Be productive in the office or in the field. Take advantage of the HP ZBook 15 G2's powerful processing and graphics, simple scalability, and blazing-fast connectivity to perform and collaborate at the speed of creativity.
Solution confidence
Rest easy with a ZBook 15 G2 that has ISV Certifications and has undergone 115,000 hours of the HP Total Test Process. -
Scale up to what you need
Customize the HP ZBook 15 G2 to meet your demands. Keep large files at your fingertips without sacrificing performance with three internal storage devices with up to 2.2 TB storage and 32 GB memory. -
Set a new performance curve for your ZBook 15
Handle large files, reduce work time and increase performance with the HP Z Turbo Drive. -
The power of Thunderbolt
Connect in a flash with 4X USB 3.0 speeds and enhance productivity with a high-performance Thunderbolt 2 port on the ZBook 15 G2. -
Work virtually anywhere
Access and share your workstation or server-based graphic-rich applications from any PC, thin client or Windows tablet with HP Remote Graphics Software. -
Optimized workstation-class graphics
Run the same demanding professional applications as a desktop workstation without dropping performance. ISV certified NVIDIA Quadro graphics options offer large GPU memory with fast bandwidth.
- HP ZBook 15 G2 Mobile Workstation - 15.6" - Intel Core i7 - 4710MQ - 4 GB RAM - 500 GB HDD - UK
- Product Type
- Mobile workstation
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
- Processor
- Intel Core i7 (4th Gen) - 4710MQ / 2.5 GHz, up to 3.5 GHz / 6 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 7200 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD
- Graphics
- NVIDIA Quadro K610M
- Video Memory
- 1 GB GDDR5 SDRAM
- Input Device
- Keyboard, touchpad, pointing stick
- Keyboard
- UK
- Numeric Keypad
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 8-cell
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
- Graphite, hematite
- 38.15 cm x 25.7 cm x 3.55 cm
- 2.93 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years - pick-up and return , Limited warranty - battery - 3 years
- Product Type
- Recommended Use
- Small business, corporate business
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Processor / Chipset
- CPU
- Intel Core i7 (4th Gen) 4710MQ / 2.5 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Quad-Core
- Cache
- L3 - 6 MB
- 64-bit Computing
- Chipset
- Intel QM87
- Intel Turbo Boost Technology 2.0
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 4
- Empty Slots
- 3
Storage
- Main Storage
- 500 GB HDD SATA 3Gb/s / 7200 rpm
- RAID Level
- RAID 0, RAID 1
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM removable - tray
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Full HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
- Graphics Processor
- Video Memory
- 1 GB GDDR5 SDRAM
- Video System Features
- NVIDIA Optimus, Shader Model 5.0
- Camera
- Yes - 1280 x 720
- Sound
- Stereo speakers, stereo microphone
- Codec
- IDT 92HD91
- High Definition Audio, DTS SOUND+, DTS Sound
Input
- Keyboard Layout
- UK
- Numeric Keypad
- Volume control, spill-resistant
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 7260 - PCI Express Half Mini Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I217-LM
- Remote Management Protocol
- SNMP 2
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.3az
- Technology
- 8-cell Lithium Ion
- Installed Qty
- 1
- Max Supported Qty
- 2
- Capacity
- 75 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 150 Watt, 19.5 V
Connections & Expansion
- Expansion Bays
- 1 x Upgrade Bay
- Slots
- 1 x ExpressCard/54 (1 free)
- VGA , DisplayPort , Thunderbolt 2 , Headphone/microphone combo jack , Battery , Dock , LAN , 3 x USB 3.0 , USB 2.0
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Cyberlink PowerDVD, CyberLink Power2Go, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Remote Graphics Software, HP Recovery Manager, HP Support Assistant, HP SoftPaq Download Manager (free download), HP ePrint, HP Hotkey Support, HP Performance Advisor, CyberLink YouCam BE, Foxit PhantomPDF Express, Drive Encryption for HP ProtectTools, HP Spare Key, One Step Logon, HP Client Security, Device Access Manager with Just In Time Authentication, HP Systems Software Manager (free download), HP PageLift, HP Secure Erase, HP File Sanitizer, Box.net 50GB storage, HP Manageability, HP Validity Fingerprint Driver
- Case Material
- Aluminum, magnesium alloy
- Dockable
- Security
- HP 3D DriveGuard, HP DuraFinish, HP SpareKey, One-Step Logon, HP DuraCase, HP DisplaySafe, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, FIPS 140-2, A-Tick, ICES, KC
- Localization
- 2.93 kg
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
