Our powerhouse ZBook thrives with heavy workloads from rendering to engineering to simulation. With room to grow, it's the only machine you'll ever need.
Windows 10 Pro 64
Work without compromising on performance or security with Windows 10 Pro, powered by HP's collaboration and connectivity technology. -
Intel Core i9 processor
Get high-end performance for intensive tasks like rendering and video editing with the Intel Core i9 processor. -
15.6" Diagonal FHD Display At 250 Nits
Get clear and sharp visuals in full high definition. Comfortably work without reflections on an anti-glare screen. -
HP Z Turbo Drive High-speed Storage
Work without limits in any location with local PCIe storage that's up to 6x faster than SATA SSD, and up to 21x faster than traditional HDD storage. -
Military Standard Testing
Our ZBooks are designed for rigorous military standard testing including drop, shock and harsh environments. Now you can take your work on the road with confidence knowing your laptop was built for durability. -
HP Collaboration Keyboard
Launch and manage calls from anywhere using Skype with HP Noise Cancellation and the world-facing third microphone. Shortcut keys, including start/stop call, calendar and screen share, enable efficient and effective collaboration.
- HP ZBook 15 G6 Mobile Workstation - 15.6" - Intel Core i9 - 9880H - vPro - 64 GB RAM - 512 GB SSD - UK
- Product Type
- Mobile workstation
- Operating System
- Win 10 Pro 64-bit - English
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core i9 (9th Gen) - 9880H / 2.3 GHz, up to 4.8 GHz / 16 MB Cache
- Memory
- 64 GB DDR4 (4 x 16 GB)
- Storage
- 512 GB SSD - NVMe, TLC + 16 GB SSD cache (PCIe (NVMe)) (3D Xpoint (Optane))
- Display
- 15.6" WLED 1920 x 1080 / Full HD
- Graphics
- NVIDIA Quadro T2000 / Intel UHD Graphics 630
- Video Memory
- 4 GB GDDR5 SDRAM
- Input Device
- Keyboard, pointing stick, ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- Bluetooth 5.0, 802.11a/b/g/n/ac/ax, Gigabit Ethernet
- Battery
- 4-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- 37.6 cm x 26.4 cm x 2.6 cm
- 2.6 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i9 (9th Gen) 9880H / 2.3 GHz
- Max Turbo Speed
- 4.8 GHz
- Number of Cores
- 8-core
- Cache
- 16 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 64 GB (4 x 16 GB)
- Max RAM Supported
- 128 GB
- Technology
- DDR4 SDRAM
- Speed
- 2666 MHz
- Rated Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 4
- Empty Slots
- 0
Storage
- Main Storage
- 512 GB SSD M.2 2280 PCIe - NVM Express (NVMe), triple-level cell (TLC)
- SSD Cache
- 16 GB 3D Xpoint (Optane) (PCIe (NVMe))
- RAID Level
- RAID 1
Display
- 15.6" - IPS
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Brightness
- 250 cd/m²
- Colour Gamut
- 45% NTSC
- Full HD ultra wide-viewing angle (UWVA) eDP anti-glare, 6-bit gamma
- Keyboard Name
- HP Collaboration
Audio & Video
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Processor
- Video Memory
- 4 GB GDDR5 SDRAM
- Camera
- Yes - HD
- Video Resolutions
- 720p
- Camera Features
- IR camera
- Sound
- Stereo speakers, dual array microphone
- High Definition Audio
- Audio Features
- Output: Bang & Olufsen Audio, HP Clear Sound Amp
Input
- Keyboard Layout
- UK
- Numeric Keypad
- Volume control, spill-resistant, ClickPad with gesture support
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Wi-Fi 6 AX 200 - PCI Express Mini Card (M.2)
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-LM
- Remote Management Protocol
- SNMP 2
- Miracast, Wake-on-LAN (WOL)
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
- Technology
- 4-cell lithium polymer
- Capacity
- 90 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 150 Watt, 19.5 V
Connections & Expansion
- Interfaces Details
- LAN , USB 3.1 Gen 1 (charging) , HDMI , 2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort 1.4 Alt Mode) , Headphone/microphone combo jack , 2 x USB 3.1 Gen 1
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
- Software Included
- Skype, HP Remote Graphics Software, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Performance Advisor, Windows Defender, Device Access Manager, HP Velocity, HP Security Manager, CyberLink Power Media Player, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP 3D DriveGuard, HP Mobile Connect Pro, HP Image Assistant, HP JumpStart, HP Sure Connect, HP Noise Cancellation, HP LAN-WLAN Protection, HP Client Security Suite Gen3, HP JetAdvantage, HP Manageability & Integration Kit (free download), HP System Software Manager (free download), HP BIOSphere Gen4, HP Host Based MAC Address Manager, HP Sure Start Gen4, HP Driver Packs (free download)
- Security
- HP DuraKeys, Automatic DriveLock, HP DriveLock, Measured Boot, Power On Authentication, Pre-boot Authentication, Master Boot Record Security, BIOS Update via Network, HP Sure Click
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- ACPI, CSA, UL, FCC, RoHS, WEEE, Common Criteria EAL4+, low halogen
- Localization
- 2.6 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
Essential Accessories (1)
Get more from your purchase from one of our essential accessories
HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt | In Stock | £184.27 |
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
HP Care Pack Next Business Day Hardware Support - extended service agreement - 3 years - on-site | In Stock | £124.94 |
Other bundles (3)
HP USB-C To VGA Adapter | In Stock | £23.07 |
HP USB Travel Mouse | In Stock | £9.23 |
HP USB-C to HDMI 2.0 Adapter | In Stock | £47.25 |
