Take your business to the next level of performance, expandability, and no compromise reliability in one complete package. Featuring a perfect mix of HP Z DNA in a performance workstation package with up to 8 discrete processor cores, up to 128 GB of RAM, and multiple storage and PCIe configuration options.
Primed to perform
Achieve the performance you need with next generation Intel Xeon processors for up to 8 processor cores in one system. -
Graphics pro
Get serious about graphics and reach peak productivity with access to a breadth of AMD professional graphics from entry to high-end 3D. -
See everything clearly
Take productivity up a notch with the ability to do more thanks to NVIDIA professional graphics cards in 2D or 3D. -
High-power ports
Maximize your time and increase your capabilities with USB and SATA ports, plus lightning-fast data transfers using optional Thunderbolt 2 technology. -
A chassis that meets any challenge
A brand new tool-free chassis boasts low acoustics, single integrated Gb Ethernet and more. -
Set a new performance curve for your HP Z440
Reduce boot up, calculation, and graphics response and revolutionize how your HP Z440 handles large files with the HP Z Turbo Drive, a remarkably fast and innovative storage solution.
- HP Workstation Z440 - MT - Xeon E5-1620V3 3.5 GHz - vPro - 16 GB - SSD 256 GB
- Workstation - mini tower - power-on password, USB port control, audio ports control, network port control, Setup Password
- Platform Technology
- Intel vPro Platform
- Height (Rack Units)
- 4U
- Localisation
- Processor
- 1 x Intel Xeon E5-1620V3 / 3.5 GHz (, up to 3.6 GHz, (Quad-Core)
- Processor Socket
- LGA2011-v3 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2
- Cache Memory
- 10 MB
- Cache Per Processor
- 10 MB
- RAM
- 16 GB (installed) / 128 GB (max) - DDR4 SDRAM - ECC - PC4-17000
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - PCI Express 2.0 x4
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- No graphics
- Audio Output
- Integrated
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
- Software Included
- Cyberlink PowerDVD, CyberLink Power2Go, HP Power Assistant, PDF Complete Corporate Edition, HP Performance Advisor, HP Remote Graphics Software 5
- Jack black
- 16.9 cm x 44.5 cm x 43.2 cm
- 11 kg
- Limited warranty - parts and labour - 3 years - on-site
- Workstation
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Mini tower - 4U
- Built-in Devices
- Solenoid hood lock
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Jack black
- Localisation
Processor / Chipset
- CPU
- Intel Xeon E5-1620V3
- Clock Speed
- 3.5 GHz
- Max Turbo Speed
- 3.6 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA2011-v3 Socket
- Chipset Type
- Intel C612
Cache Memory
- Installed Size
- 10 MB
- 10 MB
RAM
- Installed Size
- 16 GB / 128 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- DIMM 288-pin
- Slots
- 8 (Total) / 6 (empty)
- Registered
- Configuration Features
- 2 x 8 GB
Hard Drive
- SSD
- Capacity
- 1 x 256 GB
- Interface Type
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 6
- RAID Level
- RAID 0, RAID 1, RAID 10
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- No graphics
Audio Output
- Integrated
- High Definition Audio
Input Device
- Mouse
Mouse
- Technology
- Laser
- Interface
- USB
- Scroll
- Integrated
- Ethernet Controller
- Intel 82579
- Data Link Protocol
- Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 2 (free) x external 5.25" , 2 (total) / 2 (free) x internal 3.5"
- Slots
- 8 (total) / 6 (free) x DIMM 288-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe 2.0 x1 - half-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 0 (free) x PCIe 2.0 x4 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height , 1 (total) / 1 (free) x PCI - full-length, full-height
- 8 x USB 3.0 (4 front, 4 rear) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 2 x USB 2.0 , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) - RJ-45
- Included Accessories
- HP Business PC Security Lock Kit
- Power-on password, USB port control, audio ports control, network port control, Setup Password
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Power supply
- Voltage Required
- Power Provided
- 700 Watt
- 80 PLUS Certification
- 80 PLUS
- Efficiency
- 90%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence - English
- Software
- 16.9 cm
- 44.5 cm
- 43.2 cm
- 11 kg
- 5 °C
- 35 °C
- 8 - 85% (non-condensing)
