Brand
HP Z32 31.5" 3840x2160 14ms HDMI DisplayPort IPS LED Monitor
Quicklinx: F6W8WS00 Mfr#: 1AA81A4#ABU
Diagonal Size: 31.5in
Max Resolution: 3840 x 2160
Response Time: 14ms
Interfaces: HDMI, DisplayPort, USB-C, Mini DisplayPort
42 in stock
£733.33 ex VAT
£879.99 inc VAT
Experience extraordinary, precise color and see more of your projects at one time on a display with stunning 4K resolution.
  • Incredible clarity for maximum productivity
    Optimize your workflows with a large, 4K display. View more lines of code, bigger spreadsheets, and vibrant colors, all with minimal toggling and scrolling.
  • One powerful connection
    Work fast and clutter-free with USB-C connectivity that not only receives video and data from your device, but also delivers up to 65W of power-with just one cable.
  • Reliable visual solution
    Perfect your designs, projects, and documents on a display built to meet your demands. All HP Z Displays are rigorously tested and backed by an exclusive HP Zero Bright Dot Guarantee that replaces the screen if even one bright sub-pixel fails.
HP Z32 - LED monitor - 4K - 31.5"
LED-backlit LCD monitor - 31.5"
Energy Class
Class G
Energy Consumption per Year
66 kWh
Power Consumption (On mode)
33 W
USB 3.0/USB-C hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.181 mm
Brightness
350 cd/m²
Contrast Ratio
1300:1 / 5000000:1 (dynamic)
Response Time
14 ms (grey-to-grey)
Input Connectors
HDMI, DisplayPort, Mini DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
71.45 cm x 24.8 cm x 56.44 cm
12.16 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, CEL, EAC, ISC, SEPA, low halogen, ICE
5-year warranty
Display Type
Energy Class
Class G
66 kWh
Diagonal Size
31.5"
Viewable Size
31.5"
Built-in Devices
USB 3.0/USB-C hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.181 mm
Pixel Per Inch
140
Brightness
350 cd/m²
Contrast Ratio
Response Time
Vertical Refresh Rate
29 - 60 Hz
Horizontal Refresh Rate
28 - 135 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
HDCP, anti-glare, 99% sRGB colour gamut, Mercury free, arsenic-free glass, 100% BT.709 colour gamut
71.45 cm x 24.8 cm x 56.44 cm - with stand
12.16 kg
DisplayPort , Mini DisplayPort , HDMI , Audio line-out , 3 x USB 3.0 downstream , USB-C upstream , USB-C downstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
1 x USB cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
33 W
33 kWh/1000h
Power Consumption (Typical)
70 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Assistant
Dimensions & Weight Details
With stand - width: 71.45 cm - depth: 24.8 cm - height: 56.44 cm - weight: 12.16 kg , Without stand - width: 71.45 cm - depth: 4.45 cm - height: 41.09 cm - weight: 7.59 kg
TCO Certified
ENERGY STAR Certified
Limited warranty - 5 years - on-site - response time: next business day
5 °C
35 °C
20 - 80% (non-condensing)
Response Time: 14ms
Interfaces: HDMI
Interfaces: DisplayPort
Interfaces: USB-C
Interfaces: Mini DisplayPort
Brand: HP
Price Range Ex VAT: £500 - £750
Stock Status: In stock
