HP ZBook Power G8 Intel Core i7-11800H 16GB 512GB SSD 15.6" Windows 10 Professional 64-bit
Quicklinx: GLTBWS00 Mfr#: 313S5EA#ABU
  • Core i7
  • IEEE 802.11n
Now you can upgrade to professional ZBook performance and security at an unbelievably affordable price. Power up your productivity on a durable yet premium design, with pro-grade components including graphics certified for leading software applications.
  • Windows 10 Pro 64
    Work without compromising on performance or security with Windows 10 Pro, powered by HP's collaboration and connectivity technology.
  • Intel Core i7 processor
    Run several CPU–heavy programs simultaneously without sacrificing performance with an Intel Core i7 processor.
  • 15.6" (39.6 cm) Diagonal FHD Display
    Get clear and sharp visuals in full high definition. Comfortably work without reflections on an anti-glare screen.
  • HP Z Turbo Drive High-speed Storage
    Work without limits in any location with local PCIe storage that's up to 6x faster than SATA SSD, and up to 21x faster than traditional HDD storage.
  • Spill-resistant Keyboard
    Accidents happen - which is why we designed our keyboard with a drain hole, so minor spills flow out the bottom for easy cleanup.
  • Industry-leading security features
    Advanced security features come standard. System safeguards like HP Sure Start – the industry's first self-healing BIOS – mean your device is locked down tight, so your data and identity are too.
HP ZBook Power G8 Mobile Workstation - 15.6" - Intel Core i7 11800H - 16 GB RAM - 512 GB SSD - UK
Mobile workstation
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (11th Gen) 11800H (4.6 GHz) / 24 MB Cache
16 GB DDR4 (1 x 16 GB)
Storage
512 GB SSD - NVMe, TLC
Display
15.6" WLED 1920 x 1080 / Full HD @ 60 Hz
Graphics
NVIDIA T600 / Intel UHD Graphics
Video Memory
4 GB GDDR6 SDRAM
Input Device
Keyboard, ClickPad
Keyboard
Keyboard Backlight
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac/ax, Bluetooth 5.1, Gigabit Ethernet
6-cell - up to 12 hours
Tile module, ambient light sensor, HP Tamper Lock
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
35.94 cm x 23.39 cm x 2.28 cm
1.9 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Mobile workstation
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
4.6 GHz
Number of Cores
8-core
Cache
24 MB
Chipset
Intel WM590
Intel Turbo Boost Technology
RAM
16 GB (1 x 16 GB)
Max RAM Supported
64 GB
DDR4 SDRAM - non-ECC
Speed
3200 MHz
Rated Speed
3200 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
512 GB SSD M.2 2280 PCIe 4.0 x4 - NVM Express (NVMe), triple-level cell (TLC)
Display
15.6" - IPS
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Image Aspect Ratio
16:9
Image Brightness
400 cd/m²
Colour Gamut
100% sRGB
Low Power, Full HD ultra wide-viewing angle (UWVA) eDP anti-glare +PSR2
Keyboard Name
HP Premium Quiet Keyboard
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
4 GB GDDR6 SDRAM
Camera
Yes - HD
Video Resolutions
720p
Camera Features
IR camera
Sound
Dual stereo speakers, dual array microphone
High Definition Audio
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
Numeric Keypad
Programmable buttons, volume control, spill-resistant, multi-touch clickpad, gesture function, precision touchpad, glass clickpad
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Wi-Fi 6 AX 201 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Dual stream (2x2)
6-cell lithium polymer
83 Wh
Run Time
Up to 12 hours
AC Adapter
Input
AC 115/230 V (50/60 Hz)
Output
150 Watt, 19.5 V
Connections & Expansion
Slots
1 x M.2 (PCI Express 4.0 x4) (0 free) , 1 x M.2 (PCI Express 3.0 x4) (1 free)
USB4 (supports Thunderbolt 4, DisplayPort 1.4 Alt Mode) (Power Delivery) , HDMI , USB 3.2 Gen 1 (charging) , Headphone/microphone combo jack , LAN , 2 x USB 3.2 Gen 1
Software
Software Included
HP Remote Graphics Software, HP Support Assistant, Bing Toolbar, HP Hotkey Support, HP Performance Advisor, HP Drive Packs (free download), HP Client Catalogue (free download), HP Image Assistant (free download), HP PC Hardware Diagnostics, HP Connection Optimizer, HP Privacy Settings, HP Cloud Recovery, HP Performance Advisor (free download), HP QuickDrop, HP Manageability Integration Kit Gen4 (free dowload), HP Client Management Script Library (free download), HP Wake on WLAN, HP Noise Cancellation Software, Tile, HP Easy Clean, HP Smart Support, HP ZCentral Remote Boost 2020 Software for Z workstation (free download), Adobe Creative Cloud Bundle, Data Science Stack
Case Material
ABS plastic, anodised aluminium
Integrated Options
Security
Automatic DriveLock, BIOS Absolute Persistence, HP DriveLock, BIOS Update via Network, HP Sure Click, HP Sure Sense, HP Secure Erase, HP Sure Start Gen 6, HP Sure Admin, HP Sure Run Gen 4, HP Client Security Manager Gen 7, HP BIOSphere Gen 6, HP Sure Recover Gen 4
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion sensor
Security Slot Type
Kensington nano security slot
HP 150 Watt Smart PFC Slim AC Adapter
CSA, UL, VCCI, BSMI, GOST, CCC, FCC, KCC, A-Tick, ICES, low halogen, ICCP, MIL-STD-810H, BNCI
Localization
1.9 kg
Sustainability Information
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine
Shock Tolerance (non-operating)
240 g @ 2 ms half-sine
Vibration Tolerance (operating)
1.043 g @ RMS (random)
Vibration Tolerance (non-operating)
3.5 g @ RMS (random)
Essential Accessories (3)
Get more from your purchase from one of our essential accessories
GLTB HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt In Stock £147.06
GLTB HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt In Stock £206.71
GLTB HP Travel Hub G2 Port replicator USB-C VGA, HDMI for Chromebook In Stock £41.06
Other bundles (38)
GLTB HPE HDMI to DVI Adapter In Stock £9.89
GLTB HP USB-C To VGA Adapter In Stock £22.68
GLTB HP USB Travel Mouse In Stock £10.14
GLTB HP Premium Wireless Mouse In Stock £38.00
GLTB HP USB-C to DisplayPort Adapter In Stock £23.53
GLTB HP USB-C to HDMI 2.0 Adapter In Stock £47.06
GLTB HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor In Stock £144.44
GLTB HP Z24f G3 24"1920x1080 5ms HDMI DisplayPort IPS LED Monitor In Stock £210.83
GLTB HP E24d G4 Advanced Docking Monitor 23.8" 1920x1080 HDMI DisplayPort USB-C IPS LED Monitor In Stock £381.09
GLTB HP E24u G4 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor In Stock £205.26
GLTB HP P34hc G4 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor In Stock £374.81
GLTB HP Z24n G3 24" 1920x1200 5ms HDMI DisplayPort IPS LED Monitor In Stock £223.10
GLTB HP E24M G4 Conferencing 23.8" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor In Stock £294.41
GLTB HP P24v G4 23.8" 1920x1080 5ms VGA HDMI LED Monitor In Stock £82.34
GLTB Poly Voyager Focus 2 UC-M C USB-A WW In Stock £141.00
GLTB Poly Blackwire 3320 USB-A ON-Ear Wired Headset In Stock £27.52
GLTB Poly P5 1080P HD Webcam In Stock £42.43
GLTB Poly Voyager Focus 2 UC-M USB-A with Stand In Stock £142.07
GLTB Poly EncorePro HW520 Stereo Headset (Noise Cancelling) In Stock £81.75
GLTB Poly Blackwire 3310 BW3310 USB-A Headset In Stock £23.75
GLTB Poly Blackwire 3310 BW3310-M USB-A Headset In Stock £24.43
GLTB Poly Blackwire 8225 USB-A Headset In Stock £108.79
GLTB Poly Blackwire 3325 BW3325-M USB-A Headset In Stock £47.65
GLTB Poly Blackwire 3325 BW3325-M USB-C Headset In Stock £50.09
GLTB Poly EncorePro HW510 Mono Headset (N/C) In Stock £88.92
GLTB Poly Voyager 4320 UC V4320-M C USB-A CS WW In Stock £115.37
GLTB Poly Blackwire 3325 BW3325 USB-A In Stock £44.89
GLTB Poly Sync 20 SY20-M USB-A WW In Stock £61.18
GLTB Poly Voyager 4310 UC V4310-M C USB-A CS WW In Stock £106.40
GLTB Poly Voyager Focus 2 UC USB-A Headset In Stock £134.16
GLTB Poly Voyager 4310 UC V4310 C USB-A CS WW In Stock £106.40
GLTB Poly Sync 10 SY10-M USB-A/C WW In Stock £52.73
GLTB Poly EncorePro 525 USB EP525 USB-A Headset In Stock £86.88
GLTB Poly EncorePro HW510 Mono Headset (VT) In Stock £72.63
GLTB Poly Voyager Focus 2 UC-M USB-C Headset with Stand In Stock £142.42
GLTB Poly Sync 40 SY40-M WW In Stock £121.55
GLTB Poly EncorePro 525 USB EP525-M USB-A Headset In Stock £88.93
GLTB Poly Voyager Focus 2 UC USB-A Headset with Stand In Stock £142.42
