Be productive in the office or in the field. Take advantage of the HP ZBook 15 G2's powerful processing and graphics, simple scalability, and blazing-fast connectivity to perform and collaborate at the speed of creativity.
Work smarter
Work anywhere and be confident the power you need is at your fingertips. The ZBook 15 G2 is our most versatile mobile workstation with Windows 8.1, Intel Core i5 or i7 processors professional graphics, and lasting battery life. -
Feel the power
Take performance to a new level on HP ZBook 15 G2 with optional Quad Core CPUs, Thunderbolt 2, HP Z Turbo Drive storage, and optional QHD+ display options. -
Be professional
Look stylish and confident carrying the HP ZBook 15 G2. Project a professional image at the office, client meetings, and on the road without sacrificing durability in a lightweight chassis.
- HP ZBook 15 G2 Mobile Workstation - 15.6" - Intel Core i5 - 4340M - 4 GB RAM - 500 GB HDD - UK
- Product Type
- Mobile workstation
- Operating System
- Win 7 Pro 64-bit - English
- Processor
- Intel Core i5 (4th Gen) - 4340M / 2.9 GHz, up to 3.6 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 7200 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD
- Graphics
- NVIDIA Quadro K1100M
- Video Memory
- 2 GB GDDR5 SDRAM
- Input Device
- Keyboard, touchpad, pointing stick
- Keyboard
- UK
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 8-cell
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
- Graphite, hematite
- 38.15 cm x 25.7 cm x 3.55 cm
- 2.93 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years - pick-up and return , Limited warranty - battery - 1 year
- Product Type
- Recommended Use
- Small business, corporate business
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i5 (4th Gen) 4340M / 2.9 GHz
- Max Turbo Speed
- 3.6 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Chipset
- Intel QM87
- Intel Turbo Boost Technology 2.0
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA 1.5Gb/s / 7200 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM removable - tray
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Full HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
- Graphics Processor
- Video Memory
- 2 GB GDDR5 SDRAM
- Video System Features
- NVIDIA Optimus
- Camera
- Yes - 1280 x 720
- Sound
- Stereo speakers, stereo microphone
- Codec
- IDT 92HD91
- High Definition Audio, DTS Studio Sound
Input
- Keyboard Layout
- UK
- Numeric Keypad
- Volume control, spill-resistant
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 7260
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I217-LM
- Remote Management Protocol
- SNMP 2
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.3az
- Technology
- 8-cell Lithium Ion
- Max Supported Qty
- 2
- Capacity
- 83 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 150 Watt, 19.5 V
Connections & Expansion
- Expansion Bays
- 1 x Upgrade Bay
- Slots
- 1 x ExpressCard/54 (1 free)
- VGA , DisplayPort , Thunderbolt 2 , Headphone/microphone combo jack , LAN , 3 x USB 3.0 , USB 2.0 , Battery , Dock
- Memory Card Reader
- Yes (SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
- Software Included
- Microsoft Security Essentials, HP Remote Graphics Software, HP ePrint, HP Performance Advisor, CyberLink PowerDVD BD Edition, HP Client Security, HP PageLift, Drive Encryption
- Case Material
- Magnesium-aluminum alloy
- Dockable
- Security
- Charging via USB, HP 3D DriveGuard, HP DuraFinish, HP SpareKey, One-Step Logon, HP File Sanitizer, HP DuraCase, HP DisplaySafe, HP BIOS Protection, HP SureStart, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, FIPS 140-2, A-Tick, ICES, KC
- Localization
- 2.93 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
