HP Z24f G3 24"1920x1080 5ms HDMI DisplayPort IPS LED Monitor
Quicklinx: GLHMWS00 Mfr#: 3G828AA#ABU
28 In Stock
£210.83 ex VAT
£252.99 inc VAT
Meticulously crafted to surpass every design standard, the HP Z24f G3 FHD Display is composed of authentic aluminum and delivers an impressive, frameless viewing experience. Bring your ideas to life with remarkable color accuracy in precise Full HD resolution. Refine your work experience and transform your PC into a powerhouse with this 23.8-inch diagonal screen monitor.
  • Easily connect multiple monitors
    Declutter your desk and connect a series of displays by daisy chaining with a single DisplayPort cable.
  • All the ports you need
    Connect to a Workstation, a PC and additional displays.
  • Easily mount a Mini
    Mount your HPZ2 Mini or HP Desktop Mini directly to the monitor for a clean workspace.
  • HP Zero BrightDot Guarantee
    Even if just a third of a pixel fails or is stuck in one position, HP will replace the entire display.
  • Optional integrated audio
    Easily attach the Z Display Conferencing Speaker Bar for stereo quality audio and dual microphones.
  • 3-year limited warranty
    The assurance of HP's three-year standard limited warranty.
HP Z24f G3 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class D
Power Consumption (On mode)
12.5 W
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.274 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms (grey-to-grey with overdrive)
Input Connectors
HDMI, 2xDisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
(50/60 Hz)
Silver
53.84 cm x 19.5 cm x 48.93 cm
4.7 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
VCCI, BSMI, GS, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, cTUVus, KC, CECP, CEL, EAC, SEPA, BIS, DisplayPort 1.2, UAE, Ukraine Energy Label
3-year warranty
Display Type
Energy Class
Class D
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.274 mm
Pixel Per Inch
93
Brightness
300 cd/m²
Contrast Ratio
Response Time
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 75 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
On-screen Digital Controls, Low Blue Light Mode, Flicker Free technology, 4 Side Borderless Design, edge-lit LED backlight, 8-bit(6-bit + FRC) Colour Depth
Silver
53.84 cm x 19.5 cm x 48.93 cm - with stand
4.7 kg
DisplayPort 1.2 output , DisplayPort 1.2 , HDMI , 4 x USB 3.2 Gen 1 , USB (Type B)
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, arsenic free, mercury free
VESA bracket
1 x DisplayPort cable , 1 x USB-A to USB-B cable
Security Slot Type
Kensington security slot
Input Voltage
(50/60 Hz)
12.5 W
12.5 kWh/1000h
Power Consumption (Typical)
26 Watt
Power Consumption (Max)
58 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Center
Dimensions & Weight Details
With stand - width: 53.84 cm - depth: 19.5 cm - height: 48.93 cm - weight: 4.7 kg , Without stand - width: 53.84 cm - depth: 3.85 cm - height: 31.37 cm
Shipping Width
62.5 cm
Shipping Depth
37.3 cm
Shipping Height
14.2 cm
Shipping Weight
7.2 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
