Our lightest 15" ZBook provides true mobility for people who push the typical business PC past its breaking point. In the office or in the field, with pro-level performance and a full-size numeric keypad, you have everything to review work and manage projects from anywhere.
Windows 11
Work anywhere without compromising on performance or security with Windows 11 powered by HP's collaboration and connectivity technology. -
Intel Core i7 processor
Run several CPU–heavy programs simultaneously without sacrificing performance with an Intel Core i7 processor. -
15.6" (39.6 cm) Diagonal FHD Display
Get clear and sharp visuals in full high definition. Comfortably work without reflections on an anti-glare screen. -
HP Z Turbo Drive High-speed Storage
Work without limits in any location with local PCIe storage that's up to 6x faster than SATA SSD, and up to 21x faster than traditional HDD storage. -
HP Fast Charge
Ultra-fast recharge takes you from zero to 50% charge in just 30 minutes. -
Spill-resistant Keyboard
Accidents happen - which is why we designed our keyboard with a drain hole, so minor spills flow out the bottom for easy cleanup.
- HP ZBook Firefly 15 G8 Mobile Workstation - 15.6" - Intel Core i7 - 1165G7 - 16 GB RAM - 512 GB SSD - UK
- Product Type
- Mobile workstation
- Operating System
- Win 10 Pro 64-bit (downgrade from Windows 11 Pro) + Windows 11 Pro Licence - English
- Processor
- Intel Core i7 (11th Gen) - 1165G7 / 2.8 GHz, up to 4.7 GHz / 12 MB Cache
- Memory
- 16 GB DDR4 (1 x 16 GB)
- Storage
- 512 GB SSD - NVMe, TLC
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD @ 60 Hz - 141.21 ppi
- Graphics
- NVIDIA T500 / Intel Iris Xe Graphics
- Video Memory
- 4 GB GDDR6 SDRAM
- Input Device
- Keyboard, ClickPad, dual point stick
- Keyboard
- UK
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac/ax, Bluetooth 5.2
- Battery
- 3-cell - up to 14 hours
- Ambient light sensor, HP Tamper Lock
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- 35.95 cm x 23.36 cm x 1.92 cm
- 1.75 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition (available through downgrade rights from Windows 11 Pro) + Windows 11 Pro Licence - English
Processor / Chipset
- CPU
- Intel Core i7 (11th Gen) 1165G7 / 2.8 GHz
- Max Turbo Speed
- 4.7 GHz
- Number of Cores
- Quad-Core
- Cache
- L3 - 12 MB
- Intel Turbo Boost Technology
- RAM
- 16 GB (1 x 16 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR4 SDRAM - non-ECC
- Speed
- 3200 MHz
- Rated Speed
- 3200 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 512 GB SSD M.2 2280 PCIe 3.0 x4 - NVM Express (NVMe), triple-level cell (TLC)
Display
- 15.6" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen
- Pixel Density (ppi)
- 141.21
- Image Brightness
- 400 cd/m²
- Colour Gamut
- 100% sRGB, 72% NTSC
- Full HD ultra wide-viewing angle (UWVA) eDP anti-glare, Low Power
- Keyboard Name
- HP Premium Quiet Keyboard
Audio & Video
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Processor
- NVIDIA T500 / Intel Iris Xe Graphics - up to
- Video Memory
- 4 GB GDDR6 SDRAM
- Camera
- Yes - HD
- Video Resolutions
- 720p
- Camera Features
- Privacy shutter, IR camera, Windows Hello
- Sound
- Dual stereo speakers, HP World Facing Microphone / dual-array digital microphone
- High Definition Audio
- Audio Features
- Output: Bang & Olufsen Audio
Input
- Keyboard Layout
- UK
- Numeric Keypad
- Multi-touch clickpad, gesture function, precision touchpad, glass clickpad, image sensor, spill-resistant, DuraKeys
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Wi-Fi 6 AX 201 - PCI Express Mini Card (M.2)
- Miracast, dual stream (2x2), MU-MIMO, CNVi
- IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED 6
- Technology
- 3-cell lithium polymer
- Capacity
- 56 Wh
- Run Time
- Up to 14 hours
AC Adapter
- Input
- AC 115/230 V (50/60 Hz)
- Output
- 65 Watt, 19.5 V, 11 A
Connections & Expansion
- Interfaces Details
- USB 3.1 Gen 1 , HDMI , 2 x USB4 (supports Thunderbolt 4, DisplayPort 1.4 Alt Mode) (Power Delivery, Sleep & Charge) , USB 3.1 Gen 1 (charging) , Headphone/microphone combo jack
Software
- Software Included
- HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP Hotkey Support, HP Performance Advisor, HP PC Hardware Diagnostics UEFI, HP Secure Erase, CyberLink Power Media Player, MS BitLocker, Native Miracast, HP Manageability & Integration Kit, HP Connection Optimizer, HP Sure Click, HP Privacy Settings, HP Sure Sense, HP Sure Admin, HP QuickDrop, HP WorkWell, HP BIOSphere Gen6, myHP, HP Noise Cancellation Software, HP ZCentral Remote Boost Software, HP SureRun Gen4, HP Sure Recover with Embedded Reimaging Gen4, HP TPM Configuration Utility, HP Programmable Key, HP Touchpoint Customizer, HP Proactive Security (DaaS), HP Image Assistant Gen4.6, HP Sure Start Gen6
- Integrated Options
- Security
- HP Fast Charge, Secured-core PC capable
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), chassis intrusion sensor
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- HP 65 Watt Smart nPFC AC Adapter
- CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, KCC, WEEE, A-Tick, ICES, CIT, low halogen, IEEE 1680, ICCP, RED, MIL-STD-810H
- Localization
- 1.75 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
HP 65W Smart AC Adapter | In Stock | £17.31 |
HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt | In Stock | £115.06 |
Other bundles (4)
HP USB-C To VGA Adapter | In Stock | £22.09 |
HP USB Travel Mouse | In Stock | £9.39 |
HP USB-C to HDMI 2.0 Adapter | In Stock | £46.71 |
HP P34hc G4 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor | In Stock | £373.33 |
