HP ZBook Firefly 16 G11 Intel Core Ultra 7-155H 32GB 1TB SSD 16" Windows 11 Professional
Quicklinx: HW1ZWS00 Mfr#: 98N48ET#ABU
£1,921.54 ex VAT
£2,305.84 inc VAT
Pro-level performance combines with true mobility in this amazingly sleek and powerful laptop. Stay productive wherever you're working with integrated or discrete graphics and processor, AI-enhanced webcam and audio, and a stunning display-everything you need to collaborate and manage projects anywhere.
  • Windows 11
    Work anywhere without compromising on performance or security with Windows 11 powered by HP's collaboration and connectivity technology.
  • Intel Core Ultra Processor
    Unleash productivity with a new architecture that delivers power-efficient performance for complex business workloads and is purpose-built for the next era of AI software by sending the right task to the right engine at the right time.
  • NVIDIA Graphics
    Tackle your biggest projects with an optional NVIDIA RTX A500 Laptop GPU; certified for pro apps.
  • HP Z Turbo Drive High-speed Storage
    Work without limits in any location with local PCIe storage that's up to 6x faster than SATA SSD, and up to 21x faster than traditional HDD storage.
  • HP Fast Charge
    Ultra-fast recharge takes you from zero to 50% charge in just 30 minutes.
  • Spill-resistant Keyboard
    Accidents happen - which is why we designed our keyboard with a drain hole, so minor spills flow out the bottom for easy cleanup.
HP ZBook Firefly 16 G11 Mobile Workstation - AI Ready - 16" - Intel Core Ultra 7 - 155H - 32 GB RAM - 1 TB SSD - UK - with HP Wolf Pro Security Edition (1 year)
Mobile workstation - AI Ready
Operating System
Win 11 Pro - English
Intel Core Ultra 7 (Series 1) - 155H / 1.4 GHz, up to 4.8 GHz / 24 MB Cache
32 GB DDR5 (1 x 32 GB)
Storage
1 TB SSD - NVMe
Display
16" WLED 1920 x 1200 / WUXGA @ 60 Hz
Graphics
NVIDIA RTX A500 / Intel Arc Graphics
Video Memory
4 GB GDDR6 SDRAM
Input Device
Keyboard, ClickPad
Keyboard
Keyboard Backlight
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac/ax (Wi-Fi 6E), Bluetooth 5.3
6-cell
Hall sensor, HP Tamper Lock, thermal sensor, adaptive colour sensor
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
35.87 cm x 25.13 cm x 1.92 cm
1.79 kg
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
Bundled with
Operating System
Windows 11 Pro - English
Bundled with
Processor / Chipset
CPU
Intel Core Ultra 7 (Series 1) 155H / 1.4 GHz
Max Turbo Speed
4.8 GHz
Number of Cores
16-core
Cache
L3 - 24 MB
Intel Turbo Boost Technology
RAM
32 GB (1 x 32 GB)
Max RAM Supported
64 GB
DDR5 SDRAM
Speed
2800 MHz
Rated Speed
2800 MHz
SO-DIMM 262-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
1 TB SSD PCIe - NVM Express (NVMe)
Display
16" - IPS
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1200 (WUXGA)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Image Aspect Ratio
16:10
Image Brightness
400 cd/m²
Colour Gamut
100% sRGB
Low Blue Light technology, Low Power, WUXGA ultra wide-viewing angle (UWVA) anti-glare eDP +PSR2
Keyboard Name
HP Premium Quiet Keyboard
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
4 GB GDDR6 SDRAM
Camera
Resolution
5 Megapixel
Camera Features
Privacy shutter, IR camera, HP Auto Frame
Sound
Dual stereo speakers, HP World Facing Microphone / dual-array digital microphone
Codec
Realtek ALC3315
High Definition Audio
Audio Features
Output: discrete amplifiers, Poly Studio
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
Numeric Keypad
Volume control, multi-touch clickpad, gesture function, precision touchpad, glass clickpad, spill-resistant, DuraKeys
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Wi-Fi 6E AX 211 - PCI Express Mini Card (M.2)
Miracast, dual stream (2x2), MU-MIMO, CNVi, 160 MHz Wi-Fi bandwidth
Wi-Fi CERTIFIED
6-cell lithium polymer
357 g
76 Wh
AC Adapter
Input
AC 115/230 V (50/60 Hz)
Output
100 Watt, 5 / 9 / 12 / 15 / 20 V
Connections & Expansion
Interfaces Details
2 x USB4 (supports Thunderbolt 4, DisplayPort 1.4 Alt Mode) (Power Delivery, Sleep & Charge) , USB 3.2 Gen 1 (charging) , USB 3.2 Gen 1 , HDMI , Headphone/microphone combo jack
Software
Software Included
HP Recovery Manager, HP Support Assistant, HP Power Manager, HP Hotkey Support, HP PC Hardware Diagnostics UEFI, HP Secure Erase, HP Client Catalog, HP Connection Optimizer, HP Sure Click, HP Manageability Integration Kit, HP Privacy Settings, HP Cloud Recovery, HP Sure Sense, HP QuickDrop, HP Client Management Script Library (free download), HP BIOSphere Gen6, myHP, HP Noise Cancellation Software, HP Native Miracast Support, HP Image Assistant Gen5 (free download), HP Client Security Manager Gen7, HP SureRun Gen4, HP Sure Recover with Embedded Reimaging Gen4, Microsoft Bitlocker Encryption, HP TPM Configuration Utility, HP Programmable Key, HP Touchpoint Customizer, HP Image Assistant Gen4.6, HP Smart Support, HP Connect for Microsoft Endpoint Manager, HP Patch Assistant (free download), HP Sure Start Gen6, HP PC Hardware Diagnostics Windows, HP Anyware, HP Services Scan, Bing search for IE11, HP Driver Packs (free download)
Integrated Options
Security
BIOS Absolute Persistence, HP Fast Charge, BIOS Update via Network, MIL-STD-810H tested, Secured-core PC enabled
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion sensor
Security Slot Type
Kensington nano security slot
HP 100W USB-C AC Adapter
CSA, VCCI, BSMI, GS, SABS, CCC, FIPS 140-2 Level 2, FCC, RoHS, KCC, CISPR, ICES, Common Criteria EAL4+, KC, SRRC, NCC, low halogen, UL 62368-1, ICCP, TEC, KES, Low Blue Light certified (LBL), Ukraine NSoC, EAEU Compliance, Saudi Arabian Compliance
Localization
HP Smart Buy
1.79 kg
55.2 cm x 6.9 cm x 34.5 cm
Sustainability Information
ENERGY STAR Certified
Product Recycled Content
Post-consumer recycled plastic, ocean-bound plastics, recycled metal
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine
Shock Tolerance (non-operating)
240 g @ 2 ms half-sine
Vibration Tolerance (operating)
1.043 g @ RMS (random)
Vibration Tolerance (non-operating)
3.5 g @ RMS (random)
Essential Accessories (7)
Get more from your purchase from one of our essential accessories
HW1Z HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt In Stock £116.78
HW1Z HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt In Stock £145.96
HW1Z HP USB-C TO RJ45 Adapter In Stock £187.85
HW1Z HP USB-C Power Adapter - 65 Watt In Stock £57.16
HW1Z HP USB-C LC Power Adapter - 65 Watt In Stock £15.28
HW1Z HP Renew Business - Notebook carrying shoulder bag - 17.3" In Stock £19.13
HW1Z HP USB-C 65W LAPTOP CHARGER UK In Stock £19.60
Other bundles (31)
HW1Z HP USB-C To VGA Adapter In Stock £22.09
HW1Z HP USB G2 Stereo Headset In Stock £20.44
HW1Z HP 128 Wired Mouse In Stock £8.56
HW1Z HP 455 Programmable Keyboard - Wireless - UK In Stock £26.46
HW1Z HP USB-C to RJ45 Adapter G2 In Stock £13.20
HW1Z HP 325 Webcam In Stock £19.07
HW1Z Poly Voyager Surround 80 UC USB-C Headset + USB-C/A Adapter In Stock £240.58
HW1Z Poly Blackwire 8225 Stereo Microsoft Teams Certified USB-C In Stock £92.95
HW1Z Poly Blackwire 3320 on-ear - wired - USB-C - black - Certified for Microsoft Teams, UC certified In Stock £34.67
HW1Z Poly Poly Blackwire 3320 Stereo USB-C/A Adapter In Stock £33.49
HW1Z Poly Blackwire 5220 Stereo USB-C Headset + 3.5mm Plug + USB-C In Stock £75.19
HW1Z Poly Savi 8220 headset - on-ear - DECT / Bluetooth - wireless - USB-A via Bluetooth adapter - black In Stock £191.84
HW1Z Poly Blackwire 3315 headset - on-ear - wired - 3.5 mm jack, USB-C - black - UC certified In Stock £49.32
HW1Z HP 724pf Series 7 Pro 23.8" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor In Stock £164.32
HW1Z Poly Blackwire 5210 Monaural USB-C Headset +3.5mm Plug +USB-C/A Adapter In Stock £65.77
HW1Z Poly Blackwire 3310 headset - on-ear - wired - USB-A - black In Stock £28.00
HW1Z Poly Blackwire 3220 headset - on-ear - wired - USB-C - black In Stock £31.11
HW1Z Poly Blackwire 3310 Monaural USB-C Headset + USB-C/A Adapter In Stock £28.00
HW1Z HP 125 - Mouse - wired - USB - black In Stock £6.26
HW1Z HP 732pk Series 7 Pro 32" 3840x2160 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor In Stock £825.46
HW1Z HP E24mv G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Conferencing Monitor In Stock £153.30
HW1Z HP 324pv Series 3 Pro 23.8" 1920x1080 5ms VGA HDMI LED Monitor In Stock £73.89
HW1Z HP E24m G4 23.8" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Conferencing Monitor In Stock £211.74
HW1Z Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C In Stock £54.64
HW1Z HP 715 - mouse - multi-device, rechargeable - Bluetooth 3.0, 2.4 GHz - black In Stock £51.11
HW1Z HP 524pf Series 5 Pro 24" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor In Stock £110.29
HW1Z HP E27 G5 27" 1920x1080 5ms HDMI DisplayPort USB IPS LED Monitor In Stock £127.93
HW1Z HP 324ph Series 3 Pro 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £86.02
HW1Z HP 524pm Series 5 Pro 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Conferencing Monitor In Stock £242.62
Brand: HP
Price Range Ex VAT: £1500+
