Create a remarkably powerful and streamlined mobile workstation workspace without the clutter with the HP ZBook Dock with Thunderbolt 3. Get expansive device, display, and network connectivity plus simultaneous charging of your system through one simple cable from the dock to your HP ZBook.
Amplify your mobile workstation
Have a lot to attach? No problem! Link up to 10 devices at once through ports that include Thunderbolt 3 (which also supports DisplayPort 1.2 and USB 3.1 Gen 2), four USB 3.0, RJ-45, VGA, combo audio, and two additional DisplayPorts. -
Charge and connect
Rapidly replenish your HP ZBook's power after a demanding day with an impressive charging station that passes power directly through a Thunderbolt 3 power cable to your HP ZBook. -
Experience an office on the go
Get stunningly easy setup on a dock that is small enough to take with you. Slip the dock into your briefcase and initiate charging, expansion, and wired networking with one cable. -
Tidy up
Proudly display this sleek and efficient solution in the office, or tuck it away and clean up your workspace for good. Either way, no more cables and no more clutter to worry about. -
Expand your view
Take multi-tasking to the extreme with support for two UHD/4K displays that are ready to broadcast every color and detail of your projects through a superfast bandwidth connection as soon as you plug into to the dock.
- HP ZBook Dock with Thunderbolt 3 - docking station - VGA, 2 x DP
- Product Type
- Docking station
- Video Interfaces
- VGA, 2 x DP
- 23 cm x 5.7 cm x 1.6 cm
- 227 g
- Localisation
- English / United Kingdom
- Power
- Power adapter 200 Watt Power Provided
- Designed For
- EliteBook 1050 G1, 850 G5; ZBook 14u G5, 15v G5, 17 G3, 17 G4, 17 G5, Studio G3, Studio G4, Studio G5, Studio x360 G5; ZBook x2
- Product Type
- Docking station
- 23 cm
- 5.7 cm
- 1.6 cm
- 227 g
- Localisation
- 4 x SuperSpeed USB 3.0 - 9 pin USB Type A , 2 x audio / video - DisplayPort - 20 pin DisplayPort , 1 x display / video - VGA - 15 pin D-Sub (DB-15) , 1 x headset / headphones / microphone - line-out/microphone - mini-phone stereo 3.5 mm , 1 x network - RJ-45 , 1 x Thunderbolt 3
- 1 USB 3.0 (powered)
- Power Device
- Power adapter
- Power Provided
- 200 Watt
- 0 °C
- 35 °C
- Designed For
- HP EliteBook 1050 G1 Notebook, 850 G5 Notebook , HP ZBook 14u G5 Mobile Workstation, 15v G5 Mobile Workstation, 17 G3 Mobile Workstation, 17 G4 Mobile Workstation, 17 G5 Mobile Workstation, Studio G3 Mobile Workstation, Studio G4 Mobile Workstation, Studio G5 Mobile Workstation, Studio x360 G5 Mobile Workstation , HP ZBook x2 G4 Detachable Workstation
