Experience ultra high-definition /4K image presentation and factory-calibrated color accuracy out of the box with the HP Z24s 60,45 cm (23.8") IPS UHD Display, which also delivers flexible connectivity and comfort features-all at HP's most affordable HP Z Display price point.
The display that delivers what you demand
Get massive 3840 x 2160 resolution, 185 ppi, and sRGB color gamut for your demanding digital workflows. Wide viewing angles and a 60,45 (23.8") diagonal screen help ensure easy line of sight for one or many viewers. -
Limitless connectivity
Connect your display to a workstation, PC, and range of digital video devices with DisplayPort, mini-DisplayPort, HDMI, and four USB 3.0 ports. Use the two side-located USB ports for easy access to your most-used peripherals. -
UHD for every device
Instantly mirror your smart phone or tablet content to the large screen through an easy MHL connection that also keeps your devices charged and ready to go. -
Pixels for days
Get expansive views of your projects, documents, and media with 8MP-4x that of a Full HD display. View your mobile device and PC feeds side by side in picture-in-picture and picture-by-picture modes.
- HP Z24s - LED monitor - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class C
- Energy Consumption per Year
- 64 kWh
- Power Consumption (On mode)
- 44 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 30 Hz)
- Pixel Pitch
- 0.137 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 14 ms (grey-to-grey)
- Input Connectors
- 2xHDMI, DisplayPort, Mini DisplayPort, MHL
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 55.61 cm x 21.02 cm x 52.68 cm
- 6.46 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, RoHS, KCC, WEEE, KC, EPA, EAC, CEL Grade 1, ISC
- 3-year warranty
- Display Type
- Energy Class
- Class C
- 64 kWh
- Diagonal Size
- 23.8"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.137 mm
- Pixel Per Inch
- 185.4
- Brightness
- 300 cd/m²
- Contrast Ratio
- Response Time
- Vertical Refresh Rate
- 24 - 60 Hz
- Horizontal Refresh Rate
- 24 - 135 kHz
- Video Bandwidth
- 600 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, input select
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP
- Black
- 55.61 cm x 21.02 cm x 52.68 cm - with stand
- 6.46 kg
- HDMI (HDCP) , MHL / HDMI (HDCP) , DisplayPort (HDCP) , Mini DisplayPort , 4 x USB 3.0 downstream , USB 3.0 upstream , Audio line-out
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand
- Cables Included
- 1 x DisplayPort cable - 1.8 m , 1 x Mini DisplayPort-DisplayPort cable - 1.8 m , 1 x SuperSpeed USB cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- 44 W
- Power Consumption (Typical)
- 88 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- On / Off Switch
- Dimensions & Weight Details
- With stand - width: 55.61 cm - depth: 21.02 cm - height: 52.68 cm - weight: 6.46 kg , Without stand - width: 55.61 cm - depth: 6.97 cm - height: 33.53 cm - weight: 4.3 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
