HP Z240 MT Core i7-7700 8GB 256GB SSD Windows 10 Pro
Quicklinx: DVCVWS00 Mfr#: Y3Y80ET#ABU
  • Core i7
  • DVD-ROM
HP's entry level workstations just got better. The HP Z240 with two amazingly versatile form factors, packs the performance, features, and reliability of a workstation into the price point of a desktop PC.
  • Powered to manage your challenges
    Powerful processors, graphics, memory, and two optional ultra-fast HP Z Turbo Drives make the HP Z240 a true workstation-class solution. Handle your growing and complex workloads with performance for any stage in your work process.
  • Small price, big possibilities
    The essential features of the HP Z240 Tower easily support your workload with slots and ports to spare. When you're ready for workstation class features, like professional ISV certifications, the HP Z240 Tower is the right first step.
  • Priced for your budget
    HP's most affordable workstation allows you to customize your experience while still balancing your IT budget. HP reliability, thorough testing, and ISV certification means your HP Z240 is designed as a long-term budget friendly solution.
HP Workstation Z240 - MT - Core i7 7700 3.6 GHz - 8 GB - 256 GB - UK
Workstation - mini tower
1 x Intel Core i7 (7th Gen) 7700 / 3.6 GHz (4.2 GHz) (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x SSD 256 GB - SATA 6Gb/s
Optical Storage
DVD
Card Reader
Graphics Controller
Intel HD Graphics 630 Shared Video Memory (UMA)
GigE
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
17 cm x 44.2 cm x 39.9 cm
8.6 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Workstation
Product Form Factor
Mini tower
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
4.2 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel C236
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
8 GB / 64 GB (max)
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
4 (Total) / 2 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
2 x 4 GB
Hard Drive
SSD
1 x 256 GB
Interface Type
SATA 6Gb/s
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
4
RAID Level
RAID 0, RAID 1
Optical Storage
DVD
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card, miniSD, microSD, SDHC Memory Card, miniSDHC, Memory Stick Micro (M2), microSDHC, SDXC Memory Card, SDHC UHS-II Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
DVI, DisplayPort
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
Laser
USB
Ethernet Controller
Intel I219-LM
Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
Bays
2 (total) / 2 (free) x external 5.25" x 1/2H , 1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 2 (free) x internal 3.5" , 1 (total) / 0 (free) x internal 2.5"
Slots
1 (total) / 0 (free) x CPU , 4 (total) / 2 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x1 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x4 - full-length, full-height , 1 (total) / 1 (free) x M.2 Card (x4 mode)
6 x USB 3.0 (2 front, 4 rear) , 4 x USB 2.0 (2 front, 2 rear) (one of them is charging) , 1 x headphones/microphone (1 in front) , 1 x headphones (1 in front) , 2 x DisplayPort , 1 x DVI-D , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x audio line-in , 1 x audio line-out , 1 x microphone
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
RoHS, WEEE, ACPI 4.0, low halogen
Power supply
Nominal Voltage
Power Provided
400 Watt
Efficiency
92%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
ENERGY STAR Certified
17 cm
44.2 cm
39.9 cm
8.6 kg
5 °C
35 °C
8 - 85% (non-condensing)
