HP Z240 SFF Xeon E3-1245V5 16GB 256GB SSD Windows 10 Pro
Quicklinx: DVCSWS00 Mfr#: 1WV51ET#ABU
  • Xeon
  • Microsoft Windows 7 Professional 64-bit Edition
HP's entry level workstations just got better. The HP Z240 with two amazingly versatile form factors, packs the performance, features, and reliability of a workstation into the price point of a desktop PC.
  • Choose the OS for you
    Support your unique user needs with a choice of Windows 10 Pro or Linux operating systems.
  • Better Package. Bigger Punch
    Get more performance, expandability and flexibility than our previous generations.
  • Powerful performance
    Achieve the performance you need with your choice of next generation Intel Xeon processors or Intel Core processors.
  • Ultra-fast storage
    Handle large files, reduce work time and increase performance with the optional HP Z Turbo Drive.
  • Work smarter
    Up to 64 GB DDR4 ECC memory helps provide no compromise capacity, performance, and reliability.
  • Geared up graphics
    Ignite productivity with NVIDIA professional graphics cards in 2D or 3D.
HP Workstation Z240 - SFF - Xeon E3-1245V5 3.5 GHz - vPro - 16 GB - SSD 256 GB - UK
Workstation - small form factor
Platform Technology
Intel vPro Platform
1 x Intel Xeon E3-1245V5 / 3.5 GHz (, up to 3.9 GHz, (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
16 GB (installed) / 64 GB (max) - DDR4 SDRAM - ECC - PC4-17000
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 256 GB - PCI Express 3.0 x4 - PCI Express - HP Z Turbo Drive G2, NVM Express (NVMe)
Optical Storage
DVD-Writer
Card Reader
Graphics Controller
Intel HD Graphics P530
1GbE
Keyboard
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit)
33.8 cm x 38.1 cm x 10 cm
5.7 kg
Manufacturer Selling Program
HP Smart Buy
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Intel vPro Platform
Workstation
Product Form Factor
Small form factor
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Clock Speed
3.5 GHz
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel C236
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
16 GB / 64 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
4 (Total) / 2 (empty)
Unbuffered
Configuration Features
2 x 8 GB
RAM Supported
64 GB unbuffered - ECC , 64 GB unbuffered - non-ECC
Hard Drive
SSD - PCI Express
1 x 256 GB
Interface Type
PCI Express 3.0 x4
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
4
RAID Level
RAID 0, RAID 1
Optical Storage
DVD-Writer - SATA
Card Reader
Card reader
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
Laser
USB
Ethernet Controller
Intel I219-LM
Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
Bays
1 (total) / 1 (free) x 3.5" , 1 (total) / 1 (free) x internal 3.5" , 1 (total) / 1 (free) x internal 2.5"
Slots
1 (total) / 0 (free) x CPU , 4 (total) / 2 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, low-profile , 2 (total) / 2 (free) x PCIe 3.0 x1 - half-length, low-profile , 1 (total) / 0 (free) x PCIe 3.0 x16 - half-length, low-profile (x4 mode) , 1 (total) / 1 (free) x M.2 Card (x4 mode)
8 x USB 3.0 (2 front, 6 rear) , 2 x USB 2.0 (2 in front) (one of them is charging) , 1 x headphones (1 in front) , 1 x headphones/microphone (1 in front) , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x audio line-out
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
RoHS, WEEE, ACPI 4.0
HP Smart Buy
Power supply
Power Provided
240 Watt
Efficiency
92%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) English
33.8 cm
38.1 cm
10 cm
5.7 kg
5 °C
35 °C
8 - 85% (non-condensing)
