HP ZBook 15u G6 Intel Core i5-8265U 8GB 256GB SSD 15.6" Windows 10 Professional 64-bit
Quicklinx: G2G6WS00 Mfr#: 6TP50ET#ABU
  • Core i5
  • IEEE 802.11n
Our thinnest, lightest 15" ZBook ever provides true portability for people who push their typical office computer past the breaking point. Whether in the office or out in the field, you have room to work with a large screen and full-size numeric keypad.
  • Designed for road warriors
    Weighing in at less than 1.81 kg, you get high performance without the weight. And with the latest connectivity and security features, you don't have to worry about losing your connection or compromising your valuable data when you're on the move.
  • Power user performance
    Say goodbye to slowdowns. Power through your projects and cut through your workload with 8th Gen Intel processors and 50% faster graphics than our last gen. Open large files and run multiple apps for speedy multitasking and productivity.
  • See more
    With 15 diagonal inches of screen real estate, you can work in multiple tabs and windows for maximized productivity. And with a full-size numeric keypad, you can get through data-driven tasks in no time.
HP ZBook 15u G6 Mobile Workstation - 15.6" - Intel Core i5 - 8265U - 8 GB RAM - 256 GB SSD - UK
Mobile workstation
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (8th Gen) - 8265U / 1.6 GHz, up to 3.9 GHz / 6 MB Cache
8 GB DDR4 (2 x 4 GB)
Storage
256 GB SSD - HP Z Turbo Drive, NVMe, TLC
Display
15.6" WLED 1920 x 1080 / Full HD
Graphics
AMD Radeon Pro WX 3200 / Intel UHD Graphics 620
Video Memory
4 GB GDDR5 SDRAM
Input Device
Keyboard, pointing stick, ClickPad
Keyboard
Keyboard Backlight
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 5.0, Gigabit Ethernet
3-cell - up to 14 hours
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
37.08 cm x 25.1 cm x 1.86 cm
1.77 kg
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Mobile workstation
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i5 (8th Gen) 8265U / 1.6 GHz
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
Cache
L3 - 6 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (2 x 4 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - non-ECC
Speed
2400 MHz
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
0
Storage
Main Storage
256 GB SSD M.2 2280 PCIe 3.0 x4 - HP Z Turbo Drive, NVM Express (NVMe), triple-level cell (TLC)
Display
15.6" - IPS
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
250 cd/m²
Colour Gamut
45% NTSC
Full HD eDP anti-glare
Keyboard Name
HP Collaboration
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
4 GB GDDR5 SDRAM
Camera
Yes - 720p
Camera Features
HP Privacy HD
Sound
Stereo speakers, dual array microphone
High Definition Audio
Audio Features
Output: Bang & Olufsen Audio
Input
Keyboard Backlight
Keyboard Layout
Numeric Keypad
Volume control, spill-resistant, multi-touch clickpad, gesture function, precision touchpad
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Wireless-AC 9560 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Dual stream (2x2)
IEEE 802.3ab, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
3-cell lithium polymer
56 Wh
Run Time
Up to 14 hours
AC Adapter
Input
Output
65 Watt, 19.5 V
Connections & Expansion
Interfaces Details
USB 3.1 (charging) , USB-C 3.1 (supports Thunderbolt 3) , USB 3.1 , Headphone/microphone combo jack , LAN , Dock , HDMI
Software
Software Included
Skype, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP Hotkey Support, Windows Defender, HP Secure Erase, CyberLink Power Media Player, HP Device Access Manager, HP JumpStart, HP Noise Cancellation, HP Manageability & Integration Kit (free download), HP Connection Optimizer, HP BIOSphere Gen5, HP Client Security Manager Gen5, HP Remote Graphics Software (free download), HP Performance Advisor (free download)
Case Material
Aluminum
Dockable
Security
Power On Authentication, HP Fast Charge, Pre-boot Authentication, Master Boot Record Security
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
CSA, UL, VCCI, BSMI, GOST, CCC, FCC, RoHS, KCC, WEEE, A-Tick, ICES, CIT, low halogen, ICCP
Localization
HP Smart Buy
1.77 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Essential Accessories (3)
Get more from your purchase from one of our essential accessories
G2G6 HP 65W Smart AC Adapter In Stock £16.89
G2G6 HP Keyed Cable Lock 10mm In Stock £26.40
G2G6 HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt In Stock £109.31
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
G2G6 HP Care Pack Next Business Day Hardware Support - extended service agreement - 3 years - on-site In Stock £117.41
Other bundles (3)
G2G6 HP USB-C To VGA Adapter In Stock £22.09
G2G6 HP USB Travel Mouse In Stock £9.11
G2G6 HP USB-C to HDMI 2.0 Adapter In Stock £46.71
