HP Z24NF G2 23.8" 1920x1080 8MS LED HDMI VGA
Quicklinx: D8MYWS00 Mfr#: 1JS07AT#ABU
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 5ms
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£156.88 ex VAT
£188.25 inc VAT
Be a productive powerhouse with the sleek HP Z24nf G2 60.45 cm (23.8") Display. This virtually seamless Full HD display is factory-tested for reliability and longevity with integrated color calibration, uninterrupted multi-screen tiling, and expansive device connections.
HP Z24nf G2 - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class A
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
23 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.274 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Black Pearl
53.88 cm x 20.5 cm x 46.3 cm
5.6 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
Plug and Play, VCCI, BSMI, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, WEEE, ICES, cTUVus, MEPS, E-Standby, KC, ERP, CEL, ISC, RCM, MSIP, SEPA, CoC, low halogen, CU, SmartWay
5-year warranty
Display Type
Energy Class
Class A
34 kWh
23 W
Diagonal Size
23.8"
Viewable Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.274 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 84 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
Zero Bright Dot, HDCP, arsenic-free glass, 95% sRGB colour gamut, micro-bezel design
Black Pearl
53.88 cm x 20.5 cm x 46.3 cm - with stand
5.6 kg
VGA , HDMI (HDCP) , DisplayPort (HDCP) , USB 3.0 upstream , 2 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+22
Swivel Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
1 x DisplayPort cable - 2 m , 1 x USB cable - USB Type A to B - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
19 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
Included Software
Display drivers, HP Display Assistant
Dimensions & Weight Details
Without stand - width: 53.2 cm - depth: 4.38 cm - height: 32.19 cm - weight: 3.1 kg , With stand - width: 53.88 cm - depth: 20.5 cm - height: 46.3 cm - weight: 5.6 kg
Shipping Width
62 cm
Shipping Depth
40 cm
Shipping Height
27.3 cm
Shipping Weight
8.3 kg
TCO Certified
ENERGY STAR Certified
Limited warranty - 5 years - on-site - response time: next business day
5 °C
35 °C
20 - 80% (non-condensing)
Response Time: 5ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: HP
Price Range Ex VAT: 150 - 300
