Deploy a seamless multi-display setup with the HP Z24nf Narrow Bezel IPS Display, which delivers Full HD, factory color calibration, and flexible connectivity for all of your devices.
Narrow bezel beauty
Experience edge-to-edge 1920 x 1080 resolution on a three-sided borderless 60,45 cm (23.8") diagonal screen that enables uninterrupted views of multiple displays. -
Factory-integrated color calibration
Get reliable color accuracy across all of your projects with out-of-the-box color calibration that's ready to go the very first time you turn on your display. -
Build a better workspace
Connect to your everyday devices with integrated HDMI, mDP, DP, MHL, DVI, and a USB 3.0 hub with a fast-charging port. A DisplayPort output allows you to daisy chain up to four displays with just one PC or workstation connection.
- HP Z24nf - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class A
- Energy Consumption per Year
- 31 kWh
- Power Consumption (On mode)
- 21 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 8 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 95% sRGB
- Input Connectors
- HDMI, DVI-D, 2xDisplayPort, MHL
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 54.06 cm x 21.01 cm x 50.55 cm
- 5.2 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, C-Tick, BSMI, WHQL, CCC, FCC, KC, CECP
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 31 kWh
- Diagonal Size
- 23.8"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Pixel Per Inch
- 92.6
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 95% sRGB
- Response Time
- Vertical Refresh Rate
- 50 - 60 Hz
- Horizontal Refresh Rate
- 30 - 75 kHz
- Video Bandwidth
- 170 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, input select
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP
- Black
- 54.06 cm x 21.01 cm x 50.55 cm - with stand
- 5.2 kg
- DVI-D (dual link) (HDCP) , MHL / HDMI (HDCP) , DisplayPort (HDCP) , DisplayPort output , 4 x USB 3.0 downstream , USB 3.0 upstream , Audio line-out
Mechanical
- Tilt Angle
- -2/+22
- Swivel Angle
- 45
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand, 1 USB 3.0 charging port, HP Quick Release 2
- Cables Included
- 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 21 W
- Power Consumption (Typical)
- 45 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- On / Off Switch
- Dimensions & Weight Details
- With stand - width: 54.06 cm - depth: 21.01 cm - height: 50.55 cm - weight: 5.2 kg , Without stand - width: 54.06 cm - depth: 5.04 cm - height: 32.34 cm - weight: 3.3 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
