HP Z600 Workstation MT Intel Xeon E5645 6GB 160GB SSD Windows 7 Professional 64-bit
Quicklinx: 7XWKWS00 Mfr#: WM422ET#ABU
  • Xeon
  • Microsoft Windows 7 Professional 64-bit Edition
The HP Z600 packs twelve-core compute and visualization power into a small, quiet package-for the ideal workstation when every inch, watt, and decibel make a difference.
  • Engineered to perform
    The HP Z600 is engineered to optimize the way processor, memory, graphics, OS, and software technology work together to deliver massive, whole-system computational power.
  • Sleek industrial design
    Brushed aluminum side panels, integrated handles, and visually cable-less engineering are just a few of the design features that create standards for lowered acoustics, serviceability, and energy efficiency.
  • Designed with the environment in mind
    Lower power and cooling costs with ENERGY STAR qualified configurations, 85% efficient power supplies, and HP WattSaver, an energy-saving feature that, when activated, helps lower energy consumption in off mode.
  • Compact and unassuming
    Enhance your work area with HP's quietest workstation, designed for environments where space is at a premium.
  • Ease of service without comparison
    The tool-free chassis and the uncluttered and highly streamlined internal design gives you the ability to add or change components in mere seconds.
  • Easy-to-use system diagnostics tool
    Quickly capture complete system configuration data and share with IT personnel with HP Vision Field Diagnostics, an easy-to-use system diagnostics tool that runs outside the OS.
HP Workstation z600 - MT - Xeon E5645 2.4 GHz - 6 GB - SSD 160 GB
Workstation - mini tower - system password, power-on password, USB port control
1 x Intel Xeon E5645 / 2.4 GHz (, up to 2.67 GHz, (6-core)
Processor Socket
LGA1366 Socket
Processor Main Features
Hyper-Threading Technology, Intel QuickPath Interconnect, Intel Turbo Boost Technology
Cache Memory
12 MB
Cache Per Processor
12 MB
RAM
6 GB (installed) / 24 GB (max) - DDR3 SDRAM - ECC - PC3-10600
Storage Controller
RAID (SATA 3Gb/s)
Hard Drive
SSD 160 GB - SATA 3Gb/s
Optical Storage
DVD SuperMulti
Card Reader
22 in 1
Graphics Controller
No graphics
Audio Output
Stereo - integrated
1GbE
OS Provided
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
Software Included
Windows 7 Professional 64-bit recovery DVD
Black, silver
16.5 cm x 44 cm x 44.5 cm
15 kg
Manufacturer Selling Program
HP Smart Buy
Workstation
Recommended Use
Small business, corporate business
Product Form Factor
Mini tower
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Black, silver
Processor / Chipset
CPU
Intel Xeon E5645
Clock Speed
2.4 GHz
Max Turbo Speed
2.67 GHz
Number of Cores
6-core
64-bit Computing
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
LGA1366 Socket
Chipset Type
Intel 5520
Cache Memory
Installed Size
12 MB
Cache Per Processor
12 MB
RAM
Installed Size
6 GB / 24 GB (max)
DDR3 SDRAM - ECC
Effective Memory Speed
1333 MHz
Rated Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
DIMM 240-pin
Slots
6 (Total)
Unbuffered, triple channel memory architecture
RAM Supported
48 GB registered - ECC , 24 GB unbuffered - ECC
Hard Drive
SSD
1 x 160 GB
Interface Type
SATA 3Gb/s
Storage Controller
1 x RAID - integrated
Controller Interface Type
SATA 3Gb/s
Channel Qty
6
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Read Speed
40x (CD) / 16x (DVD)
Write Speed
40x (CD) / 16x (DVD±R) / 8x (DVD±R DL)
CD / DVD Rewrite Speed
32x (CD) / 8x (DVD±RW) / 12x (DVD-RAM)
Card Reader
22 in 1 card reader
Supported Flash Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, Microdrive, MultiMediaCard, SD Memory Card, Memory Stick Duo, xD-Picture Card, Memory Stick PRO Duo, miniSD, RS-MMC, MultiMediaCardmobile, microSD, MultiMediaCardplus, SDHC Memory Card, miniSDHC, microSDHC, Memory Stick PRO-HG Duo, SDXC Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
No graphics
Audio Output
Integrated
Sound Output Mode
Stereo
High Definition Audio
Input Device
Mouse, keyboard
Mouse
Laser
USB
Scroll
Integrated
Interface (Bus) Type
PCI Express x1
Remote Management Protocol
ASF 2.0
Bays
2 external 5.25" x 1/2H , 2 (total) / 1 (free) x internal 3.5" x 1/3H
Slots
2 (total) / 1 (free) x CPU , 6 DIMM 240-pin , 2 (total) / 2 (free) x PCI - full-length, full-height , 2 (total) / 2 (free) x PCIe 2.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x8 - full-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe x8 - full-length, full-height (x4 mode)
9 x USB 2.0 (3 front, 6 rear) , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x audio line-out , 2 x microphone (1 front, 1 rear) , 1 x headphones (1 in front)
System password, power-on password, USB port control
Theft/Intrusion Protection
ACPI 2.0, RoHS, WEEE
HP Smart Buy
Power supply
Power Provided
650 Watt
80 PLUS Certification
80 PLUS
Efficiency
85%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Software
16.5 cm
44 cm
44.5 cm
15 kg
5 °C
35 °C
8 - 85% (non-condensing)
7XWK HPE DisplayPort DVI-D Adapter In Stock £19.77
7XWK HPE USB to Serial Port Adapter In Stock £13.95
