No matter what the future holds, you'll have all the performance you need. Ideal for VFX and rendering, this workhorse offers a wide range of processing power and the flexibility to upgrade components over time.
Operating Systems
Support your unique user needs with a choice of Windows 10 Pro or Linux operating systems. -
Processors
Achieve the performance you need with the ability to support two next generation Intel Xeon processors for up to 56 total processor cores in one system. -
Graphics
Get serious about graphics and reach peak productivity with access to a breadth of NVIDIA and AMD professional graphics from entry to ultra 3D. -
Storage
Install the fastest professional grade storage hardware around, unlocking performance for storage-bound applications without sacrificing standard PCIe slots. -
Deliberate design
The Z6 workstation's sleek, iconic design doesn't compromise on quiet, reliable performance. -
Unrivaled BIOS protection
HP SureStart automatically detects intrusions in real-time, notifies you, and restores the BIOS you use, so you can breathe easier.
- HP Workstation Z6 G4 - tower - Xeon Silver 4114 2.2 GHz - vPro - 32 GB - SSD 256 GB
- Workstation - tower
- Platform Technology
- Intel vPro Platform
- Height (Rack Units)
- 4U
- Localisation
- Processor
- 1 x Intel Xeon Silver 4114 / 2.2 GHz (, up to 3 GHz, (10-core)
- Processor Socket
- FCLGA3647 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2
- Cache Memory
- 13.75 MB L3 Cache
- Cache Per Processor
- 13.75 MB
- RAM
- 32 GB (installed) / 384 GB (max) - DDR4 SDRAM - ECC - PC4-21333
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - PCI Express - PCI Express - HP Z Turbo Drive
- Optical Storage
- No optical drive
- Graphics Controller
- No graphics
- Audio Output
- Stereo
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro for Workstations Plus 64-bit Edition
- Software Included
- HP Remote Graphics Software, HP Performance Advisor, HP Secure Erase
- Black
- 16.9 cm x 46.5 cm x 44.5 cm
- 13.1 kg
- Manufacturer Selling Program
- HP Smart Buy
- Workstation
- Product Form Factor
- Tower - 4U
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
- Localisation
Processor / Chipset
- CPU
- Intel Xeon Silver 4114
- Clock Speed
- 2.2 GHz
- Max Turbo Speed
- 3 GHz
- Number of Cores
- 10-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- CPU Socket
- FCLGA3647 Socket
- Chipset Type
- Intel C622
Cache Memory
- Installed Size
- L3 Cache - 13.75 MB
- 13.75 MB
RAM
- Installed Size
- 32 GB / 384 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2666 MHz
- Memory Specification Compliance
- PC4-21333
- Form Factor
- DIMM 288-pin
- Slots
- 12 (Total) / 10 (empty)
- Registered, slots 7 - 12 are available in two-processor configuration only, non-uniform memory architecture
- Configuration Features
- 2 x 16 GB
Hard Drive
- SSD - PCI Express
- Capacity
- 1 x 256 GB
- Interface Type
- PCI Express
- HP Z Turbo Drive
Storage Controller
- SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 6
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- No graphics
Audio Output
- Sound Output Mode
- Stereo
- High Definition Audio
- Interface (Bus) Type
- PCI Express 3.0
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- Intel I219-LM
- Data Link Protocol
- Wake on LAN (WoL), PXE 2.1 support
- IEEE 802.3, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1as, IEEE 802.3az, IEEE 1588v2
- Bays
- 1 (total) / 1 (free) x external 5.25" Slim Line , 2 (total) / 2 (free) x external 5.25" , 2 (total) / 2 (free) x internal 2.5" / 3.5" shared
- Slots
- 2 (total) / 1 (free) x CPU , 12 (total) / 10 (free) x DIMM 288-pin , 3 (total) / 3 (free) x PCIe 3.0 x4 , 2 (total) / 2 (free) x PCIe 3.0 x16 , 1 (total) / 0 (free) x PCIe 3.0 x8 , 2 (total) / 2 (free) x M.2 Card
- 1 x headphones/microphone (1 in front) , 10 x USB 3.1 Gen 1 - Type A (4 front, 6 rear) (one of them is charging) , 1 x PS/2 mouse , 2 x LAN (Gigabit Ethernet) - RJ-45 , 1 x audio line-in , 1 x audio line-out , PS/2 keyboard
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- Security Slot Type
- Kensington security slot
- RoHS, WEEE, ACPI 5.0, low halogen
- HP Smart Buy
- Power supply
- Voltage Required
- Power Provided
- 1000 Watt
- Efficiency
- 90%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro for Workstations Plus 64-bit Edition English
- Software
- 16.9 cm
- 46.5 cm
- 44.5 cm
- 13.1 kg
- 5 °C
- 35 °C
- 10 - 85% (non-condensing)
HPE DisplayPort DVI-D Adapter | In Stock | £19.74 |
HPE USB to Serial Port Adapter | In Stock | £13.94 |
