Create a seamless 16:10 multi-display setup with the HP Z24n Narrow Bezel IPS Display, which has a virtually borderless screen for maximum impact imagery, factory color calibration to ensure optimal color accuracy, and flexible connectivity for all of your devices.
Pick your picture
Use picture-in-picture or picture-by-picture to get views from your connected devices and boost your multi-tasking productivity. -
Find your sweet spot
Work comfortably with adjustable tilt, height adjustment, and swivel settings. Use pivot rotation to customize portrait or landscape views when using multiple displays. An integrated HP Quick Release Bracket supports wall mounting. -
Be responsible
Reduce power consumption and lower costs with an intelligent, energy-efficient, low-halogen design that is ENERGY STAR certified, TCO qualified, and EPEAT Gold registered with mercury-free display backlights and arsenic-free display glass.
- HP Z24n - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200 at 60 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 14 ms (grey-to-grey), 8 ms (overdrive)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- DVI-D, DisplayPort, Mini DisplayPort, HDMI (MHL)
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 53.38 cm x 21.01 cm x 52.02 cm
- 5.78 kg
- Localisation
- English / United Kingdom
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, UL, TUV GS, VCCI, C-Tick, BSMI, TUV S, WHQL, CB, CCC, TUV Ergo, FCC, KC, CECP, CEL Grade 1, SEPA
- 5-year warranty
- Display Type
- Diagonal Size
- 24"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Pixel Per Inch
- 94.3
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Vertical Refresh Rate
- 50 - 60 Hz
- Horizontal Refresh Rate
- 30 - 75 kHz
- Video Bandwidth
- 170 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, input select
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP, 99% sRGB colour gamut
- Black
- 53.38 cm x 21.01 cm x 52.02 cm - with stand
- 5.78 kg
- DVI-D (dual link) (HDCP) , MHL / HDMI (HDCP) , DisplayPort (HDCP) , DisplayPort output (HDCP) , Mini DisplayPort (HDCP) , 4 x USB 3.0 downstream , USB 3.0 upstream , Audio line-out
Mechanical
- Tilt Angle
- -5/+22
- Swivel Angle
- 45
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), HP Quick Release, integrated cable management, detachable stand
- Cables Included
- 1 x DisplayPort cable - 1.8 m , 1 x Mini DisplayPort cable - 1.8 m , 1 x SuperSpeed USB cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 70 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- On / Off Switch
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- With stand - width: 53.38 cm - depth: 21.01 cm - height: 52.02 cm - weight: 5.78 kg , Without stand - width: 53.38 cm - depth: 4.93 cm - height: 35.11 cm - weight: 3.87 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 5 years - on-site - response time: next business day
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
