Meticulously crafted to surpass every design standard, the HP Z27k G3 4K USB-C Display is composed of authentic aluminum and delivers an impressive, frameless viewing experience. Bring your ideas to life with remarkable color accuracy in precise 4K resolution. Refine your work experience and transform your PC into a powerhouse with this 68.6 cm (27") diagonal screen monitor with USB-C 100W Power Delivery.
Easily connect multiple monitors
Declutter your desk and connect a series of displays by daisy chaining with a single DisplayPort cable. -
All the ports you need
Connect to a Workstation, a PC and additional displays. -
Easily mount a Mini
Mount your HPZ2 Mini or HP Desktop Mini directly to the monitor for a clean workspace. -
HP Zero BrightDot Guarantee
Even if just a third of a pixel fails or is stuck in one position, HP will replace the entire display. -
Optional integrated audio
Easily attach the Z Display Conferencing Speaker Bar for stereo quality audio and dual microphones. -
3-year limited warranty
The assurance of HP's three-year standard limited warranty.
 - HP Z27k G3 - LED monitor - 4K - 27" - Smart Buy
 - LED-backlit LCD monitor - 27"
- Energy Class
 - Class F
- Power Consumption (On mode)
 - 26 W
 - USB 3.2 Gen 1 hub, USB PD 100 Watt
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
 - 4K 3840 x 2160 at 60 Hz
- Pixel Pitch
 - 0.155 mm
- Brightness
 - 350 cd/m²
- Contrast Ratio
 - 1000:1 / 10000000:1 (dynamic)
- Response Time
 - 5 ms (grey-to-grey with overdrive)
- Colour Gamut
 - 99% sRGB
- Input Connectors
 - HDMI, DisplayPort, USB-C
 - Height, pivot (rotation), swivel, tilt
- Screen Coating
 - Anti-glare, 3H Hard Coating
- Voltage
 - AC 120/230 V (50/60 Hz)
 - 61.23 cm x 20.5 cm x 53.04 cm
 - 6.2 kg
- Localisation
 - English / United Kingdom
- Manufacturer Selling Program
 - HP Smart Buy
- Environmental Standards
 - TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
 - VCCI, BSMI, GS, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, cTUVus, KC, CECP, CEL, EAC, SEPA, BIS, low halogen, UAE, Australian-New Zealand MEPS, Vietnam MEPS, Ukraine Energy Label
- Display Type
- Energy Class
 - Class F
- Diagonal Size
 - 27"
- Built-in Devices
 - USB 3.2 Gen 1 hub
- USB Power Delivery
 - 100 Watt
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
- Pixel Pitch
 - 0.155 mm
- Pixel Per Inch
 - 163
- Brightness
 - 350 cd/m²
- Contrast Ratio
- Colour Gamut
 - 99% sRGB
- Response Time
- Vertical Refresh Rate
 - 50 - 60 Hz
- Horizontal Refresh Rate
 - 30 - 80 kHz
- Horizontal Viewing Angle
 - 178
- Vertical Viewing Angle
 - 178
- Screen Coating
- Backlight Technology
 - LED backlight
 - Low Blue Light Mode, Flicker Free technology, Mercury free, arsenic-free glass, 10-bit Colour Depth, edge-lit LED backlight, 4-sided micro-edge
 - 61.23 cm x 20.5 cm x 53.04 cm - with stand
 - 6.2 kg
 - DisplayPort 1.4 , 4 x USB 3.2 Gen 1 downstream , USB-C upstream/DisplayPort Alt Mode with Power Delivery (power up to 100W) , DisplayPort output , HDMI
Mechanical
- Tilt Angle
 - -5/+20
- Swivel Angle
 - 90
- Rotation Angle
 - 180
- Height Adjustment
 - 150 mm
- VESA Mounting Interface
 - 100 x 100 mm
 - Security lock slot (cable lock sold separately), detachable stand
- Included Accessories
 - VESA bracket
- Localisation
 - HP Smart Buy
- Security Slot Type
 - Kensington security slot
- Input Voltage
 - 26 W
- Power Consumption SDR (On mode)
 - 26 kWh/1000h
- Power Consumption (Typical)
 - 42 Watt
- Power Consumption Stand by
 - 0.3 Watt
 - 0.3 Watt
- Dimensions & Weight Details
 - With stand - width: 61.23 cm - depth: 20.5 cm - height: 53.04 cm - weight: 6.2 kg , Without stand - width: 61.23 cm - depth: 6.35 cm
- Shipping Width
 - 69.8 cm
- Shipping Depth
 - 42.3 cm
- Shipping Weight
 - 9.4 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
 - 5 °C
 - 35 °C
 - 20 - 80% (non-condensing)
                        HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site | In Stock | £22.36 |
                        HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site | In Stock | £32.96 |
                        HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site | In Stock | £5.93 |
