HP ZBook Firefly 14 G11 Intel Core Ultra 7-155H 16GB 512GB SSD 14" Windows 11 Professional
Quicklinx: J7HNWS00 Mfr#: A3ZD4ET#ABU
£1,644.34 ex VAT
£1,973.20 inc VAT
Pro-level performance combines with true mobility in this amazingly sleek and powerful laptop. Stay productive wherever you're working with integrated or discrete graphics and processor, AI-enhanced webcam and audio, and a stunning display-everything you need to collaborate and manage projects anywhere.
  • Windows 11
    Work anywhere without compromising on performance or security with Windows 11 powered by HP's collaboration and connectivity technology.
  • Intel Core Ultra Processor
    Unleash productivity with a new architecture that delivers power-efficient performance for complex business workloads and is purpose-built for the next era of AI software by sending the right task to the right engine at the right time.
  • NVIDIA Graphics
    Tackle your biggest projects with an optional NVIDIA RTX A500 Laptop GPU; certified for pro apps.
  • HP Z Turbo Drive High-speed Storage
    Work without limits in any location with local PCIe storage that's up to 6x faster than SATA SSD, and up to 21x faster than traditional HDD storage.
  • HP Fast Charge
    Ultra-fast recharge takes you from zero to 50% charge in just 30 minutes.
  • Spill-resistant Keyboard
    Accidents happen - which is why we designed our keyboard with a drain hole, so minor spills flow out the bottom for easy cleanup.
HP ZBook Firefly 14 G11 Mobile Workstation - AI Ready - 14" - Intel Core Ultra 7 - 155H - 16 GB RAM - 512 GB SSD - UK
Mobile workstation - AI Ready
Operating System
Win 11 Pro - English
Intel Core Ultra 7 (Series 1) - 155H / 1.4 GHz, up to 4.8 GHz / 24 MB Cache
Neural Processor Unit (NPU)
Intel AI Boost
16 GB DDR5 (1 x 16 GB)
Storage
512 GB SSD - NVMe
Display
14" WLED 1920 x 1200 / WUXGA @ 60 Hz
Graphics
NVIDIA RTX A500 / Intel Arc Graphics
Video Memory
4 GB GDDR6 SDRAM
Input Device
Keyboard, ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
Microsoft Copilot
802.11a/b/g/n/ac/ax (Wi-Fi 6E), Bluetooth 5.3
3-cell
Hall sensor, HP Tamper Lock, thermal sensor, adaptive colour sensor
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
31.57 cm x 22.44 cm x 1.92 cm
1.41 kg
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified
Carbon Footprint
160 kg carbon emissions
Limited warranty - parts and labour - 1 year
Operating System
Windows 11 Pro - English
Processor / Chipset
CPU
Intel Core Ultra 7 (Series 1) 155H / 1.4 GHz
Max Turbo Speed
4.8 GHz
Number of Cores
16-core
Performance Cores
6
Efficient Cores
10
Cache
L3 - 24 MB
Intel Turbo Boost Technology
Intel AI Boost
Sparsity Support
AI Software Frameworks Supported by NPU
DirectML, OpenVINO, WindowsML, ONNX RT
Windows Studio Effects Support
RAM
16 GB (1 x 16 GB)
Max RAM Supported
64 GB
DDR5 SDRAM
Speed
2800 MHz
Rated Speed
2800 MHz
SO-DIMM 262-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
512 GB SSD PCIe - NVM Express (NVMe)
Display
14" - IPS
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1200 (WUXGA)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Image Aspect Ratio
16:10
Image Brightness
300 cd/m²
Colour Gamut
45% NTSC
Anti-glare, Micro Edge
Keyboard Name
HP Premium
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
4 GB GDDR6 SDRAM
Camera
Resolution
5 Megapixel
Camera Features
Privacy shutter, IR camera, 88° view
Sound
Dual stereo speakers, HP World Facing Microphone / dual-array digital microphone
Codec
Realtek ALC3315
High Definition Audio
Audio Features
Output: discrete amplifiers, Poly Studio
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
Volume control, multi-touch clickpad, gesture function, precision touchpad, glass clickpad, spill-resistant, DuraKeys
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Wi-Fi 6E AX 211 - PCI Express Mini Card (M.2)
Miracast, dual stream (2x2), CNVi, 160 MHz Wi-Fi bandwidth
IEEE 802.11d, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11k, IEEE 802.11r, IEEE 802.11v
3-cell lithium polymer
56 Wh
AC Adapter
Input
AC 115/230 V (50/60 Hz)
Output
100 Watt, 5 / 9 / 12 / 15 / 20 V
Connections & Expansion
Interfaces Details
2 x USB4 (supports Thunderbolt 4, DisplayPort 1.4 Alt Mode) (Power Delivery) , USB 3.2 Gen 1 (charging) , USB 3.2 Gen 1 (powered) , HDMI , Headphone/microphone combo jack
Software
Software Included
HP Recovery Manager, HP Support Assistant, HP Power Manager, HP Hotkey Support, HP PC Hardware Diagnostics UEFI, HP Secure Erase, HP Client Catalog, HP Connection Optimizer, HP Sure Click, HP Manageability Integration Kit, HP Privacy Settings, HP Cloud Recovery, HP Sure Sense, HP QuickDrop, HP Client Management Script Library (free download), HP BIOSphere Gen6, myHP, HP Noise Cancellation Software, HP Native Miracast Support, HP Image Assistant Gen5 (free download), HP Client Security Manager Gen7, HP SureRun Gen4, HP Sure Recover with Embedded Reimaging Gen4, Microsoft Bitlocker Encryption, HP TPM Configuration Utility, HP Programmable Key, HP Touchpoint Customizer, HP Image Assistant Gen4.6, HP Connect for Microsoft Endpoint Manager, HP Patch Assistant (free download), HP Sure Start Gen6, HP PC Hardware Diagnostics Windows, HP Anyware, HP Services Scan, Bing search for IE11, Battery Health Manager, HP Driver Packs (free download)
Microsoft Copilot
Integrated Options
Security
Automatic DriveLock, HP DriveLock, HP Fast Charge, BIOS Update via Network, MIL-STD-810H tested, Secured-core PC enabled
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion sensor
Security Slot Type
Kensington nano security slot
HP 100W Slim USB-C AC Adapter
CSA, VCCI, BSMI, GS, SABS, CCC, FCC, RoHS, FIPS 140-2, KCC, CISPR, ICES, KC, SRRC, NCC, low halogen, UL 62368-1, TEC, KES, Low Blue Light certified (LBL), Ukraine NSoC, EAEU Compliance, Saudi Arabian Compliance
Localization
HP Smart Buy
1.41 kg
48.3 cm x 6.9 cm x 30.5 cm
Sustainability Information
ENERGY STAR Certified
Carbon Footprint
Manufacturing (kg CO2e)
151
Logistics (kg CO2e)
4
Use (kg CO2e)
8
EOL (kg CO2e)
0.6
Total Carbon w/o Use Phase (kg CO2e)
152
Product Recycled Content
Post-consumer recycled plastic, ocean-bound plastics
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine
Shock Tolerance (non-operating)
240 g @ 2 ms half-sine
Vibration Tolerance (operating)
1.043 g @ RMS (random)
Vibration Tolerance (non-operating)
3.5 g @ RMS (random)
Essential Accessories (8)
Get more from your purchase from one of our essential accessories
J7HN HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt In Stock £116.78
J7HN HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt In Stock £145.96
J7HN HP USB-C TO RJ45 Adapter In Stock £187.85
J7HN HP USB-C Power Adapter - 65 Watt In Stock £57.16
J7HN HP Prelude Top Load 15.6" Notebook Carrying Case In Stock £10.35
J7HN HP USB-C LC Power Adapter - 65 Watt In Stock £15.28
J7HN HP Renew Business - Notebook carrying shoulder bag - 17.3" In Stock £19.13
J7HN HP USB-C 65W LAPTOP CHARGER UK In Stock £19.60
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
J7HN HP Care Pack Onsite Support - extended service agreement - 3 years - on-site In Stock £180.90
Other bundles (31)
J7HN HP USB-C To VGA Adapter In Stock £22.09
J7HN HP USB G2 Stereo Headset In Stock £20.44
J7HN HP 128 Wired Mouse In Stock £8.56
J7HN HP 455 Programmable Keyboard - Wireless - UK In Stock £26.46
J7HN HP USB-C to RJ45 Adapter G2 In Stock £13.20
J7HN HP 325 Webcam In Stock £19.07
J7HN Poly Blackwire 8225 Stereo Microsoft Teams Certified USB-C In Stock £92.95
J7HN Poly Blackwire 3320 on-ear - wired - USB-C - black - Certified for Microsoft Teams, UC certified In Stock £34.67
J7HN Poly Poly Blackwire 3320 Stereo USB-C/A Adapter In Stock £33.49
J7HN Poly Blackwire 5220 Stereo USB-C Headset + 3.5mm Plug + USB-C In Stock £75.19
J7HN Poly Savi 8220 headset - on-ear - DECT / Bluetooth - wireless - USB-A via Bluetooth adapter - black In Stock £191.84
J7HN Poly Blackwire 3315 headset - on-ear - wired - 3.5 mm jack, USB-C - black - UC certified In Stock £49.32
J7HN HP 724pf Series 7 Pro 23.8" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor In Stock £164.32
J7HN Poly Blackwire 5210 Monaural USB-C Headset +3.5mm Plug +USB-C/A Adapter In Stock £65.77
J7HN Poly Blackwire 3310 headset - on-ear - wired - USB-A - black In Stock £28.00
J7HN Poly Blackwire 3220 headset - on-ear - wired - USB-C - black In Stock £31.11
J7HN Poly Blackwire 3310 Monaural USB-C Headset + USB-C/A Adapter In Stock £28.00
J7HN HP 125 - Mouse - wired - USB - black In Stock £6.26
J7HN HP P34hc G4 P-Series 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor In Stock £320.60
J7HN HP 732pk Series 7 Pro 32" 3840x2160 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor In Stock £825.46
J7HN HP E24mv G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Conferencing Monitor In Stock £153.30
J7HN HP 324pv Series 3 Pro 23.8" 1920x1080 5ms VGA HDMI LED Monitor In Stock £73.89
J7HN HP E24m G4 23.8" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Conferencing Monitor In Stock £211.74
J7HN Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C In Stock £54.64
J7HN HP 715 - mouse - multi-device, rechargeable - Bluetooth 3.0, 2.4 GHz - black In Stock £51.11
J7HN HP 524pf Series 5 Pro 24" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor In Stock £110.29
J7HN HP E27 G5 27" 1920x1080 5ms HDMI DisplayPort USB IPS LED Monitor In Stock £127.93
J7HN HP 324ph Series 3 Pro 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £86.02
J7HN HP 524pm Series 5 Pro 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Conferencing Monitor In Stock £242.62
Brand: HP
Price Range Ex VAT: £1500+
