HP ZBook 17 G2 Mobile Workstation Intel Core i7 4910MQ 17.3" Windows 7 Pro
Quicklinx: CP67WS00 Mfr#: M4R75EA#ABU
  • Core i7
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
On the go creativity knows no limits with a vivid 43,94 cm (17.3") diagonal HP ZBook 17 G2. Showcase your best work in the office or on the go and take advantage of HP's most powerful processing, graphics, simple scalability, and blazing-fast connectivity to perform and collaborate at the speed of creativity.
Refuse to limit your potential
Experience the ultimate in mobile workstation performance with the HP ZBook 17 G2.
One workstation for the office and the field
At the office or on the go the 43,94 cm (17.3") diagonal HP ZBook 17 G2 provides a scalable solution to workstation computing and remains easy enough to take where work sends you.
Be color confident
What you see is what you get with the optional HP DreamColor display on the HP ZBook 17 G2.1 Maintain accurate, predictable colors that are true to the finished product and consistent across your entire digital workflow.
  • Solution confidence
    Rest easy with a ZBook 17 G2 that has ISV Certifications and has undergone 115,000 hours of the HP Total Test Process.
  • Scale up to what you need
    Customize the HP ZBook 17 G2 to meet your needs. Keep large files at your fingertips without sacrificing performance with four internal storage devices with up to 3.2 TB storage and 32 GB memory.
  • Set a new performance curve for your ZBook 17
    Handle large files, reduce work time and increase performance with the HP Z Turbo Drive.
  • The power of Thunderbolt
    Connect in a flash with 4X USB 3.0 speeds and enhance productivity with a high-performance Thunderbolt 2 port on the ZBook 17 G2.
  • Work virtually anywhere
    Access and share your workstation or server-based graphic-rich applications from any PC, thin client or Windows tablet with HP Remote Graphics Software.
  • Optimized workstation-class graphics
    Run the same demanding professional applications as a desktop workstation without dropping performance. ISV certified NVIDIA Quadro graphics options offer large GPU memory with fast bandwidth.
HP ZBook 17 G2 Mobile Workstation - 17.3" - Intel Core i7 - 4910MQ - vPro - 16 GB RAM - 256 GB SSD + 512 GB SSD - UK
Mobile workstation
Operating System
Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Platform Technology
Intel vPro Platform
Intel Core i7 (4th Gen) - 4910MQ / 2.9 GHz, up to 3.9 GHz / 8 MB Cache
16 GB DDR3L (2 x 8 GB)
Storage
256 GB SSD - HP Z Turbo Drive + 512 GB SSD
Optical Drive
DVD SuperMulti
Display
17.3" LED backlight 1920 x 1080 / Full HD
Graphics
NVIDIA Quadro K4100M / Intel HD Graphics 4600
Video Memory
4 GB GDDR5 SDRAM
Input Device
Keyboard, touchpad, pointing stick
Keyboard
Keyboard Backlight
Numeric Keypad
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
8-cell - up to 9.75 hours
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
Graphite, hematite
41.6 cm x 27.2 cm x 3.4 cm
3.46 kg
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
Mobile workstation
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Processor / Chipset
CPU
Intel Core i7 (4th Gen) 4910MQ / 2.9 GHz
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
Cache
8 MB
64-bit Computing
Chipset
Intel QM87
Platform Technology
Intel vPro Platform
Enhanced SpeedStep technology, Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
16 GB (2 x 8 GB)
Max RAM Supported
32 GB
DDR3L SDRAM
Speed
1600 MHz / PC3L-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
4
Empty Slots
2
Storage
Main Storage
256 GB SSD M.2 PCIe - HP Z Turbo Drive
Secondary Storage
512 GB SSD SATA 6Gb/s
Optical Drive
DVD±RW (±R DL) / DVD-RAM removable - tray
Display
17.3"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Full HD ultra wide-viewing angle (UWVA) anti-glare DreamColor, Multi-Stream transport (MST)
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
4 GB GDDR5 SDRAM
Video System Features
NVIDIA Optimus, Shader Model 5.0
Camera
Yes - 1280 x 720
Camera Features
720p HD movie recording, low light enhancement
Sound
Stereo speakers, two microphones
Codec
Realtek ALC3228
High Definition Audio, DTS Studio Sound, DTS SOUND+
Input
Keyboard Backlight
Keyboard Layout
Numeric Keypad
Volume control, spill-resistant, touchpad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 7260 - PCI Express Half Mini Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I217-LM
Remote Management Protocol
SNMP 2
Wake-on-LAN (WOL)
IEEE 802.3, IEEE 802.3u, IEEE 802.11, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.3az
8-cell Lithium Ion
Installed Qty
1
Max Supported Qty
2
75 Wh
Run Time
Up to 9.75 hours
AC Adapter
Input
Output
200 Watt, 19.5 V
Connections & Expansion
Expansion Bays
1 x Upgrade Bay
Slots
1 x ExpressCard/54 (1 free)
Interfaces Details
VGA , DisplayPort , Thunderbolt 2 , Headphone/microphone combo jack , LAN , 3 x USB 3.0 , USB 2.0 , Battery , Dock
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
Software Included
Drivers & Utilities, Cyberlink PowerDVD, CyberLink Power2Go, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Remote Graphics Software, HP Recovery Manager, HP Support Assistant, HP SoftPaq Download Manager (free download), HP ePrint, HP Hotkey Support, HP Performance Advisor, CyberLink YouCam BE, Foxit PhantomPDF Express, Device Access Manager with Just In Time Authentication, HP Systems Software Manager (free download), HP PageLift, HP Security Manager, Box.net 50GB storage, Drive Encryption, HP Manageability, HP Validity Fingerprint Driver, HP Client Security Manager
Graphite, hematite
Case Material
Magnesium-aluminum alloy
Dockable
Security
Security lock slot (cable lock sold separately), Intel Anti-Theft Technology (iAT), HP Disk Sanitizer, HP 3D DriveGuard, Intel Active Management Technology (iAMT), HP DuraFinish, Enhanced Pre-Boot Security, HP SpareKey, One-Step Logon, HP File Sanitizer, HP DuraCase, HP DisplaySafe, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port
Power adapter
ACPI, CSA, UL, FCC, RoHS, WEEE, Common Criteria EAL4+
Localization
3.46 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
5 °C
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
