HP Z24NF G2 23.8" 1920x1080 8MS LED HDMI VGA
Quicklinx: D8MYWS00 Mfr#: 1JS07AT#ABU
Be a productive powerhouse with the sleek HP Z24nf G2 60.45 cm (23.8") Display. This virtually seamless Full HD display is factory-tested for reliability and longevity with integrated color calibration, uninterrupted multi-screen tiling, and expansive device connections.
  • Expand your connectivity
    Connect easily with ports that include a two-port USB 3.0 hub and VGA, HDMI, and DisplayPort connections tested for use with legacy, current, and future HP Workstations.
  • Find your sweet spot
    Work comfortably with adjustable tilt, height, and swivel settings. Use pivot rotation to conveniently customize portrait or landscape views on multiple displays.
  • Divide and conquer
    Design the screen for how you work with HP Display Assistant software, which enables screen partitioning and helps deter theft by dimming a display that's disconnected without approval.
  • Be responsible
    Reduce power consumption and help lower costs with an intelligent, energy-efficient, low-halogen display that is ENERGY STAR certified, TCO qualified, and EPEAT 2019 registered with mercury-free display backlights and arsenic-free display glass.
  • Make it yours
    Build a complete solution with optional HP accessories designed and tested to work with your display.
HP Z24nf G2 - LED monitor - Full HD (1080p) - 23.8" - Smart Buy
LED-backlit LCD monitor - 23.8"
Energy Class
Class E
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
17 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.274 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
95% sRGB
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
Black Pearl
53.88 cm x 20.5 cm x 46.3 cm
5.6 kg
English / United Kingdom
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VCCI, BSMI, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, WEEE, ICES, cTUVus, MEPS, E-Standby, KC, ERP, CEL, ISC, RCM, MSIP, SEPA, CoC, low halogen, CU, SmartWay
5-year warranty
Display Type
Energy Class
Class E
34 kWh
Diagonal Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.274 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
95% sRGB
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 84 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
Zero Bright Dot, HDCP, arsenic-free glass, micro-bezel design
Black Pearl
53.88 cm x 20.5 cm x 46.3 cm - with stand
5.6 kg
VGA , HDMI (HDCP) , DisplayPort (HDCP) , USB 3.0 upstream , 2 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+22
Swivel Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
1 x DisplayPort cable - 2 m , 1 x USB cable - USB Type A to B - 1.8 m
Backlight Life
30,000 hours
HP Smart Buy
Security Slot Type
Kensington security slot
Input Voltage
17 W
17 kWh/1000h
Power Consumption (Typical)
19 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
Included Software
Display drivers, HP Display Assistant
Dimensions & Weight Details
Without stand - width: 53.2 cm - depth: 4.38 cm - height: 32.19 cm - weight: 3.1 kg , With stand - width: 53.88 cm - depth: 20.5 cm - height: 46.3 cm - weight: 5.6 kg
Shipping Width
62 cm
Shipping Depth
40 cm
Shipping Height
27.3 cm
Shipping Weight
8.3 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 5 years - on-site - response time: next business day
5 °C
35 °C
20 - 80% (non-condensing)
D8MY HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £22.83
D8MY HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £33.64
D8MY HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £6.01
D8MY HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £10.81
