HP ZBook 15 G6 Intel Core i9-9880H 32GB 1TB SSD 15.6" Windows 10 Professional 64-bit
Quicklinx: G2FMWS00 Mfr#: 6TR57ET#ABU
  • IEEE 802.11n
Our powerhouse ZBook thrives with heavy workloads from rendering to engineering to simulation. With room to grow, it's the only machine you'll ever need.
  • Windows 10 Pro 64
    Work without compromising on performance or security with Windows 10 Pro, powered by HP's collaboration and connectivity technology.
  • Intel Core i9 processor
    Get high-end performance for intensive tasks like rendering and video editing with the Intel Core i9 processor.
  • 15.6" Diagonal FHD Display At 250 Nits
    Get clear and sharp visuals in full high definition. Comfortably work without reflections on an anti-glare screen.
  • HP Z Turbo Drive High-speed Storage
    Work without limits in any location with local PCIe storage that's up to 6x faster than SATA SSD, and up to 21x faster than traditional HDD storage.
  • Military Standard Testing
    Our ZBooks are designed for rigorous military standard testing including drop, shock and harsh environments. Now you can take your work on the road with confidence knowing your laptop was built for durability.
  • HP Collaboration Keyboard
    Launch and manage calls from anywhere using Skype with HP Noise Cancellation and the world-facing third microphone. Shortcut keys, including start/stop call, calendar and screen share, enable efficient and effective collaboration.
HP ZBook 15 G6 Mobile Workstation - 15.6" - Intel Core i9 - 9880H - vPro - 32 GB RAM - 1 TB SSD - UK
Mobile workstation
Operating System
Win 10 Pro 64-bit - English
Platform Technology
Intel vPro Platform
Intel Core i9 (9th Gen) - 9880H / 2.3 GHz, up to 4.8 GHz / 16 MB Cache
32 GB DDR4 (2 x 16 GB)
Storage
1 TB SSD - NVMe, TLC
Display
15.6" WLED 1920 x 1080 / Full HD
Graphics
NVIDIA Quadro RTX 3000 / Intel UHD Graphics 630
Video Memory
6 GB GDDR6 SDRAM
Input Device
Keyboard, pointing stick, ClickPad
Keyboard
Keyboard Backlight
Numeric Keypad
Integrated Webcam
Bluetooth 5.0, 802.11a/b/g/n/ac/ax, Gigabit Ethernet
4-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
37.6 cm x 26.4 cm x 2.6 cm
2.6 kg
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Mobile workstation
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i9 (9th Gen) 9880H / 2.3 GHz
Max Turbo Speed
4.8 GHz
Number of Cores
8-core
Cache
16 MB
64-bit Computing
Platform Technology
Intel vPro Platform
Intel Turbo Boost Technology 2.0
RAM
32 GB (2 x 16 GB)
Max RAM Supported
128 GB
DDR4 SDRAM
Speed
2666 MHz
Rated Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
4
Empty Slots
2
Storage
Main Storage
1 TB SSD M.2 2280 PCIe - NVM Express (NVMe), triple-level cell (TLC)
RAID Level
RAID 1
Display
15.6" - IPS
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
250 cd/m²
Colour Gamut
45% NTSC
Full HD ultra wide-viewing angle (UWVA) eDP anti-glare
Keyboard Name
HP Collaboration
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
6 GB GDDR6 SDRAM
Camera
Yes - Full HD
Video Resolutions
1080p
Camera Features
IR camera
Sound
Stereo speakers, dual array microphone
High Definition Audio
Audio Features
Output: Bang & Olufsen Audio, HP Clear Sound Amp
Input
Keyboard Backlight
Keyboard Layout
Numeric Keypad
Volume control, spill-resistant, ClickPad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Wi-Fi 6 AX 200 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Remote Management Protocol
SNMP 2
Miracast, Wake-on-LAN (WOL)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
4-cell lithium polymer
90 Wh
AC Adapter
Input
Output
150 Watt, 19.5 V
Connections & Expansion
Interfaces Details
LAN , USB 3.1 Gen 1 (charging) , HDMI , 2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort 1.4 Alt Mode) , Headphone/microphone combo jack , 2 x USB 3.1 Gen 1
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Security
HP DuraKeys, Automatic DriveLock, HP DriveLock, Measured Boot, Power On Authentication, Pre-boot Authentication, Master Boot Record Security, BIOS Update via Network, HP Sure Click
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
HP 150 Watt Smart Slim AC Adapter
ACPI, CSA, UL, FCC, RoHS, WEEE, Common Criteria EAL4+, low halogen
Localization
HP Smart Buy
2.6 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Essential Accessories (3)
Get more from your purchase from one of our essential accessories
G2FM HP Keyed Cable Lock 10mm In Stock £26.40
G2FM HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt In Stock £110.93
G2FM HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt In Stock £243.92
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
G2FM HP Care Pack Next Business Day Hardware Support - extended service agreement - 3 years - on-site In Stock £117.41
Other bundles (3)
G2FM HP USB-C To VGA Adapter In Stock £22.09
G2FM HP USB Travel Mouse In Stock £9.11
G2FM HP USB-C to HDMI 2.0 Adapter In Stock £46.71
