HP ZBook Studio G10 Intel Core i7-13700H 32GB 1TB SSD 16" Windows 11 Professional
Quicklinx: HDTRWS00 Mfr#: 62V88EA#ABU
  • Core i7
  • IEEE 802.11n
Be ready when inspiration strikes. Packed with professional performance in an incredibly sleek PC that comfortably fits in your bag, the ZBook Studio is engineered to get you in the zone and help you stay focused. Now you can build complex assemblies, render in real time or visualize data-from anywhere.
  • Windows 11
    Work anywhere without compromising on performance or security with Windows 11 powered by HP's collaboration and connectivity technology.
  • Intel Core i7 processor
    Run several CPU–heavy programs simultaneously without sacrificing performance with an Intel Core i7 processor.
  • HP Z Turbo Drive High-speed Storage
    Work without limits in any location with local PCIe storage that's up to 6x faster than SATA SSD, and up to 21x faster than traditional HDD storage.
  • HP Fast Charge
    Ultra-fast recharge takes you from zero to 50% charge in just 30 minutes.
  • Spill-resistant Keyboard
    Accidents happen - which is why we designed our keyboard with a drain hole, so minor spills flow out the bottom for easy cleanup.
  • Industry-leading security features
    Advanced security features come standard. System safeguards like HP Sure Start – the industry's first self-healing BIOS – mean your device is locked down tight, so your data and identity are too.
HP ZBook Studio G10 Mobile Workstation - 16" - Intel Core i7 - 13700H - 32 GB RAM - 1 TB SSD - UK - with HP Wolf Pro Security Edition (3 years)
Mobile workstation
Operating System
Win 11 Pro - English
Intel Core i7 (13th Gen) - 13700H / 2.4 GHz, up to 5 GHz / 24 MB Cache
32 GB DDR5 (2 x 16 GB)
Storage
1 TB SSD - NVMe, TLC
Display
16" WLED 1920 x 1200 / WUXGA @ 60 Hz
Graphics
NVIDIA RTX 3000 Ada / Intel Iris Xe Graphics
Video Memory
8 GB GDDR6 SDRAM
Input Device
Keyboard, ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac/ax (Wi-Fi 6E), Bluetooth 5.3
6-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
35.6 cm x 24.2 cm x 1.9 cm
1.73 kg
Environmental Standards
TCO Certified Notebooks 9, ENERGY STAR Qualified
Bundled with
Mobile workstation
Operating System
Windows 11 Pro - English
Bundled with
Processor / Chipset
CPU
Intel Core i7 (13th Gen) 13700H / 2.4 GHz
Max Turbo Speed
5 GHz
Number of Cores
14-core
Cache
L3 - 24 MB
Hyper-Threading Technology, Intel Smart Cache, Intel Turbo Boost Max Technology 3.0
RAM
32 GB (2 x 16 GB)
Max RAM Supported
64 GB
DDR5 SDRAM - non-ECC
Speed
5600 MHz
Rated Speed
5600 MHz
SO-DIMM 262-pin
Slots Qty
2
Empty Slots
0
Storage
Main Storage
1 TB SSD M.2 2280 PCIe 4.0 x4 - NVM Express (NVMe), triple-level cell (TLC)
Display
16" - IPS
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1200 (WUXGA)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Image Aspect Ratio
16:10
Image Brightness
400 cd/m²
Colour Gamut
100% sRGB
Low Blue Light technology, narrow bezel bent, WUXGA ultra wide-viewing angle (UWVA) anti-glare eDP +PSR2
Keyboard Name
HP Premium Quiet Keyboard
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
8 GB GDDR6 SDRAM
Camera
Yes - HD
Video Resolutions
720p
Camera Features
IR camera, Windows Hello
Sound
Four speakers, 2 Top Facing Microphone dual-array digital microphones
Codec
Realtek ALC3315
High Definition Audio
Audio Features
Output: Bang & Olufsen Audio, 200 Hz bass roll off
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
Multi-touch clickpad, gesture function, glass clickpad, image sensor, spill-resistant, DuraKeys
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Wi-Fi 6E AX 211 - PCI Express Mini Card (M.2)
Miracast, Wake-on-LAN (WOL), dual stream (2x2), MU-MIMO, CNVi
Wi-Fi CERTIFIED
6-cell lithium polymer
86 Wh
AC Adapter
Input
AC 115/230 V (50/60 Hz)
Output
200 watt, 19.5 V, 21 A
Connections & Expansion
Interfaces Details
USB 3.2 Gen 1 (charging) , Headphone/microphone combo jack , 2 x USB4 (supports Thunderbolt 4, DisplayPort 1.4 Alt Mode) (Power Delivery, Sleep & Charge) , USB-C 3.2 Gen 2 (supports DisplayPort 1.4 Alt Mode) (Power Delivery)
Memory Card Reader
Yes (microSD, microSDHC, microSDXC, microSDUC)
Software
Software Included
HP Support Assistant, HP Power Manager, HP Hotkey Support, HP Performance Advisor, HP Secure Erase, HP Client Catalogue (free download), HP Client Security Manager, HP Device Access Manager, HP PC Hardware Diagnostics, HP MAC Address Manager, HP Manageability & Integration Kit (free download), HP Notifications, HP Privacy Settings, HP Cloud Recovery, HP Client Management Script Library (free download), HP BIOSphere Gen6, HP Wake on WLAN, myHP, Touchpoint Customiser for Commercial, HP Noise Cancellation Software, HP Image Assistant Gen5 (free download), HP Easy Clean, HP Smart Support, Data Science Stack, HP Connect for Microsoft Endpoint Manager, HP Patch Assistant (free download), HP Z Light Space, HP Driver Packs (free download)
Security
Automatic DriveLock, HP DriveLock, Power On Authentication, HP Fast Charge, Pre-boot Authentication, Master Boot Record Security, BIOS Update via Network, Secured-core PC enabled
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
HP 200W Slim Smart PFC AC Adapter
CSA, UL, VCCI, BSMI, GS, SABS, CCC, FCC, RoHS, KCC, A-Tick, ICES, EAC, CIT, low halogen, RED, MIL-STD-810H, BNCI
Localization
1.73 kg
Sustainability Information
TCO Certified
- TCO Certified Notebooks 9
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
HDTR HP Prelude Top Load 15.6" Notebook Carrying Case In Stock £10.26
HDTR HP Renew Business - Notebook carrying shoulder bag - 17.3" In Stock £18.95
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
HDTR HP Care Pack Next Business Day Active Care Service - extended service agreement - 3 years - on-site In Stock £141.76
Other bundles (54)
HDTR HP USB-C To VGA Adapter In Stock £23.07
HDTR HP USB-C to HDMI 2.0 Adapter In Stock £47.25
HDTR HP USB G2 Stereo Headset In Stock £20.27
HDTR HP 128 Wired Mouse In Stock £8.49
HDTR HP 455 Programmable Keyboard - Wireless - UK In Stock £46.54
HDTR HP USB-C to RJ45 Adapter G2 In Stock £13.11
HDTR HP 325 Webcam In Stock £18.90
HDTR Poly Voyager Surround 80 UC USB-C Headset + USB-C/A Adapter In Stock £208.06
HDTR Poly Voyager Surround 80 UC MS Teams Certified USB-C + USB-C/A In Stock £216.07
HDTR Poly DA75 Sound Card In Stock £27.52
HDTR Poly Voyager 4320 UC V4320-M C USB-A WW In Stock £103.25
HDTR Poly Voyager 4320 UC V4320 C USB-C WW In Stock £106.60
HDTR Poly TRIO C60 EXPANSION MICROPHONES In Stock £147.98
HDTR Poly EncorePro HW520 Stereo Headset (Noise Cancelling) In Stock £65.27
HDTR Poly DA85 Headset Cable - USB-C to Quick Disconnect In Stock £43.34
HDTR Poly EncorePro HW510 Mono Headset (N/C) In Stock £72.84
HDTR Poly Voyager 4320 UC V4320-M C USB-C WW In Stock £103.25
HDTR Poly Voyager 4320 UC V4320-M C USB-C CS WW In Stock £111.68
HDTR Poly Voyager 4320 UC V4320 C USB-A WW In Stock £103.25
HDTR Poly Voyager 4310 UC V4310 C USB-A WW In Stock £98.17
HDTR Poly EncorePro 525 USB EP525 USB-A Headset In Stock £87.21
HDTR Poly Voyager Focus 2 UC-M USB-C Headset with Stand In Stock £141.12
HDTR Poly Blackwire 8225 Stereo Microsoft Teams Certified USB-C In Stock £109.67
HDTR Poly Poly Blackwire 3320 Stereo USB-C/A Adapter In Stock £29.68
HDTR Poly Blackwire 5220 Stereo USB-C Headset + 3.5mm Plug + USB-C In Stock £68.27
HDTR Poly Blackwire 3315 headset - on-ear - wired - 3.5 mm jack, USB-C - black - UC certified In Stock £45.04
HDTR HP 724pf Series 7 Pro 23.8" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor In Stock £166.22
HDTR Poly Blackwire 3210 headset - on-ear - wired - USB-C - black In Stock £25.87
HDTR Poly Blackwire 5210 Monaural USB-C Headset +3.5mm Plug +USB-C/A Adapter In Stock £59.09
HDTR Poly Blackwire 3310 headset - on-ear - wired - USB-A - black In Stock £24.80
HDTR Poly Blackwire 3220 headset - on-ear - wired - USB-C - black In Stock £29.67
HDTR Poly Blackwire 3220 headset - on-ear - wired - USB-C - black In Stock £25.27
HDTR Poly Blackwire 3310 Monaural USB-C Headset + USB-C/A Adapter In Stock £24.80
HDTR Poly EncorePro 515-M headset - on-ear - wired - USB-A - black In Stock £77.77
HDTR HP P34hc G4 P-Series 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor In Stock £501.52
HDTR Poly EncorePro 530 headset - in-ear - wired - Quick Disconnect - black In Stock £68.08
HDTR HP 732pk Series 7 Pro 32" 3840x2160 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor In Stock £615.80
HDTR HP E24mv G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Conferencing Monitor In Stock £167.33
HDTR Poly Voyager 4310 Mono UC V4310 USB-C Microsoft Teams In Stock £108.17
HDTR HP 324pv Series 3 Pro 23.8" 1920x1080 5ms VGA HDMI LED Monitor In Stock £76.56
HDTR Poly EncorePro HW520D - headset - Quick Disconnect In Stock £105.92
HDTR Poly HP Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C In Stock £49.75
HDTR Poly HP Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C In Stock £48.40
HDTR HP 715 - mouse - multi-device, rechargeable - Bluetooth 3.0, 2.4 GHz - black In Stock £50.20
HDTR HP 524pf Series 5 Pro 24" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor In Stock £112.58
HDTR HP 524pm Series 5 Pro 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Conferencing Monitor In Stock £251.00
HDTR Poly HP Poly Blackwire 3215 - headset - 3.5 mm jack, USB-C In Stock £46.27
HDTR HP Desktop 320MK - Keyboard and mouse set - full size - USB - UK - black In Stock £15.40
HDTR Poly Blackwire 5210 - headset - 3.5 mm jack, USB-C In Stock £53.80
HDTR HP 435 - mouse - multi-device - 2.4 GHz, Bluetooth 5.2 In Stock £19.63
HDTR Poly Blackwire 3220 USB-C HS +USB-C/A Headset In Stock £26.96
HDTR Poly Blackwire 5220 USB-C HS +USB-C/A Headset In Stock £55.67
HDTR HP 320K Wired Keyboard In Stock £11.79
