HP Z27k G3 27" 3840x2160 5ms HDMI LED Monitor
Quicklinx: G86KWS00 Mfr#: 1B9T0AT#ABU
Diagonal Size: 27in
Max Resolution: 3840 x 2160
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, HDMI, USB-C
£412.22 ex VAT
£494.66 inc VAT
Meticulously crafted to surpass every design standard, the HP Z27k G3 4K USB-C Display is composed of authentic aluminum and delivers an impressive, frameless viewing experience. Bring your ideas to life with remarkable color accuracy in precise 4K resolution. Refine your work experience and transform your PC into a powerhouse with this 68.6 cm (27") diagonal screen monitor with USB-C 100W Power Delivery.
  • Easily connect multiple monitors
    Declutter your desk and connect a series of displays by daisy chaining with a single DisplayPort cable.
  • All the ports you need
    Connect to a Workstation, a PC and additional displays.
  • Easily mount a Mini
    Mount your HPZ2 Mini or HP Desktop Mini directly to the monitor for a clean workspace.
  • HP Zero BrightDot Guarantee
    Even if just a third of a pixel fails or is stuck in one position, HP will replace the entire display.
  • Optional integrated audio
    Easily attach the Z Display Conferencing Speaker Bar for stereo quality audio and dual microphones.
  • 3-year limited warranty
    The assurance of HP's three-year standard limited warranty.
HP Z27k G3 - LED monitor - 4K - 27" - Smart Buy
LED-backlit LCD monitor - 27"
Energy Class
Class F
Power Consumption (On mode)
26 W
USB 3.2 Gen 1 hub, USB PD 100 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.155 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms (grey-to-grey with overdrive)
Colour Gamut
99% sRGB
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
61.23 cm x 20.5 cm x 53.04 cm
6.2 kg
English / United Kingdom
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
VCCI, BSMI, GS, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, cTUVus, KC, CECP, CEL, EAC, SEPA, BIS, low halogen, UAE, Australian-New Zealand MEPS, Vietnam MEPS, Ukraine Energy Label
Display Type
Energy Class
Class F
Diagonal Size
27"
Built-in Devices
USB 3.2 Gen 1 hub
USB Power Delivery
100 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.155 mm
Pixel Per Inch
163
Brightness
350 cd/m²
Contrast Ratio
Colour Gamut
99% sRGB
Response Time
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Low Blue Light Mode, Flicker Free technology, Mercury free, arsenic-free glass, 10-bit Colour Depth, edge-lit LED backlight, 4-sided micro-edge
61.23 cm x 20.5 cm x 53.04 cm - with stand
6.2 kg
DisplayPort 1.4 , 4 x USB 3.2 Gen 1 downstream , USB-C upstream/DisplayPort Alt Mode with Power Delivery (power up to 100W) , DisplayPort output , HDMI
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
VESA bracket
HP Smart Buy
Security Slot Type
Kensington security slot
Input Voltage
26 W
26 kWh/1000h
Power Consumption (Typical)
42 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 61.23 cm - depth: 20.5 cm - height: 53.04 cm - weight: 6.2 kg , Without stand - width: 61.23 cm - depth: 6.35 cm
Shipping Width
69.8 cm
Shipping Depth
42.3 cm
Shipping Weight
9.4 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
5 °C
35 °C
20 - 80% (non-condensing)
G86K HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £22.36
G86K HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £32.96
G86K HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £5.89
Diagonal Size: 27in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: USB-C
Brand: HP
