Reimagine your creative process with a versatile laptop that gives you the latest convertible design you'll want with the pro-grade performance you need.
Windows Pro for workstations
Be productive in any situation. Windows 10 Pro and powerful security, collaboration, and connectivity features from HP help you power through your day on the HP ZBook Studio x360. -
HP ZBook x360 Pen
Create on the go with the professional Wacom AES pen featuring 4K pressure sensitive levels, tilt and two customizable buttons. -
15.6" diagonal touch display
Take your work outdoors with the anti-glare touch display and built in ambient light sensor that dims or brightens based on your surroundings. -
Fast charging and long battery life
Take your work on the road with up to 16 hours of battery life for maximum productivity. When you need it, recharge ultra-fast (50% in just 45 minutes). -
Blazing fast storage
Create seamlessly. Save and access large files locally with up to 4TB local NVMe storage, up to 21 times faster than standard HDD storage and six times faster than SATA SSD. -
8th Gen Intel Core i9 or Intel Xeon processors
Do more at once with next-generation six-core Intel Core i9 or Intel Xeon processors designed to handle complex, multi-threaded applications like Adobe Premier Pro.
- HP ZBook Studio x360 G5 Mobile Workstation - 15.6" - Intel Core i7 - 8750H - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Mobile workstation - flip design
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i7 (8th Gen) - 8750H / 2.2 GHz, up to 4.1 GHz / 9 MB Cache
- Memory
- 8 GB DDR4 (2 x 4 GB)
- Storage
- 256 GB SSD - TLC + 16 GB SSD cache (3D Xpoint (Optane))
- Display
- 15.6" LED backlight touchscreen 1920 x 1080 / Full HD
- Graphics
- NVIDIA Quadro P1000
- Video Memory
- 4 GB GDDR5 SDRAM
- Input Device
- Keyboard, ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Networking
- 802.11a/b/g/n/ac, Bluetooth 5.0
- Battery
- 4-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- 36 cm x 25.4 cm x 2.04 cm
- 2.22 kg
- Localisation
- Manufacturer Selling Program
- HP Smart Buy
- Limited warranty - parts and labour - 3 years
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i7 (8th Gen) 8750H / 2.2 GHz
- Max Turbo Speed
- 4.1 GHz
- Number of Cores
- 6-core
- Cache
- L3 - 9 MB
- 64-bit Computing
- Chipset
- Mobile Intel CM246
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (2 x 4 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM - non-ECC
- Speed
- 2666 MHz
- Rated Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 0
Storage
- Main Storage
- 256 GB SSD 2.5" SATA - triple-level cell (TLC)
- SSD Cache
- 16 GB 3D Xpoint (Optane)
Display
- 15.6" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Brightness
- 400 cd/m²
- Ambient light sensor, Corning Gorilla glass 4
- Keyboard Name
- HP Collaboration
Audio & Video
- Graphics Processor
- Video Memory
- 4 GB GDDR5 SDRAM
- Video System Features
- NVIDIA Optimus, Shader Model 5.0
- Sound
- Stereo speakers
- High Definition Audio
- Audio Features
- Output: Bang & Olufsen Audio, HP Clear Sound Amp
Input
- Keyboard Layout
- UK
- Volume control, spill-resistant, multi-gesture clickpad
Communications
- Wireless
- Wireless Controller
- Intel Wireless-AC 9560 - PCI Express Mini Card (M.2)
- IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Technology
- 4-cell lithium polymer
- Installed Qty
- 1
- Capacity
- 64 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 150 Watt, 19.5 V
Connections & Expansion
- Slots
- 2 x M.2 Card (1 free)
- Interfaces Details
- 2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort 1.3 Alt Mode) , USB 3.0 (charging) , USB 3.0 , HDMI , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
- Software Included
- HP Remote Graphics Software, HP Performance Advisor, Windows Defender, Device Access Manager, HP Secure Erase, HP Security Manager, HP Client Catalog, HP BIOS Config Utility, HP Manageability & Integration Kit (free download), HP System Software Manager (free download), HP BIOSphere Gen4, HP Driver Packs (free download)
- Security
- Power-on password, One-Step Logon, Setup Password, HP Automatic Drive Lock, HP DriveLock, Measured Boot, Power On Authentication, HP Fast Charge, Pre-boot Authentication, HP Sure Start Gen 4, HP Sure Recover, BIOS Update via Network, HP Sure Click
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- CSA, UL, FCC, RoHS, WEEE, Common Criteria EAL4+, low halogen
- Localization
- HP Smart Buy
- 2.22 kg
Sustainability Information
- TCO Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt | In Stock | £109.31 |
HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt | In Stock | £138.07 |
Other bundles (3)
HPE DisplayPort to VGA Adapter | In Stock | £13.38 |
HP USB-C To VGA Adapter | In Stock | £22.09 |
HP USB Travel Mouse | In Stock | £9.39 |
