HP Z24n 24" 1920x1200 8ms DVI DisplayPort IPS LED Monitor
LIMITED STOCK LEFT - DON'T MISS OUT!
Bundles
Exclusive
Last Few Remaining
Quicklinx: BKYQWS00 Mfr#: K7B99AT#ABU
Create a seamless 16:10 multi-display setup with the HP Z24n Narrow Bezel IPS Display, which has a virtually borderless screen for maximum impact imagery, factory color calibration to ensure optimal color accuracy, and flexible connectivity for all of your devices.
Virtually borderless viewing.
Enjoy a stunning visual experience with a 1920 x 1200 resolution and more than two million pixels. Maximize your view of the 61 cm (24") diagonal screen and seamlessly tile multiple displays with a design that only has a border on one side.
Ports aplenty for a perfect workspace.
Connect to your everyday devices with integrated HDMI, mDP, DP, MHL, DVI, and a USB 3.0 hub with a fast-charging port. The DisplayPort output allows you to daisy chain up to two displays with just one PC or workstation connection.
Out-of-the-box color.
Count on a factory-calibrated 99% sRGB color gamut from the very first time you power on for reliable, accurate color between displays and from project to project.
  • Pick your picture
    Use picture-in-picture or picture-by-picture to get views from your connected devices and boost your multi-tasking productivity.
  • Find your sweet spot
    Work comfortably with adjustable tilt, height adjustment, and swivel settings. Use pivot rotation to customize portrait or landscape views when using multiple displays. An integrated HP Quick Release Bracket supports wall mounting.
  • Be responsible
    Reduce power consumption and lower costs with an intelligent, energy-efficient, low-halogen design that is ENERGY STAR certified, TCO qualified, and EPEAT Gold registered with mercury-free display backlights and arsenic-free display glass.
HP Z24n - LED monitor - 24" - Smart Buy
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
36 kWh
Power Consumption (On mode)
24 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
14 ms (grey-to-grey), 8 ms (overdrive)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
DVI, HDMI, MHL, DisplayPort, Mini DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
53.38 cm x 21.01 cm x 52.02 cm
5.78 kg
English / United Kingdom
Manufacturer Selling Program
HP Smart Buy
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, UL, TUV GS, VCCI, C-Tick, BSMI, TUV S, WHQL, CB, CCC, TUV Ergo, FCC, KC, CECP, CEL Grade 1, SEPA
5-year warranty
Display Type
Energy Class
Class A
36 kWh
Diagonal Size
24"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.27 mm
Pixel Per Inch
94.3
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
99% sRGB
Response Time
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 75 kHz
Video Bandwidth
170 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Controls & Adjustments
Colour balance, input select, luminance
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, 99% sRGB colour gamut
53.38 cm x 21.01 cm x 52.02 cm - with stand
5.78 kg
DVI-D (dual link) (HDCP) , MHL / HDMI (HDCP) , DisplayPort (HDCP) , DisplayPort output (HDCP) , Mini DisplayPort (HDCP) , 4 x USB 3.0 downstream , USB 3.0 upstream , Audio line-out
Mechanical
Tilt Angle
-5/+22
Swivel Angle
45
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), HP Quick Release, detachable stand, VESA 100 x 100 mm
1 x DisplayPort cable - 1.8 m , 1 x Mini DisplayPort cable - 1.8 m , 1 x SuperSpeed USB cable - 1.8 m
Backlight Life
30,000 hours
HP Smart Buy
Security Slot Type
Kensington security slot
Input Voltage
24 W
Power Consumption (Typical)
70 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
Included Software
HP Display Assistant
Dimensions & Weight Details
With stand - width: 53.38 cm - depth: 21.01 cm - height: 52.02 cm - weight: 5.78 kg , Without stand - width: 53.38 cm - depth: 4.93 cm - height: 35.11 cm - weight: 3.87 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 5 years - on-site - response time: next business day
5 °C
35 °C
20 - 80% (non-condensing)
