The desktop-caliber performance of our ultimate ZBook now comes packed into an incredibly sleek, slim design. Create, render, edit, and simulate with ease. Visualize complex datasets on the move. Extreme power has never been so mobile.
Intel Core i7 processor
Run several CPU–heavy programs simultaneously without sacrificing performance with an Intel Core i7 processor. -
15.6" (39.6 cm) Diagonal FHD Display
Get clear and sharp visuals in full high definition. Comfortably work without reflections on an anti-glare screen. -
HP Z Turbo Drive High-speed Storage
Work without limits in any location with local PCIe storage that's up to 6x faster than SATA SSD, and up to 21x faster than traditional HDD storage. -
Spill-resistant Keyboard
Accidents happen - which is why we designed our keyboard with a drain hole, so minor spills flow out the bottom for easy cleanup. -
Industry-leading security features
Advanced security features come standard. System safeguards like HP Sure Start – the industry's first self-healing BIOS – mean your device is locked down tight, so your data and identity are too. -
HP Privacy Camera
With the HP Privacy Camera, you can easily control who and what the webcam sees by simply sliding the privacy shutter.
- HP ZBook Fury 15 G8 Mobile Workstation - 15.6" - Intel Core i7 - 11800H - 16 GB RAM - 512 GB SSD - UK
- Product Type
- Mobile workstation
- Operating System
- Win 10 Pro 64-bit (downgrade from Windows 11 Pro) + Windows 11 Pro Licence - English
- Processor
- Intel Core i7 (11th Gen) - 11800H / 2.3 GHz, up to 4.6 GHz / 24 MB Cache
- Memory
- 16 GB DDR4 (1 x 16 GB)
- Storage
- 512 GB SSD - NVMe, TLC
- Display
- 15.6" WLED 1920 x 1080 / Full HD @ 60 Hz - 141 ppi
- Graphics
- NVIDIA T1200 / Intel UHD Graphics
- Video Memory
- 4 GB GDDR6 SDRAM
- Input Device
- Keyboard, touchpad, pointing stick
- Keyboard
- UK
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac/ax, Bluetooth 5.2, Gigabit Ethernet
- Battery
- 8-cell - up to 16.25 hours
- Tile module, ambient light sensor
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- 36.1 cm x 24.25 cm x 2.595 cm
- 2.35 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition (available through downgrade rights from Windows 11 Pro) + Windows 11 Pro Licence - English
Processor / Chipset
- CPU
- Intel Core i7 (11th Gen) 11800H / 2.3 GHz
- Max Turbo Speed
- 4.6 GHz
- Number of Cores
- 8-core
- Cache
- L3 - 24 MB
- Chipset
- Intel WM590
- Intel Turbo Boost Technology
- RAM
- 16 GB (1 x 16 GB)
- Max RAM Supported
- 128 GB
- Technology
- DDR4 SDRAM - non-ECC
- Speed
- 3200 MHz
- Rated Speed
- 3200 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 4
- Empty Slots
- 3
Storage
- Main Storage
- 512 GB SSD M.2 2280 PCIe 3.0 x4 - NVM Express (NVMe), triple-level cell (TLC)
Display
- 15.6" - IPS
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1920 x 1080 (Full HD)
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen
- Pixel Density (ppi)
- 141
- Image Aspect Ratio
- 16:9
- Image Brightness
- 400 cd/m²
- Colour Gamut
- 72% NTSC
- Full HD ultra wide-viewing angle (UWVA) eDP anti-glare +PSR
- Keyboard Name
- HP Premium Quiet Keyboard
Audio & Video
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Processor
- Video Memory
- 4 GB GDDR6 SDRAM
- Camera
- Yes - HD
- Video Resolutions
- 720p
- Camera Features
- IR camera
- Sound
- Dual stereo speakers, HP World Facing Microphone / dual-array digital microphone
- High Definition Audio
- Audio Features
- Output: Bang & Olufsen Audio
Input
- Keyboard Layout
- UK
- Numeric Keypad
- Programmable buttons, spill-resistant, multi-touch touchpad, gesture function, precision touchpad, glass touchpad, DuraKeys
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Wi-Fi 6 AX 201 - PCI Express Mini Card (M.2)
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-LM
- Miracast, Wake-on-LAN (WOL), dual stream (2x2), MU-MIMO
- IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
- Technology
- 8-cell lithium polymer
- Capacity
- 94 Wh
- Run Time
- Up to 16.25 hours
AC Adapter
- Input
- AC 115/230 V (50/60 Hz)
- Output
- 150 Watt, 19.5 V
Connections & Expansion
- Interfaces Details
- USB 3.2 Gen 1 (charging) , Mini DisplayPort 1.4 , USB 3.2 Gen 1 , 2 x USB4 (supports Thunderbolt 4, DisplayPort 1.4 Alt Mode) (BC1.2 charging) , HDMI , LAN , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
- Software Included
- Windows Defender, HP Secure Erase, HP Security Manager, HP Device Access Manager, HP PC Hardware Diagnostics, HP Sure Click, HP Manageability Integration Kit, HP Sure Sense, HP Sure Recover Gen3, HP Sure Run Gen3, HP BIOSphere Gen6, HP Tamper Lock, Tile, HP Easy Clean, Absolute Persistence Module, HP Smart Support, HP ZCentral Remote Boost 2020 Software for Z workstation (free download), HP Client Security Suite Gen7, HP Sure Start Gen6
- Case Material
- Magnesium alloy, anodised aluminium
- Integrated Options
- Security
- HP DuraKeys, Pre-boot Authentication, Master Boot Record Security, HP Sure Start Gen 6, HP Sure Run Gen 3
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- HP 150 Watt Smart PFC Slim AC Adapter, M.2 carrier cage
- CSA, UL, VCCI, BSMI, GOST, CCC, FCC, RoHS, KCC, WEEE, A-Tick, ICES, Common Criteria EAL4+, low halogen, IEEE 1680, ICCP, MIL-STD-810H, BNCI
- Localization
- 2.35 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt | In Stock | £115.06 |
HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt | In Stock | £143.82 |
Other bundles (34)
HP USB-C To VGA Adapter | In Stock | £22.09 |
HP USB Travel Mouse | In Stock | £9.39 |
HP USB-C to HDMI 2.0 Adapter | In Stock | £46.71 |
HP P34hc G4 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor | In Stock | £373.33 |
Poly Voyager Focus 2 UC-M C USB-A WW | In Stock | £126.60 |
Poly Voyager Surround 80 UC USB-C Headset + USB-C/A Adapter | In Stock | £200.78 |
Poly Voyager Surround 80 UC MS Teams Certified USB-C + USB-C/A | In Stock | £197.76 |
Poly P5 1080P HD Webcam | In Stock | £36.52 |
Poly DA75 Sound Card | In Stock | £25.28 |
Poly Voyager 4320 UC V4320-M C USB-A WW | In Stock | £102.03 |
Poly Voyager 4320 UC V4320 C USB-C WW | In Stock | £105.19 |
Poly DA85-M Sound Card | In Stock | £41.81 |
Poly Blackwire C3225 USB-A Headset | In Stock | £46.33 |
Poly EncorePro HW520 Stereo Headset (Noise Cancelling) | In Stock | £64.07 |
Poly DA85 Headset Cable - USB-C to Quick Disconnect | In Stock | £41.35 |
Poly EncorePro HW510 Mono Headset (N/C) | In Stock | £66.49 |
Poly Voyager 4320 UC V4320-M C USB-A CS WW | In Stock | £108.73 |
Poly Voyager 4320 UC V4320-M C USB-C WW | In Stock | £98.60 |
Poly Voyager 4320 UC V4320 C USB-A CS WW | In Stock | £111.19 |
Poly Voyager 4310 UC V4310-M C USB-A WW | In Stock | £95.72 |
Poly Sync 20 SY20-M USB-A WW | In Stock | £42.19 |
Poly Voyager 4320 UC V4320 C USB-C CS WW | In Stock | £111.19 |
Poly Voyager 4320 UC V4320-M C USB-C CS WW | In Stock | £111.19 |
Poly Voyager 5200 UC B5200 Headset with Case | In Stock | £93.27 |
Poly Voyager 4320 UC V4320 C USB-A WW | In Stock | £93.00 |
Poly Voyager 4310 UC V4310 C USB-A CS WW | In Stock | £102.55 |
Poly Sync 10 SY10-M USB-A/C WW | In Stock | £51.60 |
Poly Voyager 5200 Headset (no case) | In Stock | £106.48 |
Poly EncorePro 525 USB EP525 USB-A Headset | In Stock | £86.00 |
Poly EncorePro HW510 Mono Headset (VT) | In Stock | £70.81 |
Poly Voyager Focus 2 UC-M USB-C Headset with Stand | In Stock | £141.12 |
Poly Sync 40 SY40-M WW | In Stock | £118.93 |
Poly EncorePro 525 USB EP525-M USB-A Headset | In Stock | £42.16 |
Poly Voyager Focus 2 UC USB-A Headset with Stand | In Stock | £143.47 |
