Meticulously crafted to surpass every design standard, the HP Z24u G3 WUXGA USB-C Display is composed of authentic aluminum and delivers an impressive, frameless viewing experience. Bring your ideas to life with remarkable color accuracy in precise WUXGA resolution. Refine your work experience and transform your PC into a powerhouse with this 24 inch diagonal screen monitor with USB-C 100W Power Delivery.
Easily connect multiple monitors
Declutter your desk and connect a series of displays by daisy chaining with a single DisplayPort cable. -
All the ports you need
Connect to a Workstation, a PC and additional displays. -
Easily mount a Mini
Mount your HPZ2 Mini or HP Desktop Mini directly to the monitor for a clean workspace. -
HP Zero BrightDot Guarantee
Even if just a third of a pixel fails or is stuck in one position, HP will replace the entire display. -
Optional integrated audio
Easily attach the Z Display Conferencing Speaker Bar for stereo quality audio and dual microphones. -
3-year limited warranty
The assurance of HP's three-year standard limited warranty.
- HP Z24u G3 - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class E
- Energy Consumption per Year
- 19 kWh
- Power Consumption (On mode)
- 18.6 W
- Daisy Chaining
- USB 3.2 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- WUXGA 1920 x 1200 at 60 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 10000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey with overdrive)
- Colour Gamut
- 99% sRGB, 85% DCI-P3
- Input Connectors
- HDMI, 2xDisplayPort, USB-C
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating, Haze 25%
- Voltage
- AC 120/230 V (50/60 Hz)
- Turbo silver
- 53.17 cm x 19.5 cm x 52.14 cm
- 5.3 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
- Plug and Play, VCCI, BSMI, GS, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, cTUVus, China Energy Label Level 1, KC, ERP, CECP, CEL, EAC, ISC, SEPA, BIS, low halogen, DisplayPort 1.4, UAE, Ukraine Energy Label
- 3-year warranty
- Display Type
- Energy Class
- Class E
- 19 kWh
- Diagonal Size
- 24"
- Daisy Chaining
- Built-in Devices
- USB 3.2 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Pixel Per Inch
- 96
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 50 - 60 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- Picture by picture, On-screen Digital Controls, Multi-Stream transport (MST), Low Blue Light Mode, Flicker Free technology, Factory Calibration, 4 Side Borderless Design, Picture-in-Picture, edge-lit LED backlight, 8-bit(6-bit + FRC) Colour Depth, HP Eye Ease
- Turbo silver
- 53.17 cm x 19.5 cm x 52.14 cm - with stand
- 5.3 kg
- DisplayPort 1.4 output , DisplayPort 1.4 , HDMI , 4 x USB 3.2 Gen 1 , USB-C 3.1 Gen 2 upstream/DisplayPort 1.4 Alt Mode (power up to 100W) , Network
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand, arsenic free, mercury free
- Included Accessories
- Cable holder, VESA bracket
- Cables Included
- 1 x DisplayPort 1.4 cable - 1.8 m , 1 x USB-C 3.2 Gen 1 cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 18.6 W
- Power Consumption SDR (On mode)
- 18.6 kWh/1000h
- Power Consumption (Typical)
- 32 Watt
- Power Consumption (Max)
- 160 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.2 Watt
- Dimensions & Weight Details
- With stand - width: 53.17 cm - depth: 19.5 cm - height: 52.14 cm - weight: 5.3 kg , Without stand - width: 53.17 cm - depth: 3.85 cm - height: 34.29 cm - weight: 4.03 kg
- Shipping Width
- 62.5 cm
- Shipping Depth
- 41.5 cm
- Shipping Height
- 14.2 cm
- Shipping Weight
- 8.1 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
