HP ZBook 15 Intel Core i7-4700MQ 8GB 750GB 15.6" Windows 7 Professional 64-bit
Quicklinx: 98VHWS00 Mfr#: F0U63ET#ABU
  • Core i7
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
Unleash your creativity and break free from your desktop with a sleek HP ZBook 15 mobile workstation that keeps you productive in the field. Take advantage of powerful processing and graphics, consistent color throughout your workflow, simple scalability, and the blazing-fast connectivity your team needs to perform and collaborate at the speed of creativity.
  • Excellent sleek design
    The stylish HP ZBook 15 displays a professional image at the office, client meetings, and on the road without sacrificing the durability of a lightweight chassis.
  • Power to perform
    With Thunderbolt, professional NVIDIA Quadro 3D graphics, Intel Core i7 processor, the HP ZBook 15 redefines mobile workstation performance. And thanks to Thunderbolt technology, you'll transfer data at lightning-fast speeds with the ability to connect to high-resolution displays and high-performance data devices over a single Thunderbolt cable.
HP ZBook 15 Mobile Workstation - 15.6" - Intel Core i7 - 4700MQ - 8 GB RAM - 750 GB HDD
Mobile workstation
Operating System
Win 7 Pro 64-bit (downgrade from Windows 8 Pro) + Windows 8 Pro Licence
Intel Core i7 (4th Gen) - 4700MQ / 2.4 GHz, up to 3.4 GHz / 6 MB Cache
8 GB DDR3L
Storage
750 GB HDD / 7200 rpm
Optical Drive
DVD SuperMulti / Blu-ray
Display
15.6" LED backlight Full HD UWVA eDP anti-glare 1920 x 1080 / Full HD
Graphics
NVIDIA Quadro K1100M
Video Memory
2 GB GDDR5 SDRAM
Input Device
Keyboard, touchpad, pointing stick
Numeric Keypad
Integrated Webcam
802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
8-cell
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
Graphite, hematite
38.15 cm x 25.7 cm x 3.55 cm
2.93 kg
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years , Limited warranty - battery - 3 years
Mobile workstation
Recommended Use
Small business, corporate business
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8 Pro) + Windows 8 Pro Licence
Processor / Chipset
CPU
Intel Core i7 (4th Gen) 4700MQ / 2.4 GHz
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
Cache
L3 - 6 MB
64-bit Computing
Chipset
Intel QM87
Intel Turbo Boost Technology 2.0
RAM
8 GB
Max RAM Supported
32 GB
DDR3L SDRAM
Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
4
Storage
Main Storage
750 GB HDD SATA 3Gb/s / 7200 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM / BD-ROM removable - tray
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Full HD ultra wide-viewing angle (UWVA) eDP anti-glare, Panel Self Refresh (PSR)
Audio & Video
Graphics Processor
Video Memory
2 GB GDDR5 SDRAM
Video System Features
NVIDIA Optimus
Camera
Video Resolutions
1280 x 720
Sound
Stereo speakers, stereo microphone
Codec
IDT 92HD91
High Definition Audio, DTS Studio Sound
Input
Numeric Keypad
Volume control, spill-resistant
Communications
Wireless
Wireless Controller
Intel Centrino Advanced-N 6235
Network Interface
Gigabit Ethernet
Remote Management Protocol
SNMP 2
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ae, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.3az
8-cell Lithium Ion
Max Supported Qty
2
75 Wh
AC Adapter
Input
Output
200 Watt, 19.5 V
Connections & Expansion
Expansion Bays
1 x Upgrade Bay
Slots
1 x ExpressCard/54 (1 free)
Interfaces Details
VGA , DisplayPort , Thunderbolt , Headphone/microphone combo jack , LAN , 3 x USB 3.0 , USB 2.0 , Battery , Dock
Memory Card Reader
Yes (SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
Software Included
Cyberlink PowerDVD, CyberLink Power2Go, Adobe Flash Player, Skype, Microsoft Security Essentials, HP Remote Graphics Software, HP Recovery Manager, HP Support Assistant, HP Connection Manager, HP SoftPaq Download Manager (free download), HP Hotkey Support, PDF Complete Corporate Edition, HP Performance Advisor, HP Peak Power Manager (free download), HP Client Security, Microsoft Office 2013 (Trial), HP Systems Software Manager (free download)
Graphite, hematite
Case Material
Magnesium-aluminum alloy
Dockable
Security
Security lock slot (cable lock sold separately), Intel Anti-Theft Technology (iAT), HP DuraFinish, Enhanced Pre-Boot Security, HP SpareKey, One-Step Logon, HP DuraCase, HP DisplaySafe, USB 3.0 port power off USB charging
Power adapter
ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, RoHS, WEEE, A-Tick, ICES, KC
Localization
HP Smart Buy
2.93 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
5 °C
35 °C
10 - 90% (non-condensing)
Shock Tolerance
40 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating)
Vibration Tolerance
0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating)
