Enable a virtually borderless panorama of multiple displays with the HP Z27n narrow bezel IPS display, which has an edge-to-edge screen for maximum quad HD impact, out-of-the-box factory color calibration, and flexible connectivity for all of your devices.
Edge-to-edge experience
Get Quad HD 2560 x 1440 resolution visuals from a three-sided borderless design that reveals more of the 68,6 cm (27") diagonal screen and enables uninterrupted views of multiple displays. -
Color calibration at the ready
Enjoy reliable color accuracy across all of your projects with a factory-calibrated 99% sRGB color gamut from the very first time you turn on your display. -
Create a total workspace
Connect to your everyday devices with integrated HDMI, mDP, DP, MHL, DVI, and a USB 3.0 hub with a fast-charging port. The DisplayPort output allows you to daisy chain up to two displays with just one PC or workstation connection.
- HP Z27n - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 55 kWh
- Power Consumption (On mode)
- 37 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.2331 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 14 ms (grey-to-grey), 8 ms (overdrive)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- DVI-D, DisplayPort, Mini DisplayPort, HDMI (MHL)
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 61.43 cm x 21.82 cm x 53.37 cm
- 7.66 kg
- Localisation
- English / United Kingdom
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, UL, TUV GS, VCCI, C-Tick, BSMI, TUV S, WHQL, CB, CCC, TUV Ergo, FCC, KC, CECP, CEL Grade 2, SEPA
- 5-year warranty
- Display Type
- Energy Class
- Class B
- 55 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2331 mm
- Pixel Per Inch
- 108.8
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Vertical Refresh Rate
- 50 - 60 Hz
- Horizontal Refresh Rate
- 30 - 90 kHz
- Video Bandwidth
- 250 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Controls & Adjustments
- Colour balance, input select, luminance
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP, edge-to-edge glass, 99% sRGB colour gamut
- Black
- 61.43 cm x 21.82 cm x 53.37 cm - with stand
- 7.66 kg
- MHL / HDMI (HDCP) , DVI-D (dual link) (HDCP) , Mini DisplayPort (HDCP) , DisplayPort (HDCP) , DisplayPort output (HDCP) , USB 3.0 upstream , 4 x USB 3.0 downstream , Audio line-out
Mechanical
- Tilt Angle
- -5/+22
- Swivel Angle
- 45
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), HP Quick Release, detachable stand, 1 USB 3.0 fast charging port, VESA 100 x 100 mm
- Cables Included
- 1 x USB cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x Mini DisplayPort-DisplayPort cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 37 W
- Power Consumption (Typical)
- 83 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- On / Off Switch
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- With stand - width: 61.43 cm - depth: 21.82 cm - height: 53.37 cm - weight: 7.66 kg , Without stand - width: 61.43 cm - depth: 5.39 cm - height: 36.41 cm - weight: 5.1 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 5 years - on-site - response time: next business day
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
