Reimagine your creative process with a versatile laptop that gives you the latest convertible design you'll want with the pro-grade performance you need.
360-degree pro performance
Finally, a convertible laptop designed to tackle large files and run multiple apps with speed and responsiveness. Seamlessly edit or render high-res images without lag or delay, with NVIDIA Quadro graphics and 6-core Intel Xeon processors. -
Precision-crafted versatility
With our innovative 360-degree hinge, you'll get the comfort of a laptop, the convenience of a tablet and the luxury of additional modes to help you showcase your work. -
Pixel-perfect tools
Achieve remarkable inking precision with 4000 levels of pressure sensitivity and tilt with the Wacom AES pen. And with the HP DreamColor display, you'll experience one billion vibrant colors on HP's brightest 4K laptop.
- HP ZBook Studio x360 G5 Mobile Workstation - 15.6" - Core i7 8750H - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook - flip design
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i7 (8th Gen) 8750H / 2.2 GHz (4.1 GHz) / 9 MB Cache
- Memory
- 8 GB DDR4 (2 x 4 GB)
- Storage
- 256 GB SSD TLC + 16 GB SSD cache (3D Xpoint (Optane))
- Optical Drive
- No optical drive
- Display
- 15.6" LED backlight touchscreen 1920 x 1080 / Full HD
- Graphics
- NVIDIA Quadro P1000
- Video Memory
- 4 GB GDDR5 SDRAM
- Input Device
- ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Networking
- 802.11a/b/g/n/ac, Bluetooth 5.0
- Battery
- 4-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- 36 cm x 25.4 cm x 2.04 cm
- 2.22 kg
- Localisation
- Limited warranty - parts and labour - 3 years
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.1 GHz
- Number of Cores
- 6-core
- Cache
- L3 - 9 MB
- 64-bit Computing
- Chipset
- Mobile Intel CM246
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (2 x 4 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM - non-ECC
- Speed
- 2666 MHz
- Rated Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 0
Storage
- Main Storage
- 256 GB SSD - (2.5") SATA - triple-level cell (TLC)
- SSD Cache
- 16 GB 3D Xpoint (Optane)
Display
- 15.6" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Brightness
- 400 cd/m²
- Ambient light sensor, Corning Gorilla glass 4
- Keyboard Name
- HP Collaboration
Audio & Video
- Graphics Processor
- Video Memory
- 4 GB GDDR5 SDRAM
- Video System Features
- NVIDIA Optimus, Shader Model 5.0
- Sound
- Stereo speakers
- High Definition Audio
- Audio Features
- Bang & Olufsen Audio, HP Clear Sound Amp
Input
- Keyboard, ClickPad
- Keyboard Layout
- UK
- Volume control, spill-resistant, multi-gesture clickpad
Communications
- Wireless
- Wireless Controller
- Intel Wireless-AC 9560 - PCI Express Mini Card (M.2)
- IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Technology
- 4-cell lithium polymer
- Installed Qty
- 1
- Capacity
- 64 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 150 Watt, 19.5 V
Connections & Expansion
- Slots
- 2 x M.2 Card (1 free)
- 2 x USB-C 3.1 Gen 2/Thunderbolt 3/DisplayPort 1.3 , USB 3.0 (charging) , USB 3.0 , HDMI , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
- Software Included
- HP Remote Graphics Software, HP Performance Advisor, Windows Defender, Device Access Manager, HP Secure Erase, HP Security Manager, HP Drive Packs (free download), HP Client Catalog, HP BIOS Config Utility, HP Manageability & Integration Kit (free download), HP System Software Manager (free download), HP BIOSphere Gen4
- Security
- Power-on password, One-Step Logon, Setup Password, HP Automatic Drive Lock, HP DriveLock, Measured Boot, Power On Authentication, HP Fast Charge, Pre-boot Authentication, HP Sure Start Gen 4, HP Sure Recover, BIOS Update via Network, HP Sure Click
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- CSA, UL, FCC, RoHS, WEEE, Common Criteria EAL4+, low halogen
- Localization
- 2.22 kg
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
Software applications
Bundle includes:
Microsoft Office Home & Business 2019 Box Pack (Medialess, 1 PC, One Time Purchase) worth £191.49 | in stock |
£2,404.64
saving £8.33
saving £8.33
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
£2,320.65
