HP ZBook Create G7 Intel Core i7-10750H 16GB 512GB SSD 15.6" Windows 10 Professional 64-bit
Quicklinx: G2FJWS00 Mfr#: 118R0ET#ABU
  • Core i7
  • IEEE 802.11n
Real-time rendering. Sleek design. This device does it all. Ready for a workflow revolution? With NVIDIA GeForce graphics combined with the remarkable power of Z, pro-grade performance has never looked or felt better.
  • Windows 10 Pro 64
    Work without compromising on performance or security with Windows 10 Pro, powered by HP's collaboration and connectivity technology.
  • Intel Core i7 processor
    Run several CPU–heavy programs simultaneously without sacrificing performance with an Intel Core i7 processor.
  • HP Z Turbo Drive High-speed Storage
    Work without limits in any location with local PCIe storage that's up to 6x faster than SATA SSD, and up to 21x faster than traditional HDD storage.
  • HP Fast Charge
    Ultra-fast recharge takes you from zero to 50% charge in just 30 minutes.
  • Spill-resistant Keyboard
    Accidents happen - which is why we designed our keyboard with a drain hole, so minor spills flow out the bottom for easy cleanup.
  • Industry-leading security features
    Advanced security features come standard. System safeguards like HP Sure Start – the industry's first self-healing BIOS – mean your device is locked down tight, so your data and identity are too.
HP ZBook Create G7 Notebook - 15.6" - Intel Core i7 - 10750H - 16 GB RAM - 512 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (10th Gen) - 10750H / 2.6 GHz, up to 5 GHz / 12 MB Cache
16 GB DDR4 (provided memory is soldered)
Storage
512 GB SSD - SED, TCG Opal Encryption 2, NVMe, TLC
Display
15.6" WLED 1920 x 1080 / Full HD
Graphics
NVIDIA GeForce RTX 2070 / Intel UHD Graphics
Video Memory
8 GB GDDR6 SDRAM
Input Device
ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth 5.0, 802.11a/b/g/n/ac/ax
6-cell - up to 14 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
Turbo silver
35.4 cm x 23.46 cm x 1.79 cm
2.02 kg
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i7 (10th Gen) 10750H / 2.6 GHz
Max Turbo Speed
5 GHz
Number of Cores
6-core
Cache
L3 - 12 MB
64-bit Computing
Chipset
Mobile Intel WM490
Intel Turbo Boost Technology
RAM
16 GB (provided memory is soldered)
DDR4 SDRAM - non-ECC
Speed
2933 MHz
Rated Speed
2933 MHz
Storage
Main Storage
512 GB SSD M.2 2280 PCIe 3.0 x4 - Self-Encrypting Drive, TCG Opal Encryption 2, NVM Express (NVMe), triple-level cell (TLC)
Display
15.6" - IPS
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
400 cd/m²
Colour Gamut
100% sRGB
Anti-glare, Panel Self Refresh (PSR), Low Power
Keyboard Name
HP Premium Quiet Keyboard
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
NVIDIA GeForce RTX 2070 / Intel UHD Graphics - up to
Video Memory
8 GB GDDR6 SDRAM
Video System Features
Max-Q design
Camera
Yes - HD
Video Resolutions
720p
Camera Features
Noise reduction, IR camera, Windows Hello
Sound
Two subwoofers, two tweeters, dual array microphone
High Definition Audio
Audio Features
Output: Bang & Olufsen Audio
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-touch clickpad, gesture function, precision touchpad, glass clickpad, DuraKeys
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6 AX 201
Miracast, dual stream (2x2)
Wi-Fi CERTIFIED
6-cell lithium polymer
83 Wh
Run Time
Up to 14 hours
AC Adapter
Input
Output
200 Watt, 19.5 V
Connections & Expansion
Interfaces Details
2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3) , USB 3.1 Gen 1 (charging) , Headphone/microphone combo jack , Mini DisplayPort 1.4
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS Card)
Software
Software Included
HP Support Assistant, Bing Toolbar, HP Hotkey Support, Windows Defender, HP Secure Erase, HP Client Security Manager, HP Device Access Manager, HP Noise Cancellation, Native Miracast, HP Connection Optimizer, HP Sure Click, HP Fingerprint Sensor, HP Sure Sense, HP Image Assistant Gen4, HP Sure Recover Gen3, HP BIOSphere Gen6, HP Sure Start Gen6
Turbo silver
Security
BIOS Absolute Persistence, Power On Authentication, HP Fast Charge, Pre-boot Authentication, Master Boot Record Security
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
Power adapter
CSA, UL, VCCI, BSMI, SABS, CCC, FCC, RoHS, KCC, WEEE, A-Tick, ICES, CIT, low halogen, ICCP, AUS/NZ, MIL-STD-810H
Localization
HP Smart Buy
2.02 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
G2FJ HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt In Stock £115.06
G2FJ HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt In Stock £143.82
Other bundles (4)
G2FJ HP USB-C To VGA Adapter In Stock £22.09
G2FJ HP USB Travel Mouse In Stock £9.39
G2FJ HP USB-C to HDMI 2.0 Adapter In Stock £46.71
G2FJ HP P34hc G4 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor In Stock £373.33
