Join the Ultra High Definition movement and expand your visual workspace with the HP Z27s 68,6 cm (27") IPS UHD Display, which delivers an extra-large screen with UHD/4K presentation and flexible connectivity and comfort features.
Get comfortable
Find your sweet spot with customizable tilt, height adjustment, swivel, and pivot settings-plus an integrated HP Quick Release that allows you to mount the display on a wall. -
Meet your monitor's new best friend
Design the screen for how you work with HP Display Assistant software. -
Designed with the environment in mind
Be a better consumer with a display that has environmentally responsible components that include low halogen, arsenic-free glass, and mercury-free backlights.
- HP Z27s - LED monitor - 4K - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class C
- Energy Consumption per Year
- 77 kWh
- Power Consumption (On mode)
- 53 W
- USB Hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.15525 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 6 ms (grey-to-grey with overdrive)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 100% sRGB
- Input Connectors
- HDMI, DisplayPort, Mini DisplayPort, MHL
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 62.56 cm x 24.24 cm x 53.59 cm
- 7.8 kg
- Localisation
- English / United Kingdom
- Plug and Play, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, KCC, KC, CECP, EPA, ISC, CEL Grade 2, SEPA
- 3-year warranty
- Display Type
- Energy Class
- Class C
- 77 kWh
- Diagonal Size
- 27"
- Viewable Size
- 26.9"
- Built-in Devices
- USB Hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.15525 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 100% sRGB
- Response Time
- Vertical Refresh Rate
- 24 - 60 Hz
- Horizontal Refresh Rate
- 30 - 135 kHz
- Video Bandwidth
- 600 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, contrast, input select, colour temperature
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP
- Black
- 62.56 cm x 24.24 cm x 53.59 cm - with stand
- 7.8 kg
- HDMI (HDCP) , MHL / HDMI (HDCP) , DisplayPort (HDCP) , Mini DisplayPort (HDCP) , 4 x USB 3.0 downstream , Audio line-out
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 45
- Rotation Angle
- 90
- Height Adjustment
- 120 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand
- Cables Included
- 1 x USB cable - 1.8 m , 1 x Mini DisplayPort cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- 53 W
- Power Consumption (Typical)
- 61 Watt
- Power Consumption Stand by
- 0.38 Watt
- Power Consumption Sleep
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 62.56 cm - depth: 24.24 cm - height: 53.59 cm - weight: 7.8 kg , Without stand - width: 62.56 cm - depth: 6.09 cm - height: 37.03 cm - weight: 5.4 kg
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
