HP Z4 G4 Core i9-7940X 16GB 256GB SSD Windows 10 Pro
Quicklinx: DQHMWS00 Mfr#: 3MC04ES#ABU
Perfect for engineering and visualization, HP's popular workstation delivers disruptive performance for a wide spectrum of applications.
  • Feature-rich functionality
    The Z4 is ahead of its time with more standard features than any other single processor HP workstation. With multiple configuration options, you can choose the perfect blend of components that meet your performance requirements.
  • Visualization powerhouse
    Visualize your project anytime with the power to move seamlessly between rendering and simulation applications. The Z4 can easily handle tasks that require high frequency processing, multiple cores and high-powered GPUs for an optimized design process.
  • Functional design
    The simply stunning design features front and rear handles, so you can easily relocate your system.
HP Workstation Z4 G4 - MT Core i9 7940X X-series 3.1 GHz - 16 GB - SSD 256 GB - UK
Workstation - MT
Height (Rack Units)
4U
1 x Intel Core i9 (7th Gen) 7940X X-series / 3.1 GHz (up to 4.3 GHz, (14-core)
Processor Socket
LGA2066 Socket
Processor Main Features
Intel Turbo Boost Technology 3
Cache Memory
19.25 MB
Cache Per Processor
19.25 MB
RAM
16 GB (installed) / 128 GB (max) - DDR4 SDRAM - non-ECC - PC4-20800
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 256 GB - PCI Express 3.0 x4 - M.2 2280 - HP Z Turbo Drive
Optical Storage
DVD-Writer
Graphics Controller
No graphics
1GbE
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
HP Remote Graphics Software
16.9 cm x 44.5 cm x 38.6 cm
Environmental Standards
TCO Certified Desktops 9
Limited warranty - parts and labour - 3 years - on-site
Workstation
Product Form Factor
MT - 4U
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.1 GHz
Max Turbo Speed
4.3 GHz
Number of Cores
14-core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA2066 Socket
Chipset Type
Intel X299
Cache Memory
Installed Size
19.25 MB
Cache Per Processor
19.25 MB
RAM
Installed Size
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
Memory Specification Compliance
PC4-20800
DIMM 288-pin
Slots
8 (Total) / 7 (empty)
Unbuffered
Configuration Features
1 x 16 GB
Hard Drive
SSD - M.2 2280
1 x 256 GB
Interface Type
PCI Express 3.0 x4
HP Z Turbo Drive
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
6
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
No graphics
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Business Slim Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Intel I219-V
Wake on LAN (WoL), PXE support
Bays
2 (total) / 1 (free) x external 5.25" , 2 (total) / 2 (free) x internal 3.5"
Slots
2 (total) / 2 (free) x PCIe 3.0 x16 , 2 (total) / 2 (free) x PCIe 3.0 x4 , 1 (total) / 1 (free) x PCIe 3.0 x8 , 2 (total) / 1 (free) x M.2 Card
10 x USB 3.1 Gen 1 (4 front, 6 rear) (one of them is charging) , 1 x headphones/microphone , 1 x audio line-in , 1 x audio line-out , 2 x USB-C 3.1 , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet)
HP Z4 Fan and Front Card Guide Kit, HP Z4 High-Power Processor Cooling Solution
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, RoHS, FIPS 140-2, Common Criteria EAL4+, WEEE 2002/96/EC, ISO 11469, ISO 1043
Power supply
Power Provided
1000 Watt
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Software
Sustainability Information
TCO Certified
16.9 cm
44.5 cm
38.6 cm
5 °C
35 °C
10 - 85% (non-condensing)
