage
512 GB SSD - (M.2 2280) SATA 6Gb/s
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
300 cd/m²
Full HD ultra wide-viewing angle (UWVA) eDP anti-glare +PSR, 141 ppi
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
4 GB GDDR5 SDRAM
Video System Features
NVIDIA Optimus
Camera
Yes - 720p
Video Resolutions
1280x720
Frame Rate
30 frames per second
Camera Features
Low light enhancement
Sound
Stereo speakers, dual array microphone
Codec
Conexant CX7700
High Definition Audio
Audio Features
Bang & Olufsen Audio
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
Volume control, spill-resistant, gesture function
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8265 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-LM
Remote Management Protocol
SNMP 2
Wake-on-LAN (WOL)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.3az
4-cell Lithium Ion
64 Wh
AC Adapter
Input
Output
150 Watt, 19.5 V
Connections & Expansion
2 x USB 3.0 , USB 3.0 (charging) , 2 x Thunderbolt 3 , HDMI , LAN
Memory Card Reader
Yes (SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
Software Included
Skype, HP Remote Graphics Software, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Performance Advisor, Windows Defender, HP Client Security, HP Systems Software Manager (free download), HP Velocity, HP Secure Erase, CyberLink Power Media Player, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP Image Assistant, HP JumpStart, HP Noise Cancellation, HP BIOSphere Gen3, HP JetAdvantage, HP Manageability & Integration Kit (free download), HP Workwise (free download)
Space Silver
Security
Automatic DriveLock, HP DriveLock, Power On Authentication, Pre-boot Authentication, HP Sure Start Gen 3, Master Boot Record Security
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, FCC, RoHS, WEEE, Common Criteria EAL4+, low halogen
Localization
2.09 kg
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Software applications
HP Zbook Studio G4 Xeon E3-1505MV6 32GB 512GB SSD 15.6 Bundle deal on HP Zbook Studio G4 Xeon E3-1505MV6 32GB 512GB SSD 15.6" Windows 10 Pro
£3,073.97
saving £8.33
£2,990.98
Optical Storage: None
Graphics: NVIDIA Quadro M1200 / Intel HD Graphics P630
Hard Drive Type: SSD
Type: Laptop
Brand: HP
Price Range Ex VAT: 1500+
