HP's entry level workstations just got better. The HP Z240 with two amazingly versatile form factors, packs the performance, features, and reliability of a workstation into the price point of a desktop PC.
Choose the OS for you
Support your unique user needs with a choice of Windows 10 Pro or Linux operating systems. -
Better Package
Get more performance, expandability and flexibility than our previous generations. -
Powerful performance
Achieve the performance you need with your choice of next generation Intel Xeon processors or Intel Core processors. -
Ultra-fast storage
Handle large files, reduce work time and increase performance with the optional HP Z Turbo Drive. -
Work smarter
Up to 64 GB DDR4 ECC memory helps provide no compromise capacity, performance, and reliability. -
Geared up graphics
Ignite productivity with NVIDIA professional graphics cards in 2D or 3D.
- HP Workstation Z240 - SFF Core i7 6700 3.4 GHz - vPro - 8 GB - HDD 1 TB - UK
- Workstation - SFF
- Platform Technology
- Intel vPro Platform
- Localisation
- Processor
- 1 x Intel Core i7 (6th Gen) 6700 / 3.4 GHz (up to 4 GHz, (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 1 TB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- Intel HD Graphics 530 Shared Video Memory (UMA)
- Networking
- 1GbE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
- 33.8 cm x 38.1 cm x 10 cm
- 5.7 kg
- Manufacturer Selling Program
- HP Smart Buy
- Workstation
- Product Form Factor
- SFF
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Intel Core i7 (6th Gen) 6700
- Clock Speed
- 3.4 GHz
- Max Turbo Speed
- 4 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel C236
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- Technology
- Effective Memory Speed
- 2133 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 4 (Total) / 3 (empty)
- Unbuffered
- Configuration Features
- 2 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- DisplayPort
- Max Monitors Supported
- 3
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP USB Business Slim Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Laser
- Interface
- USB
- Ethernet Controller
- Intel I217-LM
- Data Link Protocol
- Wake on LAN (WoL), PXE support
- Bays
- 1 (total) / 0 (free) x external 5.25" x 1/2H , 1 (total) / 1 (free) x external 3.5" , 1 (total) / 0 (free) x internal 3.5" , 1 (total) / 1 (free) x internal 2.5"
- Slots
- 1 (total) / 0 (free) x CPU , 4 (total) / 2 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 2 (total) / 2 (free) x PCIe 3.0 x1 - low-profile (x1 mode) , 1 (total) / 1 (free) x PCIe 2.0 x4 - low-profile (x16 mode)
- 4 x USB 3.0 (2 front, 2 rear) , 4 x USB 2.0 (2 front, 2 rear) , 1 x headphones/microphone (1 in front) , 1 x headphones (1 in front) , 1 x serial , 3 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x audio line-out
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- RoHS, WEEE, ACPI 4.0
- HP Smart Buy
- Power supply
- Voltage Required
- Power Provided
- 240 Watt
- Efficiency
- 92%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
- 33.8 cm
- 38.1 cm
- 10 cm
- 5.7 kg
- 5 °C
- 35 °C
- 8 - 85% (non-condensing)
