HP's thinnest and most powerful 17" performance mobile workstation packs the relentless power of our ultimate ZBook into a dramatically smaller design. Create, render, edit, and simulate with ease. Visualize complex datasets in the field. Incredible performance has never been so portable.
Windows 10 Pro for Workstations 64
Work without compromising on performance or security with Windows 10 Pro for Workstations, powered by HP's collaboration and connectivity technology. -
Intel Core i7 processor
Run several CPU–heavy programs simultaneously without sacrificing performance with an Intel Core i7 processor. -
HP Z Turbo Drive High-speed Storage
Work without limits in any location with local PCIe storage that's up to 6x faster than SATA SSD, and up to 21x faster than traditional HDD storage. -
Spill-resistant Keyboard
Accidents happen - which is why we designed our keyboard with a drain hole, so minor spills flow out the bottom for easy cleanup. -
Industry-leading security features
Advanced security features come standard. System safeguards like HP Sure Start – the industry's first self-healing BIOS – mean your device is locked down tight, so your data and identity are too.
- HP ZBook Fury 17 G7 Mobile Workstation - 17.3" - Intel Core i7 - 10750H - 32 GB RAM - 512 GB SSD - UK
- Product Type
- Mobile workstation
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i7 (10th Gen) - 10750H / 2.6 GHz, up to 5 GHz / 12 MB Cache
- Memory
- 32 GB DDR4 (1 x 32 GB)
- Storage
- 512 GB SSD - NVMe
- Display
- 17.3" WLED 1920 x 1080 / Full HD
- Graphics
- NVIDIA Quadro T2000 / Intel UHD Graphics
- Video Memory
- 4 GB GDDR6 SDRAM
- Input Device
- Keyboard, touchpad, pointing stick
- Keyboard
- UK
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- Bluetooth 5.0, 802.11a/b/g/n/ac/ax, Gigabit Ethernet
- Battery
- 8-cell - up to 15.75 hours
- Ambient light sensor
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- 39.84 cm x 26.71 cm x 2.69 cm
- 2.76 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i7 (10th Gen) 10750H / 2.6 GHz
- Max Turbo Speed
- 5 GHz
- Number of Cores
- 6-core
- Cache
- 12 MB
- 64-bit Computing
- Chipset
- Mobile Intel WM490
- Intel Turbo Boost Technology
- RAM
- 32 GB (1 x 32 GB)
- Max RAM Supported
- 128 GB
- Technology
- DDR4 SDRAM - non-ECC
- Speed
- 2666 MHz
- Rated Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 4
- Empty Slots
- 3
Storage
- Main Storage
- 512 GB SSD M.2 2280 PCIe - NVM Express (NVMe)
Display
- 17.3" - IPS
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Brightness
- 300 cd/m²
- Colour Gamut
- 72%
- Full HD ultra wide-viewing angle (UWVA) eDP anti-glare
- Keyboard Name
- HP Premium Quiet Keyboard
Audio & Video
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Processor
- Video Memory
- 4 GB GDDR6 SDRAM
- Camera
- Yes - HD
- Video Resolutions
- 720p
- Camera Features
- IR camera
- Sound
- Stereo speakers, HP World Facing Microphone / dual-array digital microphone
- High Definition Audio
- Audio Features
- Output: Bang & Olufsen Audio
Input
- Keyboard Layout
- UK
- Numeric Keypad
- Programmable buttons, spill-resistant, multi-touch touchpad, gesture function, precision touchpad, glass touchpad
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Wi-Fi 6 AX 201 - PCI Express Mini Card (M.2)
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-V
- Dual stream (2x2), CNVi
- IEEE 802.11d, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11k, IEEE 802.11r, IEEE 802.11v
- Technology
- 8-cell lithium polymer
- Capacity
- 94 Wh
- Run Time
- Up to 15.75 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 150 Watt, 19.5 V
Connections & Expansion
- Interfaces Details
- USB 3.1 Gen 1 (charging) , Mini DisplayPort 1.4 , 2 x USB 3.1 Gen 1 , 2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort 1.4 Alt Mode) (BC1.2 charging) , HDMI , LAN , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
- Software Included
- HP Support Assistant, Bing Toolbar, HP Hotkey Support, HP Performance Advisor, Windows Defender, HP Device Access Manager, HP Image Assistant, HP Noise Cancellation, Native Miracast, HP Connection Optimizer, HP Sure Recover, HP BIOSphere Gen5, HP Client Security Manager Gen5, HP Cloud Recovery, HP Manageability Integration Kit Gen4 (free download), HP ZCentral Remote Boost, myHP
- Integrated Options
- Security
- HP DuraKeys, Power On Authentication, Pre-boot Authentication, Master Boot Record Security, MIL-STD-810H tested
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- HP 150W Slim Smart AC Adapter
- CSA, UL, VCCI, BSMI, GOST, CCC, FIPS 140-2 Level 2, FCC, RoHS, KCC, WEEE, A-Tick, ICES, Common Criteria EAL4+, low halogen, ICCP
- Localization
- 2.76 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
Essential Accessories (3)
Get more from your purchase from one of our essential accessories
HP Keyed Cable Lock 10mm | In Stock | £26.40 |
HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt | In Stock | £110.93 |
HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt | In Stock | £140.13 |
Other bundles (3)
HP USB-C To VGA Adapter | In Stock | £22.09 |
HP USB Travel Mouse | In Stock | £9.11 |
HP USB-C to HDMI 2.0 Adapter | In Stock | £46.71 |
