HP Zbook 15 Studio Core i7-8750H 8GB 256GB SSD 15" Windows 10 P
Quicklinx: DVD7WS00 Mfr#: 2ZC50ET#ABU
  • Core i7
  • IEEE 802.11n
Get the ultimate blend of design and performance in the next generation HP ZBook Studio. Speed through your work and bring your ideas to life on HP's brightest 4K laptop.
  • Windows 10 Pro for Workstations
    Be productive in any situation. Windows 10 Pro and powerful security, collaboration, and connectivity features from HP help you power through your day on the HP ZBook Studio.
  • 8th gen Intel Core i9 or Intel Xeon processors
    Do more at once with next-generation 6-core Intel Core i9 or Intel Xeon processors designed to handle complex, multi-threaded applications like Adobe Premier Pro.
  • NVIDIA Quadro 3D Graphics
    Seamlessly edit your designs and render multi-layered files with certified NVIDIA Quadro P2000 graphics, optimized for stability and performance with professional software apps.
  • Blazing fast storage
    Create seamlessly. Save and access large files locally with up to 4 TB local NVMe storage, up to 21 times faster than standard HDD storage and six times faster than SATA SSD.
  • Large memory configurations
    Get remarkable, real time performance running multiple applications simultaneously with up to 64 GB RAM.
  • Fast charging and long battery life
    Take your work on the road with up to 16 hours of battery life for maximum productivity. When you need it, recharge ultra-fast (50% in just 45 minutes).
HP ZBook Studio G5 Mobile Workstation - 15.6" - Intel Core i7 - 8750H - 8 GB RAM - 256 GB SSD - UK
Mobile workstation
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (8th Gen) - 8750H / 2.2 GHz, up to 4.1 GHz / 9 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
NVIDIA Quadro P1000 / Intel UHD Graphics 630
Video Memory
4 GB GDDR5 SDRAM
Input Device
Keyboard, ClickPad
Keyboard
Keyboard Backlight
802.11a/b/g/n/ac, Bluetooth 5.0
4-cell
Ambient light sensor
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
36 cm x 25.4 cm x 1.74 cm
2 kg
Manufacturer Selling Program
HP Smart Buy
Limited warranty - parts and labour - 3 years
Mobile workstation
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i7 (8th Gen) 8750H / 2.2 GHz
Max Turbo Speed
4.1 GHz
Number of Cores
6-core
Cache
9 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 8 GB)
DDR4 SDRAM
Speed
2666 MHz
Rated Speed
2666 MHz
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD SATA
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
400 cd/m²
Full HD eDP anti-glare
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
4 GB GDDR5 SDRAM
Sound
Stereo speakers
High Definition Audio
Audio Features
Output: Bang & Olufsen Audio
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
Volume control, spill-resistant, gesture function
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Wireless-AC 9560
IEEE 802.1x, IEEE 802.11i
4-cell Lithium Ion
64 Wh
AC Adapter
Input
Output
150 Watt, 19.5 V
Connections & Expansion
Interfaces Details
2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort 1.3 Alt Mode) , USB 3.0 (charging) , USB 3.0 , HDMI , Headphone/microphone combo jack
Memory Card Reader
Yes (SDHC Card, SDXC Card, SDXC UHS-II Card)
Integrated Options
Security
Power-on password, One-Step Logon, Setup Password, Automatic DriveLock, BIOS Absolute Persistence, HP DriveLock, Measured Boot, Power On Authentication, Pre-boot Authentication, Secure Erase, HP Sure Start Gen 4, HP Sure Run, HP Sure Recover, BIOS Update via Network, HP Sure Click
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, FCC, RoHS, WEEE, Common Criteria EAL4+, low halogen
Localization
HP Smart Buy
2 kg
Sustainability Information
TCO Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Essential Accessories (3)
Get more from your purchase from one of our essential accessories
DVD7 HP Keyed Cable Lock 10mm In Stock £26.40
DVD7 HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt In Stock £110.93
DVD7 HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt In Stock £140.13
Other bundles (3)
DVD7 HPE DisplayPort to VGA Adapter In Stock £12.98
DVD7 HP USB-C To VGA Adapter In Stock £22.09
DVD7 HP USB Travel Mouse In Stock £9.11
