HP Z24u G3 24" 1920x1200 5ms 5ms HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: H02SWS00 Mfr#: 1C4Z6AA#ABU
Diagonal Size: 24in
Max Resolution: 1920 x 1200
Response Time: 5ms
Speakers: None
Interfaces: HDMI, DisplayPort, USB-C
£277.78 ex VAT
£333.33 inc VAT
Meticulously crafted to surpass every design standard, the HP Z24u G3 WUXGA USB-C Display is composed of authentic aluminum and delivers an impressive, frameless viewing experience. Bring your ideas to life with remarkable color accuracy in precise WUXGA resolution. Refine your work experience and transform your PC into a powerhouse with this 24 inch diagonal screen monitor with USB-C 100W Power Delivery.
  • Easily connect multiple monitors
    Declutter your desk and connect a series of displays by daisy chaining with a single DisplayPort cable.
  • All the ports you need
    Connect to a Workstation, a PC and additional displays.
  • Easily mount a Mini
    Mount your HPZ2 Mini or HP Desktop Mini directly to the monitor for a clean workspace.
  • HP Zero BrightDot Guarantee
    Even if just a third of a pixel fails or is stuck in one position, HP will replace the entire display.
  • Optional integrated audio
    Easily attach the Z Display Conferencing Speaker Bar for stereo quality audio and dual microphones.
  • 3-year limited warranty
    The assurance of HP's three-year standard limited warranty.
HP Z24u G3 - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class E
Energy Consumption per Year
19 kWh
Power Consumption (On mode)
18.6 W
Daisy Chaining
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
WUXGA 1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms (grey-to-grey with overdrive)
Colour Gamut
99% sRGB, 85% DCI-P3
Input Connectors
HDMI, 2xDisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating, Haze 25%
Voltage
Turbo silver
53.17 cm x 19.5 cm x 52.14 cm
5.3 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
Plug and Play, VCCI, BSMI, GS, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, cTUVus, China Energy Label Level 1, KC, ERP, CECP, CEL, EAC, ISC, SEPA, BIS, low halogen, DisplayPort 1.4, UAE, Ukraine Energy Label
3-year warranty
Display Type
Energy Class
Class E
19 kWh
Diagonal Size
24"
Daisy Chaining
Built-in Devices
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.27 mm
Pixel Per Inch
96
Brightness
350 cd/m²
Contrast Ratio
Colour Gamut
Response Time
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
Picture by picture, On-screen Digital Controls, Multi-Stream transport (MST), Low Blue Light Mode, Flicker Free technology, Factory Calibration, 4 Side Borderless Design, Picture-in-Picture, edge-lit LED backlight, 8-bit(6-bit + FRC) Colour Depth, HP Eye Ease
Turbo silver
53.17 cm x 19.5 cm x 52.14 cm - with stand
5.3 kg
DisplayPort 1.4 output , DisplayPort 1.4 , HDMI , 4 x USB 3.2 Gen 1 , USB-C 3.1 Gen 2 upstream/DisplayPort 1.4 Alt Mode (power up to 100W) , Network
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, arsenic free, mercury free
Cable holder, VESA bracket
1 x DisplayPort 1.4 cable - 1.8 m , 1 x USB-C 3.2 Gen 1 cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
18.6 W
18.6 kWh/1000h
Power Consumption (Typical)
32 Watt
Power Consumption (Max)
160 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.2 Watt
Dimensions & Weight Details
With stand - width: 53.17 cm - depth: 19.5 cm - height: 52.14 cm - weight: 5.3 kg , Without stand - width: 53.17 cm - depth: 3.85 cm - height: 34.29 cm - weight: 4.03 kg
Shipping Width
62.5 cm
Shipping Depth
41.5 cm
Shipping Height
14.2 cm
Shipping Weight
8.1 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
H02S HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £22.87
H02S HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £33.70
H02S HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £6.01
H02S HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £10.83
Diagonal Size: 24in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: DisplayPort
Interfaces: USB-C
Brand: HP
