Now you can upgrade to professional ZBook performance and security at an unbelievably affordable price. Power up your productivity on a durable yet premium design, with pro-grade components including graphics certified for leading software applications.
Windows 10 Pro 64
Work without compromising on performance or security with Windows 10 Pro, powered by HP's collaboration and connectivity technology. -
Intel Core i7 processor
Run several CPU–heavy programs simultaneously without sacrificing performance with an Intel Core i7 processor. -
NVIDIA Quadro P620 graphics card
Get stable, reliable performance on professional workflows that require you to create complex 2D and 3D models with NVIDIA Quadro P620 graphics. -
HP Collaboration Keyboard
Launch and manage calls from anywhere using Skype with HP Noise Cancellation and the world-facing third microphone. Shortcut keys, including start/stop call, calendar and screen share, enable efficient and effective collaboration. -
Spill-resistant Keyboard
Accidents happen - which is why we designed our keyboard with a drain hole, so minor spills flow out the bottom for easy cleanup. -
Industry-leading security features
Advanced security features come standard. System safeguards like HP Sure Start – the industry's first self-healing BIOS – mean your device is locked down tight, so your data and identity are too.
- HP ZBook Power G7 Mobile Workstation - 15.6" - Intel Core i7 10750H - 16 GB RAM - 512 GB SSD - UK
- Product Type
- Mobile workstation
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i7 (10th Gen) 10750H / 2.6 GHz (5 GHz) / 12 MB Cache
- Memory
- 16 GB DDR4 (1 x 16 GB)
- Storage
- 512 GB SSD - NVMe, TLC
- Display
- 15.6" WLED 1920 x 1080 / Full HD
- Graphics
- NVIDIA Quadro P620 / Intel UHD Graphics
- Video Memory
- 4 GB GDDR5 SDRAM
- Input Device
- Keyboard, ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- Bluetooth 5.0, 802.11a/b/g/n/ac/ax, Gigabit Ethernet
- Battery
- 6-cell
- Ambient light sensor
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- 35.94 cm x 23.39 cm x 2.28 cm
- 1.89 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 5 GHz
- Number of Cores
- 6-core
- Cache
- L3 - 12 MB
- 64-bit Computing
- Chipset
- Mobile Intel WM490
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 16 GB (1 x 16 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR4 SDRAM
- Speed
- 2933 MHz
- Rated Speed
- 3200 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 512 GB SSD M.2 2280 PCIe 3.0 x4 - NVM Express (NVMe), triple-level cell (TLC)
Display
- 15.6" - IPS
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Brightness
- 250 cd/m²
- Colour Gamut
- 45% NTSC
- Full HD ultra wide-viewing angle (UWVA) eDP anti-glare
- Keyboard Name
- HP Premium Quiet Keyboard
Audio & Video
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Processor
- Video Memory
- 4 GB GDDR5 SDRAM
- Camera
- Yes - HD
- Video Resolutions
- 720p
- Camera Features
- IR camera, Windows Hello
- Sound
- Stereo speakers, dual array microphone
- High Definition Audio
Input
- Keyboard Layout
- UK
- Numeric Keypad
- Volume control, spill-resistant, multi-touch clickpad, gesture function, precision touchpad, glass clickpad
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Wi-Fi 6 AX 201 - PCI Express Mini Card (M.2)
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-V
- Miracast, dual stream (2x2), MU-MIMO, CNVi
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.11d, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11k, IEEE 802.11r, IEEE 802.11v
- Technology
- 6-cell lithium polymer
- Capacity
- 83 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 120 Watt, 19.5 V
Connections & Expansion
- USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort 1.2 Alt Mode) (BC1.2 charging) , HDMI , USB 3.1 Gen 1 (charging) , Headphone/microphone combo jack , LAN , 2 x USB 3.1 Gen 1
Software
- Software Included
- HP Support Assistant, Bing Toolbar, HP Hotkey Support, HP Performance Advisor, HP Secure Erase, HP Client Security Manager, HP Device Access Manager, HP Noise Cancellation, Native Miracast, HP Manageability & Integration Kit (free download), HP Connection Optimizer, HP BIOSphere Gen6, HP ZCentral Remote Boost
- Case Material
- ABS plastic, anodised aluminium
- Integrated Options
- Security
- Intel Active Management Technology (iAMT), HP DuraKeys, Power On Authentication, HP Fast Charge, Pre-boot Authentication, Master Boot Record Security, Microsoft Security Defender, MIL-STD-810H tested
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- HP Smart AC Adapter
- CSA, UL, VCCI, BSMI, SABS, CCC, FCC, RoHS, KCC, A-Tick, ICES, low halogen, ICCP
- Localization
- 1.89 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
Essential Accessories (4)
Get more from your purchase from one of our essential accessories
HP Power Connector Adaptor DC Jack 7.4mm (F) To DC Jack | In Stock | £13.44 |
HP USB-C mini Dock - Docking Station - USB-C - VGA, HDMI - GigE | In Stock | £33.61 |
HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt | In Stock | £147.06 |
HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt | In Stock | £206.71 |
Other bundles (11)
HPE HDMI to DVI Adapter | In Stock | £9.89 |
HP USB-C To VGA Adapter | In Stock | £22.68 |
HP USB Travel Mouse | In Stock | £10.14 |
HP X4000b Bluetooth Mouse | In Stock | £28.71 |
APC Smart-UPS SMC1000IC - UPS - AC 220/230/240 V - 600 Watt | In Stock | £438.36 |
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
HP Premium Wireless Mouse | In Stock | £38.00 |
HP USB-C to DisplayPort Adapter | In Stock | £23.53 |
APC BACK-UPS BE650G2-UK 650VA 230V | In Stock | £99.31 |
APC BACK-UPS BE850G2-UK 850VA 230V USB | In Stock | £110.10 |
HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor | In Stock | £144.44 |
