HP Z27s 27" 3840x2160 6ms HDMI MHL DisplayPort UHD IPS LED Monitor
Quicklinx: BKYJWS00 Mfr#: J3G07A4#ABU
Join the Ultra High Definition movement and expand your visual workspace with the HP Z27s 68,6 cm (27") IPS UHD Display, which delivers an extra-large screen with UHD/4K presentation and flexible connectivity and comfort features.
  • Get comfortable
    Find your sweet spot with customizable tilt, height adjustment, swivel, and pivot settings-plus an integrated HP Quick Release that allows you to mount the display on a wall.
  • Meet your monitor's new best friend
    Design the screen for how you work with HP Display Assistant software.
  • Designed with the environment in mind
    Be a better consumer with a display that has environmentally responsible components that include low halogen, arsenic-free glass, and mercury-free backlights.
HP Z27s - LED monitor - 4K - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
77 kWh
Power Consumption (On mode)
53 W
USB Hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.15525 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
6 ms (grey-to-grey with overdrive)
Colour Support
1.07 billion colours
Colour Gamut
100% sRGB
Input Connectors
HDMI, DisplayPort, Mini DisplayPort, MHL
Screen Coating
Anti-glare
Voltage
62.56 cm x 24.24 cm x 53.59 cm
7.8 kg
English / United Kingdom
Plug and Play, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, KCC, KC, CECP, EPA, ISC, CEL Grade 2, SEPA
3-year warranty
Display Type
Energy Class
Class C
77 kWh
Diagonal Size
27"
Viewable Size
26.9"
Built-in Devices
USB Hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.15525 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
100% sRGB
Response Time
Vertical Refresh Rate
24 - 60 Hz
Horizontal Refresh Rate
30 - 135 kHz
Video Bandwidth
600 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, input select, colour temperature
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP
62.56 cm x 24.24 cm x 53.59 cm - with stand
7.8 kg
HDMI (HDCP) , MHL / HDMI (HDCP) , DisplayPort (HDCP) , Mini DisplayPort (HDCP) , 4 x USB 3.0 downstream , Audio line-out
Mechanical
Tilt Angle
-5/+20
Swivel Angle
45
Rotation Angle
90
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
1 x USB cable - 1.8 m , 1 x Mini DisplayPort cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
53 W
Power Consumption (Typical)
61 Watt
Power Consumption Stand by
0.38 Watt
Power Consumption Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 62.56 cm - depth: 24.24 cm - height: 53.59 cm - weight: 7.8 kg , Without stand - width: 62.56 cm - depth: 6.09 cm - height: 37.03 cm - weight: 5.4 kg
Limited warranty - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
