HP Z640 Workstation Intel Xeon E5-2620v3 16GB 1TB Windows 7 Professional 64-bit
Quicklinx: BD4LWS00 Mfr#: G1X55EA#ABU
Processor Type: Xeon
Operating System: Microsoft Windows 7 Professional 64-bit Edition
Installed Memory: 16GB, 16GB
Hard Drive Capacity: 1TB
Storage Type: HDD
  • Xeon
  • Microsoft Windows 7 Professional 64-bit Edition
£1,541.35 ex VAT
£1,849.62 inc VAT
Redefine versatility and flexibility. Expand your capabilities with HP's Z640 Workstation offering powerful performance, whisper-quiet computing, and tool-less access in compact design.
  • Power up
    Experience massive workstation power with support for 145W processors powering up to 36 cores in a dual Intel Xeon processor configuration. The HP Z640 Workstation uses Z DNA to provide a high-end workstation experience.
  • Versatility redefined
    Build the perfect workstation for your needs. The HP Z640 Workstation featuring Windows 8.1 provides incredible expansion in a small footprint. With up to 8 memory DIMMs, up to 4 internal hard drives, optional Thunderbolt 2, and the HP Z Turbo Drive, you get storage, performance, and the freedom to create.
  • Experience the quiet
    Concentrate on your work using a workstation that is whisper quiet. When every inch, watt, and decibel makes a difference, count on the HP Z640 Workstation.
HP Workstation Z640 - MT - Xeon E5-2620V3 2.4 GHz - 16 GB - 1 TB
Workstation - mini tower
Platform Technology
Intel vPro Technology
Height (Rack Units)
4U
1 x Intel Xeon E5-2620V3 / 2.4 GHz (3.2 GHz) (6-core)
Processor Socket
LGA2011-v3 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
15 MB
Cache Per Processor
15 MB
RAM
16 GB (installed) / 256 GB (max) - DDR4 SDRAM - ECC - PC4-17000
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Card Reader
15 in 1
Graphics Controller
No graphics
Audio Output
Integrated
GigE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
Black, hematite brushed aluminium
17.15 cm x 46.48 cm x 44.45 cm
15 kg
Platform Technology
Workstation
Recommended Use
Small business, corporate business
Product Form Factor
Mini tower - 4U
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3.2 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
LGA2011-v3 Socket
Chipset Type
Intel C612
Cache Memory
Installed Size
15 MB
Cache Per Processor
15 MB
RAM
Installed Size
16 GB / 256 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
1866 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
4 (Total) / 2 (empty)
Registered
Configuration Features
2 x 8 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Channel Qty
6
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
DVD SuperMulti - SATA
Card Reader
15 in 1 card reader
Supported Flash Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, Microdrive, SD Memory Card, Memory Stick Duo, Memory Stick PRO Duo, SDHC Memory Card, Memory Stick PRO-HG Duo, SDXC Memory Card, Memory Stick Select
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
No graphics
Audio Output
Integrated
High Definition Audio
Input Device
Keyboard
Keyboard
USB
Integrated
Interface (Bus) Type
PCI Express 1.1 x1
Ethernet Controller
Intel I218-LM
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1as, IEEE 802.3az
Bays
2 (total) / 2 (free) x external 5.25" x 1/2H , 3 (total) / 2 (free) x internal 3.5" x 1/3H , 1 (total) / 0 (free) x external 5.25" Slim Line
Slots
2 (total) / 1 (free) x CPU , 4 (total) / 2 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe 2.0 x4 - half-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height , 1 (total) / 1 (free) x PCI - full-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x1 - full-length, full-height
8 x USB 3.0 (4 front, 4 rear) , 2 x USB 2.0 , 1 x PS/2 mouse , 1 x PS/2 keyboard , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x microphone (1 rear) , 1 x audio line-out , 1 x headphones (1 rear)
Handle in Top Optical Bay
Power-on password, Setup Password
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI 2.0, RoHS, WEEE
Power supply
Nominal Voltage
Power Provided
925 Watt
80 PLUS Certification
80 PLUS
Efficiency
90%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
17.15 cm
46.48 cm
44.45 cm
15 kg
5 °C
35 °C
8 - 85% (non-condensing)
HP Z640 Workstation Intel Xeon E5-2620v3 16GB 1TB Windows 7 Professional 64-bit Bundle deal on HP Z640 Workstation Intel Xeon E5-2620v3 16GB 1TB Windows 7 Professional 64-bit
£1,721.21
saving £3.64
£1,640.52
Storage Type: HDD
Processor Model: E5-2620V3
Type: Workstation
Case Style: Mini tower
Display: no
Optical Storage: DVD±RW (±R DL) / DVD-RAM
Brand: HP
Price Range Ex VAT: 1500+
