Get workstation performance with next-generation graphics at prices you'd expect from a desktop PC. Available as a Convertible Minitower or a Small Form Factor, HP offers the enterprise-class design that fits you best.
Designed to fit your business
Choose the expansive Convertible Minitower or the space-saving Small Form Factor design – both complete with tool-free chassis that make adding hard drives and upgrading memory a snap.Take advantage of world class architecture with the latest in connectivity for external storage devices and peripherals. Transfer data 10x faster than USB 2.0 ports with four integrated super-speed USB 3.0 ports.Business-built and environmentally aware – featuring a 90% efficient power supply, BFR/PVC free configurations and your choice of ENERGY STAR qualified configurations. -
High performance, no sweat
Increase performance and reduce energy consumption with next-generation 22nm processors, including the Intel Xeon processor E3-1200v2 family and 3rd-generation Intel Core processors.Give memory intensive applications a boost with 1600 MHz DDR3 memory technology and support for ECC memory configurations to help protect your data integrity.Keep going at a moment's notice with Intel Smart Response Technology, a disk cache solution that provides solid state drive like performance, faster boot up times and quick application responsiveness.Optimize your output with integrated HP Performance Advisor. Run reports, diagnose and fine-tune your workstation specific to your professional applications with just one click. -
Next-generation graphics
Take presentations to the next level and bring work to life with integrated Intel HD Graphics.Access your high-performance 2D, 3D, video and media-rich applications regardless of where you are. Preinstalled HP Remote Graphics Software gives you the freedom to work remotely without skipping a beat.Be ready with the bandwidth you need for tomorrow's generation of PCIe 3D graphics cards from NVIDIA and AMD the moment they're available.
- HP Workstation Z220 - CMT Xeon E3-1225V2 3.2 GHz - vPro - 4 GB - HDD 500 GB
- Workstation - CMT - system password, power-on password, USB port control, audio ports control, network port control
- Platform Technology
- Intel vPro Platform
- Localisation
- Processor
- 1 x Intel Xeon E3-1225V2 / 3.2 GHz (up to 3.6 GHz, (Quad-Core)
- Processor Socket
- LGA1155 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR3 SDRAM - ECC - PC3-10600
- Storage Controller
- SATA (SATA 6Gb/s); SATA (SATA 3Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Card Reader
- 22 in 1
- Graphics Controller
- Intel HD Graphics P4000 Shared Video Memory (UMA)
- Audio Output
- Integrated
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8 Pro 64-bit) + Windows 8 Pro 64-bit Licence
- Microsoft Office Preloaded
- Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
- Software Included
- Intervideo WinDVD, Roxio Easy Media Creator, HP ProtectTools Security Software Suite, HP Support Assistant, HP Power Assistant, PDF Complete (Trial), HP Performance Advisor
- Jack black
- 17.8 cm x 45.5 cm x 44.7 cm
- 10.4 kg
- Manufacturer Selling Program
- HP Smart Buy
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Limited warranty - parts and labour - 3 years - on-site - response time: next business day
- Workstation
- Recommended Use
- Small business, corporate business
- Product Form Factor
- CMT
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Jack black
- Localisation
Processor / Chipset
- CPU
- Intel Xeon E3-1225V2
- Clock Speed
- 3.2 GHz
- Max Turbo Speed
- 3.6 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1155 Socket
- Chipset Type
- Intel C216
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- Technology
- DDR3 SDRAM - ECC
- Effective Memory Speed
- 1333 MHz
- Rated Memory Speed
- 1333 MHz
- Memory Specification Compliance
- PC3-10600
- Form Factor
- DIMM 240-pin
- Slots
- 4 (Total)
- Unbuffered, dual channel memory architecture
- RAM Supported
- 32 GB unbuffered - ECC , 32 GB unbuffered - non-ECC
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 2
- RAID Level
- RAID 0, RAID 1
Storage Controller (2nd)
- SATA 3Gb/s
- Channel Qty
- 4
- RAID Level
- RAID 0, RAID 1
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
- 22 in 1 card reader
- Supported Flash Memory Cards
- CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, Microdrive, MultiMediaCard, SD Memory Card, Memory Stick Duo, xD-Picture Card, Memory Stick PRO Duo, miniSD, RS-MMC, microSD, SDHC Memory Card, miniSDHC, microSDHC, Memory Stick PRO-HG Duo, SDXC Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- DVI, DisplayPort
- Max Monitors Supported
- 2
Audio Output
- Integrated
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Standard Keyboard
- Interface
- PS/2
Mouse
- Technology
- Laser
- Interface
- USB
- Integrated
- Ethernet Controller
- Intel 82579LM
- Data Link Protocol
- Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3az
- Bays
- 3 (total) / 1 (free) x external 5.25" , 3 (total) / 2 (free) x internal 3.5"
- Slots
- 1 (total) / 0 (free) x CPU , 4 DIMM 240-pin , 2 (total) / 2 (free) x PCI - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x16 - full-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 2.0 x8 - half-length, full-height (x4 mode) , 2 (total) / 2 (free) x PCIe 2.0 x1 - full-height
- 5 x USB 2.0 (1 front, 4 rear) , 4 x USB 3.0 (2 front, 2 rear) , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x audio line-out , 2 x microphone (1 front, 1 rear) , 1 x headphones (1 in front) , 1 x DisplayPort , 1 x DVI-I
- System password, power-on password, USB port control, audio ports control, network port control
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- ACPI 2.0, RoHS, WEEE
- HP Smart Buy
- Power supply
- Voltage Required
- Power Provided
- 400 Watt
- 80 PLUS Certification
- 80 PLUS Gold
- Efficiency
- 90%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8 Pro 64-bit) + Windows 8 Pro 64-bit Licence
- Software
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- 17.8 cm
- 45.5 cm
- 44.7 cm
- 10.4 kg
- 5 °C
- 35 °C
- 8 - 85% (non-condensing)
