Our lightest 15" ZBook provides true mobility for people who push the typical business PC past its breaking point. In the office or in the field, with pro-level performance and a full-size numeric keypad, you have everything to review work and manage projects from anywhere.
Windows 10 Pro for Workstations 64
Work without compromising on performance or security with Windows 10 Pro for Workstations, powered by HP's collaboration and connectivity technology. -
Intel Core i7 processor
Run several CPU–heavy programs simultaneously without sacrificing performance with an Intel Core i7 processor. -
15.6" (39.6 cm) Diagonal FHD Touch Display
Get clear and sharp visuals in full high definition. Comfortably work without reflections on an anti-glare touch screen. -
HP Z Turbo Drive High-speed Storage
Work without limits in any location with local PCIe storage that's up to 6x faster than SATA SSD, and up to 21x faster than traditional HDD storage. -
HP Fast Charge
Ultra-fast recharge takes you from zero to 50% charge in just 30 minutes. -
HP Collaboration Keyboard
Launch and manage calls from anywhere using Skype with HP Noise Cancellation and the world-facing third microphone. Shortcut keys, including start/stop call, calendar and screen share, enable efficient and effective collaboration.
- HP ZBook Firefly 15 G7 Mobile Workstation - 15.6" - Intel Core i7 - 10510U - 16 GB RAM - 512 GB SSD - 4G LTE-A - UK
- Product Type
- Mobile workstation
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i7 (10th Gen) - 10510U / 1.8 GHz, up to 4.9 GHz / 8 MB Cache
- Memory
- 16 GB DDR4 (2 x 8 GB)
- Storage
- 512 GB SSD - NVMe, TLC
- Display
- 15.6" WLED touchscreen 1920 x 1080 / Full HD
- Graphics
- NVIDIA Quadro P520 / Intel UHD Graphics
- Video Memory
- 4 GB GDDR5 SDRAM
- Input Device
- Keyboard, pointing stick, ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 5.0, 802.11a/b/g/n/ac/ax
- Wireless Broadband (WWAN)
- 4G LTE Advanced
- Battery
- 3-cell - up to 23 hours
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- 35.95 cm x 23.36 cm x 1.92 cm
- 1.7 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i7 (10th Gen) 10510U / 1.8 GHz
- Max Turbo Speed
- 4.9 GHz
- Number of Cores
- Quad-Core
- Cache
- L3 - 8 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 16 GB (2 x 8 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR4 SDRAM - non-ECC
- Speed
- 2666 MHz
- Rated Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 0
Storage
- Main Storage
- 512 GB SSD M.2 2280 PCIe 3.0 x4 - NVM Express (NVMe), triple-level cell (TLC)
Display
- 15.6" - IPS
- LCD Backlight Technology
- WLED backlight
- Touchscreen
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Brightness
- 250 cd/m²
- Colour Gamut
- 45% NTSC
- Full HD eDP anti-glare
- Keyboard Name
- HP Premium
Audio & Video
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Processor
- Video Memory
- 4 GB GDDR5 SDRAM
- Camera
- Yes - HD
- Camera Features
- IR camera, Windows Hello
- Sound
- Stereo speakers, HP World Facing Microphone multi-array digital microphone
- Audio Features
- Output: Bang & Olufsen Audio
Input
- Keyboard Layout
- UK
- Volume control, spill-resistant, multi-touch touchpad, ClickPad with gesture support, glass clickpad
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Wi-Fi 6 AX 201 - PCI Express Mini Card (M.2)
- Dual stream (2x2), CNVi
- IEEE 802.11d, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11k, IEEE 802.11r, IEEE 802.11v
- Generation
- 4G
- Technology
- DC-HSPA+, LTE Advanced
- Controller
- Intel XMM 7360 - M.2 3042
- Max Transfer Rate
- 450 Mbps
Navigation
- Receiver
- GPS/A-GPS
- Technology
- 3-cell lithium polymer
- Capacity
- 56 Wh
- Run Time
- Up to 23 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 5 / 9 / 12 / 15 / 20 V
Connections & Expansion
- Slots
- 1 x Nano-SIM card (1 free)
- Interfaces Details
- USB 3.1 Gen 1 , USB 3.1 Gen 1 (charging) , 2 x USB-C (supports Thunderbolt 3) , HDMI , Headphone/microphone combo jack
Software
- Software Included
- HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP Hotkey Support, HP Performance Advisor, Windows Defender, CyberLink Power Media Player, HP Device Access Manager, HP Mobile Connect Pro, HP JumpStart, HP Noise Cancellation, HP Manageability & Integration Kit (free download), HP Connection Optimizer, HP BIOSphere Gen5, HP Client Security Manager Gen5, HP ZCentral Remote Boost
- Security
- HP DuraKeys, Power On Authentication, HP Fast Charge, Pre-boot Authentication, MU-MIMO technology, Master Boot Record Security, MIL-STD-810H tested
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- USB-C power adapter
- CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, KCC, WEEE, A-Tick, ICES, CIT, low halogen, ICCP
- Localization
- 1.7 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
HP 65W Smart AC Adapter | In Stock | £17.30 |
HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt | In Stock | £185.94 |
Other bundles (3)
HP USB-C To VGA Adapter | In Stock | £23.07 |
HP USB Travel Mouse | In Stock | £9.28 |
HP USB-C to HDMI 2.0 Adapter | In Stock | £47.48 |
